Excessive vibrations on spin(transit bolts) - Washing Machines
    Scholar:
  • 59 Answers
You must remove these transit bolts . after you do try it . of course the legs of the washer must be set to make the machine levl. and then make sure the lock nuts on each leg are tightened. with a level machine with the leg locknuts tight the machine should spin smoothly. if you fasled to remove the transit bolts first then you may have damaged the suspension. then you will have to call for professional service. good luck
Posted on Aug 04, 2010
  • scragerx7 Aug 24, 2011
    HOW do you remove those bolts?
2 Suggested Answers
beltronic205
  • 1474 Answers
SOURCE: When under load, Excessive vibration and noise
If you have excess play on inner drum it will be the drum Bearings which is a common problem with this make......
Posted on Feb 22, 2011
Testimonial: "Many thanks for your expert advice. do you know if bearings are easily accessible to fix ?"
Amana LW2503
is this a new machine if it is you need to remove the transit bolts
Feb 20, 2013 | Washing Machines
I left the transit bolts in our "brand new" zanussi washing machine and am afraid to use it as I do not know what damage might have been done.
Highly unlikely any damage will have been done so long as it hasnt been in use for a long time (weeks).
In a front loading washing machine, most of the mechanicals inside are held between springs at the top and dampers at the bottom. The transit bolts are used to minimse how much movement can ocour whilst the machine is in transit as excessive movement could damage the springs/dampers. When they are removed, normal movement of the mechanicals helps keep the machine stable and minmises vibration.
So, the worst that happens when the machine is used with the transit bolts in place is it vibrates alot, and possible moves about.
Remove the bolts as soon as possible and it should be fine.
Oct 04, 2009 | Zanussi ZWF12070 Front Load Washer
Brand new washing machine wandering on spin cycle
It sounds like the transit bolts or some of the packing is still in place. Running the machine with these in place can do serious damage.
Thankyou for using Fixya.
Feb 14, 2009 | Washing Machines
Hotpoint Aquarius WMA46 1300 , front loader
half loads will vibrate more than full load
check transit bolts are removed
if vibration persists, then fault is probably shock absorbers worn
Sep 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint washing machine vibrate/oscillates violently when on spin mode. Installation instructions tell you to adjust the feet, which I have done. I have also tried different sizes of load - no difference...
have you removed the transit bolts? this is the usual cause of violent vibration. if not, do not use the machine till this is done as you can cause a lot of damage
Sep 03, 2008 | Washing Machines
Samsung WF 338 washer
Hello.
These are usually shipped with a number of "shipping bolts" to lock the drum in position during transit. If they are not removed when it is installed, then the washer will behave exactly as you describe. Check the manual or look for a sticker on the back or the washer showing which bolts to remove,
-ellie
Jun 26, 2008 | Washing Machines
Transit brackets
Hiya .. the transit bolts are located under the lid at either side ..or at the rear... they are fairly long bolts which hold the drum and balance in place.. until installation. they will be sheathed in fairly hefty rubber grommets.
Screws for removal of lid located at the rear..2- or 4.. remove these slide lid front to back.. remove bolts if they are they are present... refit lid... note uneven siting of an appliance can cause excessive vibration as well!
Let me know if this sorts your prob
Regards Faggly
Mar 20, 2008 | Washing Machines
Excessive vibration during spin cycle
sure..start by re leveling the unit, with a standard carpenters level.
Mar 02, 2008 | Maytag Atlantis MAV5000
Washing Machines Logo
646 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
