Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
I HAVE TO PC COMPUTER TO VGA CABLE CONNECT TV SOCKET , BUT THERE FORE NO SIGNAL CONNECTED TO T V
  • Samsung Master
  • 12,061 Answers
  1. You must setup multiple desktops. And enable the screen, also it must be set up first to the right resoloution format etc.
http://www.microsoft.com/windowsxp/using/setup/learnmore/northrup_multimon.mspx
Above is how to do it. Also another help link below.
http://en.kioskea.net/faq/1068-displaying-video-from-a-pc-on-a-television-screen
Posted on Aug 04, 2010
When I connect my computer to the TV it says no signal
If there is VGA socket at the back of the TV, you can connect it to your PC, using a VGA cable.
Oct 28, 2014 | Vizio E320-B0 32IN LED TV Full Array
I have an Acer aspire m3200. I tried to connect it to my hdtv, i got picture but no sound using the VGA cord, and got nothing using the HDMI cord. Please help
Using a vga cable to connect your laptop to a hdtv is very easy but the cable does not transfer the audio signal, you need another cable aswell. You need a 3.5mm jack to jack cable, one end plugs into your headphone socket on your laptop and the other end plugs into the pc audio socket at the back of your tv (usually next to where you plug in the vga plug).
May 28, 2011 | Acer Computers & Internet
TV set to vga source - laptop connected via hdmi cable to vga socket - TV says no signal - how do I activate connection?
Please make sure that the connection is detected by your computer..go to the settings of your computer (where you adjust the screen resolution) and check if a 2nd monitor is detected (do this first before assigning the TV as your primary monitor just to ensure the connection).
If it's detected make sure that the resolution that you set is supported by the TV.
Hope this helps!
May 19, 2011 | Computers & Internet
HOW CAN I HOOK THE Panasonic TH-42PX75U TO THE VGA OUTPUT ON MY COMPUTER?
If your computer has an HDMI socket, all you need is an HDMI cable. If not you need a VGA cable (the blue cable that usually connects a computer to it's monitor. One end goes into the socket on your TV marked VGA or PC. the other end goes into the monitor output on your computer. if you have a laptop, there will be a vga socket (usually blue inlay in the socket) on the side or back. you will then need to set up the second screen in Control panel, display settings. If using the VGA cable, you will need to run an audio cable from the speaker/headphone socket of your computer to your tv (there will be a 3.5mm jack near the VGA socket) or to your audio receiver.
Good luck.
Apr 15, 2011 | Panasonic TH-42PX75U 42 in. Plasma HDTV
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
Can i hook my computer to tv ?
Hello
You can connect your Sylvania LC320ss8 to a computer. There is a socket at the back of your TV to connect it with a PC via VGA cable. One end of that cable must be connected to TV, and the other end of the VGA cable must be connected to PC's monitor out jack.. You have to purchase on VGA cable for this purpose, and is available at most of the electronic spare part shops. A "mini-plug audio cable" also is needed to connect the audio from PC to TV. Its one end to be connected to PCs Audio Line Out jack and its other end to TVs PC in audio jack. Both Jacks can be located at the back side of the TV. After connecting it select the TV to receive PC signals according to its manual says. OK.
Jan 26, 2011 | Sylvania LC320SS8 32 in. LCD Television
Hi, I am trying to connect my laptop to my TV using VGA (MALE) to VGA (MALE) cable. I am able to see black lines on the TV with noise.How can i correct this ?
You didn't say, is the TV HDTV??
From Windows help menu, press F1, type in "VGA connection" I found this:
Why can't I hear audio when I connect my computer to an HDTV?
VGA, DVI, and component video cables do not support audio signals. HDMI cables do support audio signals, but not all HDMI-enabled video cards support audio. If your HDTV has an audio input, you might be able to connect a separate audio cable from your computer's sound card directly to the TV. Otherwise, you'll need to connect the audio signal to a different output device, such as external computer speakers or your home stereo system. For more information about sound cards, see Sound cards: frequently asked questions.
From Wikipedia.org search VGA connection:
1.
Video Graphics Array (VGA) refers specifically to the display hardware first introduced with the IBM PS/2 line of computers in 1987,[1] but through its widespread adoption has also come to mean either an analog computer display standard, the 15-pin D-subminiature VGA connector or the 640×480 resolution itself. While this resolution was superseded in the personal computer market in the 1990s, it is becoming a popular resolution on mobile devices.[2]
VGA was the last graphical standard introduced by IBM that the majority of PC clone manufacturers conformed to, making it today (as of 2010[update]) the lowest common denominator that all PC graphics hardware can be expected to implement without device-specific driver software.[citation needed] For example, the Microsoft Windows splash screen appears while the machine is still operating in VGA mode, which is the reason that this screen always appears in reduced resolution and color depth.
VGA was officially superseded by IBM's Extended Graphics Array (XGA) standard, but in reality it was superseded by numerous slightly different extensions to VGA made by clone manufacturers that came to be known collectively as Super VGA.
2.
The same VGA cable can be used with a variety of supported VGA resolutions, ranging from 640x400px @70 Hz (24 MHz of signal bandwidth) to 1280x1024px @85 Hz (160 MHz) and up to 2048x1536px @85 Hz (388 MHz). There are no standards defining the quality required for each resolution, but higher-quality cables typically contain coaxial wiring and insulation which make them thicker. A quality cable should not suffer from signal crosstalk which occurs when the signals in one wire induce unwanted currents in adjacent wires, ghosting which occurs when impedance mismatches cause signals to be reflected (note that ghosting with long cables may not be the fault of the cable but may instead be caused by equipment with incorrect termination or by use of passive splitters), and other signal degradation effects; shorter VGA cables are less likely to introduce significant degradation. Some higher-end monitors and video cards featured 5 separate BNC connectors for RGBHV signal, allowing highest quality connection using five 75 Ohm coaxial cables.
I hope this helps, I find the sales reps at Best Buy very helpful.
Dec 04, 2010 | Computers & Internet
How to connect my pc to my tv & use it as a monitorbaxterstead000@hotmail.com
-get a vga cable(usually both ends are male) - connect it to the vga port on the laptop then the other end to your tv -press fn+f2 to switch the display to your tv( this is model/brand dependent, check your user's manual for more info)
Oct 23, 2010 | Computers & Internet
Connecting my netbook to my tv
Hi
You will need a male to male, 15 pin D-SUB VGA cable to connect the webbook to the TV. You also have to make sure that your television supports such a connection. If not and it has side AV then you can get a male to RCA VGA cable.
Then you will need an audio cable as VGA does not carry a an audio signal. You will need a male to male mini stereo jack.
Connect the VGA cable to your computer and then to the TV. Then plug the audio jack into the headphones socket of the webbook and to the PC IN or audio in on the TV.
Turn the webbook on and if you have to use the Fn key and one of the F keys to switch screens (it usually does it automatically but the keys are usually between F4 and F7)
Regards.
Feb 09, 2010 | ASUS Eee PC 900HD Netbook
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
69 people viewed this question
Jerry Greenberg
Jerry Greenberg
