Question about LG enV VX9900 Cellular Phone
Weird I love my phone but it started doing something weird two days ago.. The phone wasn't dropped or damaged in any way. When the phone is closed and the screen is locked it will randomly light up and go to the music page. It is like a button is stuck down or something. It will only do it for awhile and then it will be fine again. The phone is in a plastic case and the buttons appear fine to me. Any ideas??
The plastic case my be too tight on the phone causing it to have some buttons pressed down. But you might have to turn the phone on and off, and if that doesn't work the you should be able to get another phone free and without any hassle...
Posted on Apr 26, 2008
Ok, so my little sister dropped my iphone on the floor and now it has white spots all over it, it seems as if it had water inside but it wasn't dropped on water. And it won't let me listen to my...
clean with isopropyl or" petrol.if use ******** wash very good.something heat with mobilephone past.so work it again.harry up in one day or"So4 damage your board.
May 30, 2012 | Apple Cell Phones
Hey, I had a few samsung INNOV8's some time ago... I unlocked 1 of them at a service shop and it suddenly started having battery problems like it would only last a maximum of 1 day... now i still have 1...
Battery lasting one day is about right for an aftermarket battery.
I have an innov8 and with my standard I get maximum 2 days and less than a day with the "cheap" battery.So if you do unlock,you wont be loosing much.
The innov8 is a great phone ,love it ,but battery life, sucks!
Nov 02, 2010 | Samsung SGH-i8510 INNOV8 Cell Phone
My sony Ericsson C902 screen has two black lines running accross the screen. I did drop it about 2 months ago but it was fine afterwards and since that I have not dropped it again. The lines were there...
Damage takes time especially water damage. I suggest getting a new phone because over the next month chances are against you that the phone screen will fully black out. Get a new phone as soon as you can. Not having a screen sucks, trust me! I hope I helped you out! Good Luck!
Mar 19, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
I dropped my blackjack II on the concrete the other day, at first when the screen was supposed to black out it would go to a white screen, then when it stopped doing that the screen would flicker off and...
Fixing it will most likely cost close to getting a new one. Getting a new phone is certainly the easiest answer.
The problem with screen damage, is that most of the screens use lcds (liquid crystal displays) if damaged its hard to repair something that is mostly liquid.
Sorry about your phone. I hope its insured.
Dec 16, 2008 | Samsung Blackjack SGH-I607 Smartphone
V3 razor screen is locked
describe ur problem briefly for help!!!!
May 16, 2008 | Motorola Mobility RAZR V3
Neo mp3 players
only one of my headphones is working i started to notice it a couple of days ago what does that mean?
Mar 30, 2008 | Audio Players & Recorders
Motorola Razr V3- Acting weird
Have u dropped ur phone in any liquid or have u connected it to a pc of some sort? When did this start happening and i need for u to be honest with me if u have done anything odd to the phone. Any info can help me resolve ur problem.
Jan 28, 2008 | Motorola Mobility RAZR V3
Monitor started to flicker then went blank
I have a envision professional series and I love it, but I will get to the point.
I recent ly received a Envision EN9410e monitor, had the same problem (flickering screen then turned on, then off then on then blank). The problem is bad capacitors. There are 7 electrolytic capXon capacitors that will need to be replaced. You should see if the caps are bulging or leaking, if so replace. As known by many replace with the same capacitance and voltage. There are a few incidences that the capacitors where replaced and the problem wasn’t solved; this is because the cap problem wasn’t taken care of and damage occurred to another part of the monitor. The back light is a Royer oscillator (cool things) and it uses two smd mosfet transistors. They are on the green side of the circuit board near a big control chip (they each look like a off rectangle black square with eight pins) you need to see if there is any carbon or chard residue between the pins or burning smell from them, if there is you need to remove the transistor and do some board repair then ether put a new transistor or try the old one. No offence to the people at Envision but not smart putting the drain, gate and source so close to each other under the chip where there is such high voltage! Hope this helps.
Dec 24, 2007 | Computers & Internet
Dropped phone and now it won't slide correctly
You probably have a chip inside the center of the slider. Try taking a vac to it and sucking out any fragments that might make it rough. Otherwise you have damaged your phone and most likely your provider will not replace the phone due to normal wear and tear damage.
Nov 21, 2007 | Samsung SGH-d807 Cellular Phone
W375 is acting weird
I have motorola w375 mobile but in this mobile How use data cable or usd drive on this mobile
Aug 28, 2007 | Motorola Mobility W375 Cellular Phone
LG enV VX9900 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
