Question about Horizon Exercise & Fitness
Horizon treadmill loud squeaking sound once I run over 3.0 (speed)
    Champion:
  • 218 Answers
You need to lubricate the pivot points and deck. Check to make sure the deck is not broken.
Posted on Aug 11, 2010
Tip
HORIZON FITNESS TREADMILL ENGINEERING MODE AND RUNNING BELT ADJUSTMENT
Eng0 - Display and Button Check
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng0 appears in the display.
2. Press "Enter" to select Eng0.
3. Press "Start" button to verify all LED's
Eng1- Hardware Test
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng1 appears in the display.
2. Press "Enter" to select Eng1.
3. Press "Start" button to verify belt movement, sensor wire, and elevation function.
Eng2 - Auto Calibration
1. While in the Engineering Mode Menu, press Speed "+" or "-" until Eng2 appears in the display.
For more check the following link . from the drop down menu select treadmills.
www.electro-medical.blogspot.com
on May 03, 2015 | Horizon Exercise & Fitness
Treadmill
Dear Sir:
PLease LUBE the deck belt, is possible the deck is worn!
2) Test the drive belt too 3) Test and lube the roller bearing 4) Lube the bearing main motor. All this parts is subjects to maintenance, see your instruction manual.
Run the software calibration for diagnose, and troubleshooting.
sincerely. God bless you
May 03, 2012 | Horizon Fitness Horizon T101 9 Program...
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Dec 26, 2010 | Horizon T91 Treadmill
I have a horizon fitness t51 treadmill. I weigh about 138 pounds and typically run 5 miles a day at a 2% elevation at a steady speed somewhere between 5-6 mph. It recently has developed one of two...
hi,
from ur description i think ur treadmills control module have problem. motor driving card and motor is ok. normally there are no serviceable part inside the controlling module ( user interface module). only thing can do is remove the controlling module, take out its board check all the micro switches( press button switches) replace it found faulty or not( remember to remove the power before). the refix it and the test the tread mill.
ok
Dec 26, 2010 | Horizon Fitness Horizon Motor T51...
Treadmill squeaks
There's a special silicone-based treadmill lubricant that you put between the belt and rollers See this treadmill accessory kit
Jun 24, 2010 | Proform CrossWalk TreadSoft Treadmill
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
Erratic speed on Horizon treadmill.
Treadmills Erratic speed on Horizon treadmill. Solve Hi The speed of the treadmill does not correspond to the speed control key. Any... (More)
Apr 18, 2009 | Horizon Exercise & Fitness
Exercise & Fitness Logo
656 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
