Water won't drain away - how do we get to the punp to unblock it please? Nothing in manual to help. Thank you, Jenny
    Brigadier General:
  • 4,090 Answers
Jenny, you did not list a brand so we are unable to help 100%
Most access is from the rear panel, but often easier to access by turning machine on its side and coming in from the bottom. Follow the hose from the outlet to the pump and undo the clamps on in and out as blockages occur on both sides. After removal of any matter in the pipes, flush hoses from both ends to ensure flow. Connect inlet hose to pump and run some water through pump with drain hose disconnected to ensure pump is also clean. replace outlet hose and make sure clamps are done up tight otherwise they will leak.
Stand machine back upright and test.
Please rate my help++++Thanks for using FIXYA
Posted on Aug 04, 2010
Washing Machine won't drain away water.
Hi, can you hear the pump running when you select a drain program?
Mar 11, 2013 | Washing Machines
New unlocked cell phone won't turn on
Hey, same problem. Push and hold the hangup button. It will prompt to insert sim , but I only have one. The phone works. The website and the manual are useless. Just gotta play with it, I guess.
Mar 06, 2013 | Cell Phones
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
Inlet/drain light flashes on miele dishwasher and water will not completely drain away. Model G638l plus help please
the pump is blocked, need to remove the trays, drain plg, the gauze, scoop the water out as much as possible, thge thers a plastic hosing with a spring clip on top, remove this to unblock the pump. assemble & should be good to go.
May 23, 2011 | Miele 24 in. G638 Plus Free-standing...
Does the Hoover HW160M washer/dryer need an exhauest duct to carry away the water vapour from the dryer?
No vent hose required
This appliance condenses the water vapour to a liquid and punps it down the drain.
Jan 10, 2011 | Hoover HW160M Front Load Washer / Dryer
Water not draining
Set the controls to off then power off at the mains for 30 mins and then power mains back on and run a drain program or a full wash program. If the water won’t drain away then the most likely problems are the door interlock switch is faulty, the drain water motor is faulty, there is a blockage in the drain outlet pipe or filter – this will need unblocking, there is a blockage in the water pump – this will need to be unblocked, the controller board is faulty – but this generally shows an error code. First turn off the mains power to the dishwasher then check the internal filter and screen and clean it thoroughly. Then check the waste water hose and any outlet valve and make sure that it is unblocked and free of any obstruction or waste material. If you have access to the water pump you can check that it is free of obstruction and is able to turn and that none of the impeller vanes have been damaged. Then if all this is OK then try turning on the mains power and running a hot wash cleaning cycle to flush out any remaining sludge / debris.
Oct 01, 2009 | Frigidaire Dishwashers
Dishwashers
you have a draining problem ... check the garbage disposal that it is clear.. then check your drain hose and the the drain trap inside your dishwaher....
if all this don't help then go to the drain pump ... hope it helps
Jun 14, 2008 | Dishwashers
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
