I have formatted my Mitone Mitmp30 player, I am now getting a disk error on all optiions. Is there firmware available to update the player.
  • 677 Answers
Hi, yes there is firmware update available.
Visit the website of Mitone Mitmp30 player an get the update for your mp3 player.
Take care.
Posted on Aug 04, 2010
  • 1 more comment
  • Please supply web address, I can not find one.
  • ikechukwu joshua
    ikechukwu joshua Aug 04, 2010
    If a player like this
    http://www.szimp3.com/product_show.asp?B... ,
    there are several clones of the Chinese goods. Firmware on the Russian here (English supports)
    http://ftp.roverbook.com/RoverMedia/Aria...
    there two different versions of firmware for the assembly player (one can work with bugs)
    Methodology firmware:
    1. Disable USB cable, turn off player.
    2. Holding down "M" connect the USB cable.
    3. The menu select 3 - y para (other then USB disk), clicking the right analog stick.
    4. The system will appear logical disk 2. First at 16 mb, second - remaining FLASH memory.
    5. Copy invested in this archive 5 files on 16 - MB removable disk (all except reame.txt).
    6. Turn off the player through the safe extraction devices.
  • I have tried to follow the instructions, they are not understandable, no menu selct 3 is available. Also where is the right analog stick?
Boot error problem. everytime i swich it on it says boot error
the media player's firmware which contains bootable files is seems corrupted. probable cause is virus or electrical failure of firmware. you can scan the player by computer which has latest updated anti-virus. if that not work try to format it. you can get the firmware if it is available from the manufectures web site, try to reload it.
Oct 13, 2011 | Audio Players & Recorders
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
Screen shows flash error to format
you should reinstall the firmware in the mp3 player
to do that you can go on the mp3 manufacture's website click on support and look for the appropriate firmware that fit your model number
once it's download
plug your mp3 to your pc and then run the firmware updater
you should be able to use your mp3
good luck
Jun 19, 2009 | GPX MW8847DT MP3 Player
My mp3 player says initializing
Same here...I hate Phillips right now
Aug 16, 2008 | RCA M4204 MP3 Player
On my rca pm3 player it is stuck on initializing it will not turn off by pressing the turn off button
I have not tried this yet but RCA support sent me this.
I suggest updating the firmware on your player. After upgrading the firmware on your player, you must use the easy rip software. This will avoid problems in the future and keep the unit updated
1. Go to www.audiovox.com
2. Go to FAQ’s in search enter M4204
3. Download firmware upgrade
4. Hold play/pause button for 15 seconds
5. Hold menu button for 10 seconds
6. Attach M4204 via USB cable while holding play/pause button
7. This should start the firmware upgrade
8. Possible an error message of “cant write to disk” will pop up
9. Firmware upgrade will end with error do not close
10. Go to My Computer find the drive that holds the MP3 player
11. Right click scroll down to format, format the player
12. Run firmware upgrade again
Aug 04, 2008 | SanDisk Sansa m230 MP3 Player
Need firmware for MiTone MITMP20
http://www.szimp3.com/product_show.asp?BigClassName=MP4&SmallClassName=MP2610  ,
http://ftp.roverbook.com/RoverMedia/Aria_Q7
Jan 22, 2008 | Apple iPod shuffle MP3 Player
MITONE MP3 player software files are formatted
If a player like this http://www.szimp3.com/product_show.asp?BigClassName=MP4&SmallClassName=MP2610 , there are several clones of the Chinese goods. Firmware on the Russian here (English supports) http://ftp.roverbook.com/RoverMedia/Aria_Q7  there two different versions of firmware for the assembly player (one can work with bugs)
Jan 08, 2008 | Yifang Digital Easy Mp3 EM02 MP3 Player
Error Message
This just sounds to me like you have a slight error. You may need to update your firmware/drivers or formatting.
One of those solutions should fix your problem.
To update your firmware you will need to visit your mp3 players manufacture, I have found your firmware all you will need to do is visit this link and download the firmware/drivers -
http://www.sandisk.com/driverdownload/index.asp
Once your on the website choose your mp3 player ect.. then click download.
If that doesn't do the trick my final solution is to format your mp3 player then update the firmware/drivers.
To format a basic way follow these steps. First click on "Start" - then go to "My Computer" - then look for your mp3 player if the name hasn't been customized it will come under the name of "Removable Disk" - once you've found it right-click on it then click on "Format".
Once you've formatted then do the first solution surgested. which was install the firmware/drivers. Once you've done that upload music back on to your mp3 player then see if the problems be fixed.
Good luck. Hope my solutions were helpful.
Oct 26, 2007 | SanDisk Sansa e250 MP3 Player
Rebuilding Library to Firmware Problem error...HELP
try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
Oct 08, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Error with formatting
Its not a firmware update you are running, it is a recovery tool. The "application failed to read version details" error is because it is not meant for your device. You have a Rhapsody version and the firmware is different. You will need to call SanDisk for them to email support documents. SanDisk Technical Support 1-866-726-3475 If you are truly trying to format the device, change the mode on the device Settings>Mode or USB Mode, then try formatting again. Best of Luck.
Oct 04, 2007 | SanDisk Sansa e260 MP3 Player
216 people viewed this question
 Grubhead
Grubhead
