Question about Garmin GPSMAP 60CS GPS Receiver
I have a Garmin 60csx that won't power up
The unit's been working fine for the 2 months I've had it.Today it froze on me and would not power down so I removed the batteries. After replacing the batteries it won't power up at all. Is there a hard reset to this thing? Or is there possibly something else I need to do.
Any help would be great!
  • 2 more comments
  • pakrat4life Apr 28, 2008
    I have a GPSmap 60CS (bought new 2005) that will not power on either after working just fine for 3 yrs. Replaced with new batteries and all! Seems like the on/off button is the culprit - may try to open and get to the button to see??
  • Dlincoln Oct 16, 2008
    My Garmin turned off and will not turn on - even when using the Car adapter. It seems like the power button has lost its pushed...
  • Anonymous Jan 05, 2009
    The screen fades away every time I try to power it up with the memory card in it. It works fine with the base map (no memory card)
  • neibard Feb 18, 2009
    On 5 months old 60CSx pressing power button turns on the screen. It seems to work just fine acquiring while the power button is held down. However, all the other buttons are disabled. When releasing the power button the screen display fades away. Seems like the processor fails to latch the "power-on" state. This is the same with or without SD chip, on battery or USB power. Talked to Garmin last night. They had me reload the software while holding the power button, did not help.
    Good thing it's still under warranty, but this does not make me feel too good about buying this unit. Will this happen again after the warranty?
On my GPSmap 60CSx the screen fades away after powering on - just like the battery is empty. Changed battery and used USB power. Always the same. When removing  the 2GB micro SD memory card then it comes up. Replaced the memory card and now it powers up fine. Seems that the memory card is damaged or causes a short circuit.
Posted on Feb 16, 2009
My device has seemed to have lost its ability to acquire satellites. Any suggestions? It's Garmin GPSmap 60CSx. Thanks.
I would try a reset and firmware update first. To Reset the unit hold the Page and Enter keys down while you power up the unit. hold them down until you get a prompt asking you if you really want to reset.
Garmin has a free software called webupdater. this will put the latest software in your unit. If there is a GPS chipset software available please apply that also. It will be in the list when you run webupdater.
You may want to try an external antenna also to see if an internal connection came loose.
Jul 11, 2010 | Garmin GPSMAP 60CSx GPS Receiver
How to Transfer Maps to GPSmap 60csx
You have use the unlock wizard to install the key that is provided with the software. When I bought my Mapsource CitySelect, it came with two keys. The way Garmin does it is, you can install the software as many times as you want on as many machines as you want, but can transfer the maps, data, etc ONLY to unlocked devices. Last I checked Garmin wanted $75 for additional unlocks. Some data is not locked, like Topo maps and some tide points since this data is obtained (by Garmin) from the gov't, which is free for us (wel, minus taxes we pay). Contact Garmin support, they are very attentive.
May 29, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Black Map - shows only cursor, North pointer, and data fields.
Try a hard boot on it. Remove the batteries for 1 minute, then re-insert them and try again. If this doesn't work, contact Garmin at
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
To speak with a service tech.
Apr 10, 2009 | Garmin GPSMAP 60CSx GPS
Garmin 60csx turning off while in use
OK, I've managed to overcome the problem :D I've formated the micro SD card and now it works without any glitches :D
Apr 15, 2008 | Garmin GPSMAP 60CS GPS Receiver
Garmin 60CSx - Cant find satellites
Try a re-load of the chipset driver. It is available from the Garmin website. I find that it occasionally becomes corrupt.
You can check by entering the "Main Menu" then "Setup" then "System" then press Menu and choose "Software Version".
If the "GPS SW Version" is 0.00 then a reload of the chipset driver will correct the problem.
Cheers.
Dec 29, 2007 | Garmin GPSMAP 60CSx
Garmin gpsmap 60csx won't acquire satellites
I found the solution that fixed my 60CSx. You need to make sure you have the latest chipset installed on your device. Go to
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00422-00&cID=145&pID=310
and download the chipset type G ver 2.9.
After you have loaded it on your 60CSx, you should be good to go. Just turn it on like you normally do and now you'll see your device retrieving locks w/ the satellites.
Let me know if this helps you out.
Charles
Dec 10, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Garmin MAP 60CSx
try calibrating the compass. make sure the battery type is set to the correct type.
Nov 12, 2007 | Garmin GPSMAP 60CSx
Go to the Garmin Web site's home page, avoid staring to long at the hot chick and click on "On The Trail" .. "Mapping Handhelds" .. scroll down to the second row far right and click on the 60CSx. You will then see the 60CSx page, look to the right and click on "Updates & Dowdloads", on doing so you will now see four downloads to choose from. The one you will need is "GPS Chipset Type G Ver. 2.90 as of Nov 27, 2006" if you follow this you shouldn't have any problems. If however you do i'll keep an eye on this page and try to help, this is my first GPS and also had the same issue.
Sep 17, 2007 | Garmin GPSMAP 60CS GPS Receiver
Not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Jul 24, 2007 | Garmin GPSMAP 60 GPS Receiver
Garmin GPSMAP 60CS GPS Receiver Logo
2,092 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
