Problem with LG Cell Phones
Lg gw300 pc suite download
Cell Phones Logo
1,956 people viewed this problem
  • 0 people are following this problem. Be the first!
More Insights on Fixboard
5 Suggested Solutions Relevant solutions from other related problems that we feel might be a fix.
Author image
my mobile is lg kp 220. i have no pc suit. please help me.
Source: lg kp220 driver and pc suit
  • Was this solution helpful? Yes No
Author image
I had also the same problems that u all have, but i make a way by using Blue-Tooth device & connect the set via the Blootooth adapter, & now can have the Internet access as U all see. Make it & feel it.
Source: pc suite for lg kg195
Author image
Hi, Please download it here : www.brothersoft.com/downloads/mobile-phone-pc-suite.html
Source: WHERE TO DOWNLOAD PC SUITE FOR MY LG GW300 MOBILE
Author image
you can get pc suit for lg kp220 in lgmobiles.com
Source: lg pc suite
Author image
  • amoizp
  • 2 Solutions
  • April 08, 2009
Finally, after spending 2 days on this issue, I am now able to back up my phone book on LG KP220 to my PC!  Hurray!
I have now used the pc sync software on Windows Vista as well as Windows XP (SP3) without any issues.
For Windows XP (SP3): ----------------------------------
After installing the driver, all you need to do is make sure that USBSER.SYS file has the following specs:
Size: 22,768 bytes     Version: 5.0.2195.4858
The newer one (which has the following specs) does not work and needs to be replaced with the older one with above specs.
Size: 26,221 bytes      Version: 5.1.2600.5512
(yes, for some reason, the older version works and newer does not)
For windows vista: -------------------------- When you first connect the phone in COM mode, let vista download the driver from the internet.  Then run PC Sync and viola it'll work!
For both: ------------ For running as a USB flash drive (data mode), you don't need any driver in either o/s. For running as a COM port (phone mode), you need a driver and a software.  The driver I'm using is USBSER.SYS and the software is called "Phone Suite" by MediaTek.  I've also tried a slightly older version of the same software called "PC Sync Manager" and that also works.  Other software should also work, as long as the driver is working correctly!
If you still need any help, drop me a mail at amoizpatgmaildotcom (you know what to do with "at" and "dot")
Source: LG KP220 PC SUITE?
Add your solution
Full Name
Top LG Cell Phones Experts
Chris Hingee
  • Solutions: 32268
  • Level: 3
  • Achievements: 5
Corey Knoettgen
  • Solutions: 8596
  • Level: 3
  • Achievements: 1
Expert Badge
Are you a LG Cell Phone Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More Cell Phones Related Problems
Unsolved Problems:
Loading... Loading...
