Question about Philips GOGEAR SA6045 MP3 Player
Wait for USB Connection Cannot find data file ! File Header : 50 48 30 47 30 32 30 33 30 31 Start Header: 50 48 30 47 30 32 30 33 30 31 End header : 50 48 30 47 30 32 30 33 30 31
2 Suggested Answers
  • 11 Answers
SOURCE: i have mp4 philips GoGear
philips support page
This worked for my Opus player supposed to work for all Opus players.
Tip: if the Device manager asks you to update first, dont, close the dialog and Choose 'Repair' tab. Follow the instructions from there.
You need to connect the player whilst holding the "+" volume key to enter the repair mode
Posted on Feb 20, 2011
Repair damaged pdf
See this theme on non-commercial resource: http://www.filerepairforum.com/forum/adobe/adobe-aa/pdf/417-%E2%80%8Bdamaged-pdf-file-cannot-open
Guide for PDFTK (Freeware)
1)Download Gui for PDFTK from the Paehl website.
2)Double-click the downloaded installer to begin the program's setup.
3)Click "Start," select "All Programs" and click "Gui for PDFTK" to open the program.
4)Click the "..." button next to "PDF file" and locate your corrupt PDF. Click the "..." next to "Target" if you are not happy with the output file name.
5)Click "Repair a PDF." Wait for Gui for PDFTK to confirm repairing is complete.
6)Close Gui for PDFTK. Your repaired PDF will be in the same location as the original PDF unless specified otherwise.
To read more about them pdf repair service online, visit:
https://onlinefilerepair.com
Oct 29, 2014 | Adobe Acrobat 7.0 Professional
Do you have any user manual for front panel usb
http://www.msi.com/product/mb/PM8M-V.html
(MSI PM8M-V H, is version 2.0 )
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc.)
In the drop down list, click on - Manual
Under the subheading - Download, click on the blue -
M7104v1.0.zip
[ This is a Zip file. A Zip file is a file that is compressed, to send easier. The above manual is for the M7104v1.0
It will work for the version 2.0 also.
You need a program to 'Unzip' it. (Decompress)
If WinZip is not working on your computer, go to 7-Zip, and download for free.
If you need guidance in downloading, and unzipping, post back in a Comment ]
There are two USB headers on the motherboard for the Front Panel,
JUSB1 and JUSB2. (Junction USB 1 and Junction USB 2)
Looking along the bottom of the motherboard, FROM the Right going towards the Left;
JFP1 header; (Front Panel main wires)
Header with 4 pins on the Top row, and 5 pins on the Bottom row.
JFP2 header; (Dual color Power On LED, and Speaker)
Header with 4 pins on the Top row, {Speaker}, and 3 pins on the Bottom row.
JUSB2 header.
JUSB1 header.
EACH USB header will support TWO USB ports in the Front Panel.
JUSB1 supports two,
JUSB2 supports two.
For each USB header there are 5 pins across the Top, 4 pins across the Bottom.
The pins are numbered EVEN across the Top, and ODD across the Bottom.
Starting from the LEFT side going across to the RIGHT side;
on the TOP row for JUSB2 and JUSB1;
Pins 2, 4, 6, 8 and 10.
on the BOTTOM row for JUSB1 and JUSB2;
Pins 1, 3, 5, and 7. There is NO pin 9.
A) Pin 2 is VCC
B) Pin 4 is USB1-
C) Pin 6 is USB1+
D) Pin 8 is Ground
E) Pin 10 is USBOC
Pin 10 is N/C -> Not Connected.
It is there, and Pin 9 is not there, to key which way a connector can go on. Only ONE way.
F) Pin 1 is VCC
G) Pin 3 is USB0-
H) Pin 5 is USB0+
I) Pin 7 is Ground
There is NO pin 9.
(The USB technology used is USB 2.0)
http://pinouts.ru/Slots/USB_pinout.shtml
Let's read together,
Under - USB pinout signals;
"USB is a serial bus. It uses 4 shielded wires: two for power (+5v & GND) and two for differential data signals (labeled as D+ and D- in pinout). NRZI (Non Return to Zero Invert) encoding scheme used to send data with a sync field to synchronise the host, and receiver clocks. In USB data cable Data+ and Data- signals are transmitted on a twisted pair. No termination needed. Half-duplex differential signaling helps to combat the effects of electromagnetic noise on longer lines. Contrary to popular belief, D+ and D- operate together; they are not separate simplex connections."
See the USB examples in the link above, where it labels the contact pins?
The MALE connectors are shown on the Left side.
The FEMALE connectors are shown on the Right side.
Your USB ports will be FEMALE, on the Front Panel.
They are also the A style. USB A style. The Top example to the Right.
Just noting the following in case for some reason, the wires coming from those contact pins in the female USB connector, are not color coded correctly;
Even after you have the wires sorted out, as to which contact pins they go to, DOUBLE-check again. Do NOT just go by the color code of the wires.
Why?
You do NOT want to accidentally connect the +5 Volts (VCC), to the Ground!
Explaining further;
You connect the VCC wire, (Red), of the USB port in the Front Panel, to the Ground pin on the USB header on the motherboard.
(Which means the Ground wire of the USB port, (Black), will probably also be connected to the VCC pin, on the USB header of the motherboard)
Zzzzzzap! There goes your front USB ports. Both USB front panel headers on the motherboard, will be DONE!
Make sure!
Going on;
1) VCC or Vcc, goes back relating to Transistor technology.
Just think of it as the Positive, or power wire.
It is.
It is 5 Volts DC.
2) GND is Ground. It's a DC circuit, and you have a Positive, and a Negative, or Ground.
3) USB1-
That is -> Data-
USB0 is for one USB port in the Front Panel.
USB1 is for another USB port in the Front Panel.
[ Each USB header on the motherboard can be connected, to TWO USB ports on the Front Panel.
Therefore for the two JUSB1 and JUSB2, you can connect Four USB ports in the Front Panel ]
Data- on one USB port in the Front Panel, goes to USB0-
Data- on the other USB port in the Front Panel, goes to USB1-
4) Data+
Same thing.
Data+ on one of the USB ports in the Front Panel, goes to USB0+
Data+ on the other USB port in the Front Panel, goes to USB1+
EACH side of JUSB1 and JUSB2, will support one USB port on the Front Panel.
Two sides per JUSB1 and JUSB2 = 4 USB ports on the Front Panel.
For additional questions, or clarification to anything I have stated above, please post in a Comment.
Regards,
joecoolvette
Jul 20, 2012 | MSI Computers & Internet
How do i hook up usb button in intel 845 motherboard
Well, that's a start. You know you have an Intel motherboard in your eMachines, that uses an Intel 845 motherboard chipset.
It is an Intel D845GVSR motherboard.
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
Left-click on the blue -
Intel Desktop Board D845GVSR Product Guide (PDF)
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
(I would advise upgrading to Adobe Reader X { 10 }, however, if you don't have it )
After you click on the above link, it may take up to 30 seconds before the first page comes up. (Took 6 seconds just now. Adobe Reader X, and medium speed DSL connection)
At the top of the PDF file, is the PDF file page number box.
It is to the left of the Down Arrow.
Go to Page 11.
T is the Front Panel USB header.
This is where the USB ports on the front of the computer, (Front Panel) connect to.
Go to Page 31.
E is the Front Panel USB header.
The Front Panel USB header is J9F2.
Observe the numbers next to the pins.
Go to Page 33.
This is the pinout for the Front Panel USB header, using those contact pin numbers.
1, 3, 5, 7, and 9 = one USB port
2, 4, 6, 8, and 10 = one USB port
Notice pins 9 and 10 are not used.
You can connect two USB ports to this header.
The pinout of ANY USB connector, female, or male, is set to a Standard.
This is the standard pinout for USB connectors,
In case you cannot download the Intel D845GVSR motherboard manual;
Looking at the motherboard in it's normal position, installed into the computer case, the USB header is on the Bottom edge of the motherboard.
It is to the immediate Right, of the bottom white PCI slot (PCI 3)
It is to the Left of the motherboard mounting hole.
It is Below the Intel 82801DB, Southbridge chip.
Two rows of pins.
5 across the Top row, 4 across the Bottom row.
STARTING on the Left side, (Towards the white PCI slot), and going towards the Right, the pins on Top are numbered,
Pins 2, 4, 6, 8, and 10
STARTING on the Left side, (Towards the white PCI slot), and going towards the Right, the pins on Bottom are numbered,
Pins 1, 3, 5, and 7
Pins 1, 3, 5, and 7 = One USB connection
Pins 2, 4, 6, and 8 = One USB connection
Pin 9, and Pin 10 are Not used. (N/C. No Connection)
A) Pin 1 is for Power
B) Pin 3 is for D-
The Data, or Signal wire. It is the Negative connection
C) Pin 5 is for D+
The other Data, or Signal wire. It is the Positive connection
D) Pin 7 is for Ground
Going to the other USB header;
A) Pin 2 is for Power
B) Pin 4 is for D-
C) Pin 6 is for D+
D) Pin 8 is for Ground
For additional questions please post in a Comment.
Out of curiosity which eMachines is this?
Regards,
joecoolvette
Nov 24, 2011 | E-Machines eMachines Desktop PC
I keep getting the message The data file 'personal folders' was not closed properly when I open Outlook, how can I prevent this from happening?
The underlying reason why Outlook displays this "data file" check is very simple. There is a single flag in the header of the data file that is a Boolean value (True or False). While you use Outlook the value of this flag is constantly changing as the data file is updated. When the update begins the value is changed to False and then when the update completes the value is changed back to True (implying the update is finished and successful).
So, the key to the problem is the shut down process because once the Outlook.exe process is exited this flag value cannot be changed. If the Outlook.exe process was terminated prematurely or a 3rd party add-in did not properly set the flag value to True then the flag value can be left at False. If you start Outlook with a data file where the value of the flag is False you are guaranteed to see the "data file" check. If the value of the flag is True then you will not see the "data file" check.
Right now, there are a few known common causes for this issue:
- Shutting down Windows before the Outlook.exe process has exited
- 3rd party add-ins improperly "closing" the data file
- Outlook crashing
- Non-Outlook process accessing the data file
http://support.microsoft.com/kb/954642/en-us
http://support.microsoft.com/kb/948733/en-us
Regarding the post advised by Rod, I would like to explain more detailed:
When you shut down Outlook, the Outlook window goes away, but the Outlook.exe process can continue to run for some time. That's why you can see Outlook.exe sitting in Task Manager for a few minutes after closing the Outlook window. If you shut down Windows while the Outlook.exe process is still running Windows will not wait for the Outlook.exe process to exit. So, you increase the likelihood of encountering the "data file check" issue the next time you start Outlook (because the Outlook.exe process was not able to "close" your data file(s) completely before Windows was shut down).
On the other hand, if you leave Outlook running when you shut down Windows the Outlook.exe process will continue to run and exit on its own. When Windows is shut down, it sends messages to all visible window frames telling them to quit, and will wait for those programs to quit before shutting down. Not until all processes with open windows have exited will Windows finally shut down. This is somewhat counter-intuitive to most people as traditional training has always advised manually closing applications before shutting down Windows.
Mar 10, 2011 | Microsoft Computers & Internet
Getting an error message on my Philips Gogear OPUS 16GB player " Wait for usb connection, cannot find the data file!'' Not sure how to rectify this problem! Please help!
Here is a link where you find the user manual of your device:
http://download.p4c.philips.com/files/s/sa5295_02/sa5295_02_dfu_eng.pdf
Read it's content in the page 44. I think it is necessary to update of your player and I hope you can repair it this way.
gylacz
Mar 07, 2011 | Philips GoGear SA5285/37 Digital Media...
I have mp4 philips GoGear Opus wait for USB Cannection Cannot find data file File Header : 50 48 30 47 30 31 30 39 30 30 Start header : FF FF FF FF FF FF FF FF FF End Header : FF FF FF FF FF FF FF...
Oct 26, 2010 | Philips GoGear SA6185/37 Digital Media...
Download videos
Plug the USB data cable into the and connect the opposite end into one of the USB ports on your computer. The computer states it has detected a new device.
Launch the Sony Media Manager program (either double-click the desktop icon or select "Start," "All Programs" and finally "Sony Media Manager"). The program automatically detects the device.
Select the "Videos" tab, and then click-and-drag a video file into the open window from your computer. The video file location on the computer may vary, depending on where you saved the content to.
Wait for the video files to upload to the (the video files automatically begin uploading to the device once you drag the file into the open program window). Do not disconnect the device from the computer while the upload is being performed. If you do, you may corrupt the device. Once the upload has finished, you may close out the program and disconnect the MP3 player from your computer.
Aug 31, 2010 | Sony NWZS716FSNC Digital Media Player
Want to update my sharp blue ray disk player bd-hp21u - does not play current disks
To obtain the software update file, please call 1-800-BE-SHARP (23-74277). Save the update file into a USB drive.
  1. Insert the USB memory device
    with the update file into the BD
    STORAGE/SERVICE terminal on
    rear of this player.
  2. Press SETUP to display the SETUP
    MENU screen.
  3. Press arrow keys to select
    “SETTINGS”, then press ENTER.
  4. Press UP/DOWN keys to select “SOFTWARE
    UPDATE”, then ENTER.
  5. Enter the 4-digit number using 0-9.
  6. Press ENTER to start checking data
    in the USB memory device.
  7. During the data checking,
    “Checking” blinks.
  8. The current version of this unit software
    and the version of the update file on the
    USB memory device are displayed. To
    update this player software with update
    file, select “YES”, and press ENTER.
  9. If the USB memory device is not
    properly installed or the correct update
    file cannot be found on the USB
    memory device, an error message is
    displayed.Check the file on the USB memory
    device, and then reinsert the USB
    memory device correctly.
  10. Press ENTER to start updating.The screen becomes dark for a
    while until the update screen can be
    displayed. Please wait for the update
    screen to appear. Do not unplug the AC
    cord
  11. When the software is successfully
    updated, a screen is displayed
    indicating that the update process is
    completed.If the update has failed, check the file
    in the USB device and try Software
    Update again.
  12. Press POWER to turn off the player.
  13. Remove the USB memory device.
Oct 18, 2009 | Sharp BD-HP21U Blu-Ray Player
Problem with my philips mp4 player
PLEASE FORMAT YOUR PLAYER AND TRY TO REINSTALL THE MUSIC FILES AGAIN, I HOPE YOU WILL GET THE SOLUTION AND PLEASE VISIT THE WEBSITE OF YOUR PRODUCT.
Oct 03, 2009 | Philips GOGEAR SA6045 MP3 Player
Doesn't remember there's a Header Row
You can try to select all data (except for the entire row which contain your header) and try to sort thru columns. This can sorted in ascending or descending order.
Jul 17, 2009 | Microsoft EXCEL 2004 for Mac
Philips GOGEAR SA6045 MP3 Player Logo
350 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
