Question about Canon LaserShot LBP5050N A4 Colour Laser , 9600x600 dpi, 8ppm colour/12ppm mono, LAN, USB Printer
Canon 5050 Colour Laser has Paper Jam and half paper inside what do we do
Open the back cover and pull out the jammed paper
Posted on May 30, 2011
Xerox 2520 copier when machine start some part lose there that, s why sound is coming out & only half paper is come out from output side.what can i do?
first check the paper size of casset detecting properly, if ok, check your fixing unit film...maybe the sound comes from the fixing film
Feb 11, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
Canon laser shot lbp 5050 how to load paper
my canon lbp 2050 Error Code: E197 0001
help my plz
thanx
Jan 27, 2014 | Canon LaserShot LBP5050N A4 Colour Laser ,...
Tells me my printer has a jam but there is none
Hell,
Paper jam errors can also be caused by worn pickup rollers. When the printer tries to print a page and the rollers can not grab a sheet of paper to feed into the printer the printer will think there is a jam and display the same error. Pull out the paper drawer all the way and reach inside the top of the opening and you should find the pickup rollers. They should feed rough not smooth. If they do feel smooth then they will need to be replaced by a Canon repair center.
I hope this helps,
BuddyMc
Nov 30, 2012 | Canon imageRUNNER C1028i Laser...
My canon LBP 5050N printer refuses to print anymore. It says it has a paper jam but I cannot find any paper when I open the rear end of the printer. I have a new iMac and had to download a driver. ...
The canon lbp5050 is the biggest steaming pile of **** we have bought. The only dilemma when trying to fix it is wether to use a 10 pound or 16 pound sledgehammer when smashing the **** out of the usless thing. My advice is DO NO BUY THIS PRINTER
Jul 07, 2011 | Canon LaserShot LBP5050N A4 Colour Laser ,...
Paper jam in front roller of imageclass D880 (about 1/3 inside)
dirty pick up rollers. take the paper tray out and them you will see 2 half moon rollers, clean them with alcaho and you will be ok.
Oct 08, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon mf3110 does not pick up paper
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Aug 22, 2009 | Canon MF3110 All-In-One Laser Printer
Paper jam Brother HL-5050
1. Turn off the printer. 2. Remove any paper trays. Inspect them for wrinkled or damaged paper. 3. Also open the back cover of the printer if this model has one. 4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. 5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it. 6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. 7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside. 8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. 9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path. 10. see alternative if the problem is still not solved. alternative : Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 05, 2009 | Brother HL 5050 Laser Printer
Paper Jam
1-fan the papers many times befor you put in the machine.
2-keep the paper inside its cover in dry place.
3-check for any foreign object droped in paper path(pins-a small pieces of torn paper).
4-check for good condition of paper detecting switches in paper path inside the machine.
Jun 19, 2008 | Canon FAX-L350 Plain Paper Laser
Canon LaserShot LBP5050N A4 Colour Laser , 9600x600 dpi, 8ppm colour/12ppm mono, LAN, USB Printer Logo
752 people viewed this question
old marine
old marine
