Question about Refrigerators
Dometic 3804, relay (on cotrol board) to power gas & igniter sticks. part# to replace relay?
3 Suggested Answers
  • 122 Answers
SOURCE: Dometic RM2562 - No Flame
use a set of needle nose pliers & disconnect the igniter wire the module should start clicking if it does not click check the wires to the board clean them good & reconnect if the module still wont start clicking your board is bad if it does click the igniter adjustment off stick a nickle between the igniter & burner the gap should be the size of the nickle 3/16"
Posted on Jun 07, 2009
VtToolMan
  • 704 Answers
SOURCE: Dometic RM2811 stopped getting cold
Here's a link to a step-by-step troubleshooting guide to help you resolve your issue with your fridge.
http://gasrefrigeration.net/does_not_get_cold.htm
Hope you find this helpful and best regards!
Posted on Aug 08, 2009
jumptrout51
  • 3361 Answers
SOURCE: My Dometic NDR1062 only runs on gas, its set for auto and has 110
There is a control board and a step down transformer that may be at fault.
These should be located in the lower rear of the unit.
Posted on Jul 11, 2010
Single wire igniter that sparks the oven on but flame goes out after a few seconds. Does the igniter control gas valve?
Its the other way around the valve controls the igniter so to speak
GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 23, 2015 | Ovens
Oven ignitor intermittent spark, oven wont light, emits gas.
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
ELECTRIC OVENS:
Mar 13, 2015 | Ovens
Gas dryer checked ignitor, thermal fuse and flame all had continuity still ignitor will not glow or heat
Will try to help you checked the igniter you say good if good does it glow if so clamp on one wire and take an amp draw while heating I like to see a minimum of 3 amps if glowing and 3 and above change the coils on the gas valve very cheap, now if not glowing and good ignitor the fun begins power comes out of the heat relay on the control board passes thru the thermal fuse then thermal cut off then hi limit then the flame sensor while also feeding the gas coils the neutral is supplied thru the centrifugal switch on the tumbler motor if the dryer stays running the centrifugal switch is good and you have a neutral bad flame sensor very rare since I am not there check the thermal cut off once blown it does not reset has to be replaced if all the fused I mentioned check good then check the heat relay on the board black and red wire stick meter ends in both off should read 120 volt when machine turned on should hear it click and meter should read 0 volts the boards seldom go bad but I have replaced a few in 5 years I am leaning more towards an open thermal cutoff
Feb 20, 2015 | Whirlpool Dryers
Gas wall oven wont come up to temp.
ELECTRIC OVENS:
Apr 07, 2014 | Frigidaire FGB24S5A Gas Single Oven
NATURAL GAS OVEN WONT COOK PROPERLY
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
ELECTRIC OVENS:
Apr 06, 2014 | Frigidaire Ovens
Frigidare gas oven wont ignite
ELECTRIC OVENS:
Feb 07, 2014 | Frigidaire Ovens
Light stays on check when on ac on Dometic Fridge
Here's some info regarding the check issue you're experiencing:
Problem. Unit controls go to "check"
There is a common problem with, Dometic RM2807 or RM2811 and most later model Dometics with upper controls. The refrigerator's "check light" comes on or the refrigerator just shuts down seemingly for no reason. Another common problem occurs while on 120v. The refrigerator might switch to gas or just shut down even while you have a good 120v supply.
Answer. Dometic RV refrigerators with the push button upper control boards have a problem with the main power boards. The power board components are encased in yellow epoxy, reducing heat transfer. This tends to cause them to run too hot which in turn can often cause the power board to fail completely or cause problems such as listed above. We have found the only effective repair is to replace the power board. We do not use the Dometic replacement as they too can fail. The Dometic replacement also requires you to rewire the board and gas valve. The only board we recommend is the P-711. The P-711 not only will fix these problems but does not require the rewiring. It uses all the standard wiring. See Power Boards
Jun 27, 2009 | Dometic RM2652 Refrigerator
My dometic will only work a couple of hours on electric then goe to check mode, is this the board
Hope you found this very helpful, best regards!
Jun 15, 2009 | Dometic RM2652 Refrigerator
Dometic 2811 gas/AC refrigerator poor operation on gas mode.
Your gas valve is sticking. Could be a bad thermocouple.
Set it to come on, then with a screwdriver handle or something similar, tap,tap,tap gently on the gas valve to see if it lights.
Once it unsticks it should operate OK.
If it does not unstick, replace the gas valve.
May 26, 2009 | Dometic Refrigerators
May 26, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Gere knutson
