Question about Whirlpool AWM8143 Front Load Washer
Doorlock light comes on after you push start button on any program, and it does nothing else ! it has got worse you used to be able to get half way through a load before the doorlock light would come on and m/c would stop. please help thanks phill.
  • Whirlpool Master
  • 12,061 Answers
It seems your door lock switch is faulty, that or the sensor on the amain PCB is.
http://www.eserviceinfo.com/downloadsm/17628/Whirlpool_AWM8143.html
Your service and repair manual.
http://www.acmehowto.com/howto/appliance/washer/washer.php
Above is a self help DIY troubleshooting and repair tutorials to assist. between this and the manual, you should be able to sort it.
Posted on Aug 04, 2010
Cayenne liftdoor wont open on cayenne 2008s
The latch is broken or jammed for some reason, remove the inner trim panel and manually unlatch the door
Jul 06, 2017 | Cars & Trucks
Kenmore ultra wash dishwasher only half of the lights light up when pressed when press start nothing happens
Do you mean only half of the lights that you push stay on ? If I try to push in too many buttons at the same time, or the cycles I push don't function together, that some of them stay off because they aren't programmed to run at the same time. And the machine is set up to not allow you to expect it to do all the functions during the same cycle.
Jul 19, 2014 | Kenmore 665
Why do my machine flashes red lights when pluged in AC and nothing else works ?
Replace doorlock and mainboard.
If all five spin cycle buttons flash, its a fatal error.
It depens on which wash button that ligths up.
One of them is doorlock error, the other is main board error
May 21, 2014 | Bosch WAE24166GB
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
The climate control on my 2001 jaguar s type does not come on no lights
Overheated??...has nothing to do with no lites on.Check your fuses 1st worse case is fried control panel.heat coming out because climate system inop
Nov 19, 2012 | 2001 Jaguar S-Type
Whirlpool AWO3761
hi we have a whirlpool awo3761/5 when wash is selected it goes to start but then doorlock flashes a nowt happens, i have just replaced with new doorlock this morning and with fingers crossed tryed again it looked promising but doorlock started to flash again and nothing happens pls pls help
Sep 07, 2009 | Whirlpool Washing Machines
04 Escalade w / Valet Starter, all works but door locks
Hello 7suds,
Well, I'd go back and tell them about the doorlock problem. I know that 2 years is a little late to start complaining, but it's most likely a really easy fix.
The most probably causes are that the power doorlock output was either not programmed, programmed incorrectly, or it's not connected or improperly connected to the vehicle servos. Have the installer check the programming, especially the doorlock pulse duration. It's also possible that the remote is simply not sending the doorlock signal. Could just be a bad button. Have them switch the doorlock function to the right "AUX" button temporarily and see if that works. But in any case, the system needs to be tested to find out exactly what is causing the doorlock failure.
Hope this helps.
Jul 16, 2009 | Directed Dei Valet 561r Remote...
Losing all electrical on my 1999 Jimmy
Could be a defective pcm (computer)  also bad grounds can wreak havoc on electrical systems check engine light on before this happened??
Jan 30, 2009 | 1999 GMC Jimmy
When I push in the program little hole, a red light used to come on .
There is possibly some soda or something sticky blocking the connection. Put some 91% alcohol on a q-tip and work it around the button to break up any sticky food stuffs.
9 out of 10 button problems I see is due to Soda,Tea,Candy,Baby Saliva.
Apr 30, 2008 | Televison & Video
Whirlpool AWM8143 Front Load Washer Logo
78 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
