X axis error comes on the computer screen which is connected to the investronica p2000/1 plotter.
When does it happen?
When you load Plotwin and try to move the head to the physical origin of the plotter or when you launch the job.
These plotters have a lot of problems with carriage and belt so it's hard to give a useful suggestion.
Posted on Aug 31, 2010
Persistent Error 86:01
Oh my throw it away, too much you have tinkered with its not worth the headache
Sep 01, 2014 | HP Designjet Z6100 InkJet Printer
Hp designjet 9000s system error 1701
The Paper-Axis or the Scan-Axis Motor moves the Carriage, but the input from
the Linear Encoder Sensor does not change.
You are going to need a tech to check out the plotter.
Dec 11, 2013 | HP DesignJet 9000 InkJet Printer
SEVER EROR 0X9010001
Was the error preceded by 81:01 or 81:11? That is the format for the actual error on a 500 series plotter.
If so then you have a Paper-Axis shutdown.
Corrective Action: If this error code appeared but was NOT caused by a paper jam, then try the following:
Carriage Belt if it is frayed or worn out, if it is good then
Replace the Encoder Disk Assembly.
Sep 22, 2013 | HP DesignJet 500ps InkJet Printer
Error 47:01 in hp plotter t1100
Indicating "Star Wheel Motor" error, Perform the Scan Axis Starwheel diagnostic test,Entering in Service menu: hold the Up arrow key and the OK key down andswitch the printer ON using the front power switch. Wait until the LED of thepower switch stops flashing (usually after 5 seconds) before releasing ALL Diagnostics menu,go to scan axis, enter,go to star wheel lifter,press OK.. complete the mode..if fails remove star wheel are clean all gears refix again, do the diagnostic again..if you have manual that better to process the things.. Best of luck
Sep 27, 2011 | HP Designjet T1100ps Printer
86:01 error in designjet 500 plus Paper jam...
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
Corrective Action:
  • Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
  • The Carriage is bumping into the Service Station. If the carriage is stuck at the right hand side of the Printer and cannot be moved out to the center of the Print Platen it is because the Service Station cannot uncap the Printheads. In this case replace the Service Station/Aerosol Fan Assembly
  • Perform the Carriage Movement test
Aug 26, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
Hp plotter 500ps problem by when given the command affter than plotter show on display system error 81:01. pls give to soluction.
Have you solved this problem, as I post it's 3 months old. This is a serios problem and refers to paper axis shut down.
Jun 08, 2011 | HP DesignJet 500ps InkJet Printer
87:10 error in HP plotter 1110
There is a problem finding the Scan-Axis encoder reading.
1st thing to do is upgrade the firmware (www.hp.com)
Try cleaning the Encoder Strip.
If that fails the encoder strip will have to be replaced.
Mar 03, 2011 | HP Designjet T1100ps Printer
Need to change Y-axis belt on 650C Plotter. I
Try www.smpcshop.com they have many service manuals, from $9.95 to $19.95 to download.
Nov 27, 2009 | Office Equipment & Supplies
Error code showing on my HP 1050c plotter
The error stands for : 24V source test failure.
And i'm sorry to say but the service manual then tells you to try the following:
- Replace the scan-axis motor assembly.
- Replace the paper-axis motor assembly.
- Replace the service station assembly.
- Replace the main pca.
- Replace the ISS pca.
- Replace the power supply unit.
- Replace the electronics module.
(only replace one component at a time)
Yeah then you have to guess which part to start with.
Maybe anybody else on this forum knows more about the error and has a better idee about the part you should start with.
Just take a good look at the machine, and check which sections of the start up works before the error is prompted.
e.g. If the carriage moves then you could say that the scan-axis motor is probably ok.
Good luck....
Sep 07, 2009 | HP DesignJet 1050c plus InkJet Printer
187 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
