Question about Car Audio & Video
Back of headunit is getting very warm is this normal
  • 1,498 Answers
Warm is normal.
Very warm? not so much.
If it is hot to the touch, that is abnormal.
If you believe it is warmer than it should be, a small fan to help circulate air could be the solution.
The fans from an old computer power supply run on 12VDC and could be easily attached to the receiver.
Best regards
Posted on Aug 04, 2010
Headunit help
Try googling.. 1245xm alpine iphone 5c app
Apr 11, 2014 | Car Audio & Video
Remote wire?
The remote wire on the jvc unit is blue/white stripe if that isn't there it's the blue wire
Apr 08, 2009 | JVC KW-AVX800 CD Player
No Power coming to head unit..
u need to connet the pioneer black wire to the car direct .
Mar 26, 2009 | Pioneer DEH-P3800MP CD Player
How to remove Panasonic cq-c1301u unit from car
This is an interesting question. As to the fact that you didn't mention what kind of car you have, I can't give you exact instructions, but I can give you approximate instructions. Read all Instructions b4 you do anything and detach battery b4 working on system!!!!!!
1. Most car's require you to remove a dashboard panel, of not the whole thing. (on a side note, the panel on my jeep that has to be removed just pops out).
2. Next you need to unscrew the adapter kit from the car. A lot of older cars put Double DIN headunits into their cars, These are the larger sized headunits. Most after-market systems require a plastic adapter to allow them to fit into the larger space. As long as your new unit is the same size as the older unit, this piece can be reused.
3. Then you must remove the old headunit from the adapter. Most are either screwed in or have pressure pins that hold it in place. Either unscrew or carefully push down the pressure pins until you can remove the old headunit.
4. If you have already purchased the wiring kit, if necessary, then continue onto next step, otherwise purchase appropriate wiring kit for your headunit and car. Do not open wiring kit until you are ready to hook up your new headunit!!!!
5. Find new wiring kit, detach old wiring kit, and hook up new wiring kit according to included instructions. For best reliability, I recommend using wire nuts as electrical tape isn't as relaible and can come apart after a while. If you need to save space and can't use wire nuts, I recommend liquid electrical tape. Let this dry before you go any further.
6. Attach new headunit to adapter and then attach wiring kit to back of the headunit. Make sure to attach radio cord to back of headunit. Push adapter and headunit back into place, adjusting wires as necessary. Screw adapter back into place.
7. Re-attach dash panel back to car, reattaching screws where and if necessary and reattach battery. Power up car and test system.
8. Listen away.
If you cannot get this to work, most places like Best Buys and Circuit City have professionals that have the necessary parts and expertise to exchange headunits in cars and can do this for a small fee. Just replacing a headunit should be relatively cheep. Adding other components as well would be more expensive.
Mar 25, 2009 | Panasonic CQ-C1303U CD Player
I have the panasonic cq-c8303u radio and i would like to hook up the ipod to it. any tips?
You need to get the Direct Cable for iPod® (CA-DC300U) from panasonic. This allows you to plug in and control your ipod from your headunit. There is also the expansion module (CY-EM100U), however I am not sure if this is necessary if you have the Direct Cable. The Direct Cable might plug directly into the back of the headunit without the need for the expansion module. Check with the company before purchasing one or both. If the direct cable requires the expansion module, then get both, however, I think the direct cable works independent from the expansion module. Again, contact the company about this. The expansion module also lets you plug your ipod as well as other devices into your headunit, however I don't think it allows you to control them via the unit. I think if you want to control the ipod from your headunit, you just need the Direct Cable for Ipod®.
Mar 23, 2009 | Panasonic CQ-C8303U CD Player
Mercedes ML320 CD Changer Malfunction
I can help for you. I'am live in London. Contact e-mail address: info@headunit-repair.co.uk or visit my site : www.headunit-repair.co.uk
Oct 17, 2008 | 2000 Mercedes-Benz M-Class
Amp hook 2008 Tundra
I'm afraid you must go to the back of the headunit... your only other option would be to catch the wires in the door sill going towards the back, or catch them in the kick panels going towards the front doors. This will prove to be much much harder than just removing the headunit.
Mar 30, 2008 | Stingpro ST444 1850 Watts Complete...
Faceplate
Mine did the same thing, send the whole thing back.
Nov 25, 2007 | Phase Linear UMP8015 CD Player/Receiver...
Faceplate not responding / acting very weirdly
Sounds like a bad connection with the faceplate and the multi connector that the faceplate mates with when closed. check for dirt and bent pins on both connectors. Luck
Dec 14, 2006 | Sony CDX-CA900X CD Player
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
