Question about Dishwashers
Kindly give me the meaning of error C8 on Zanussi dishwasher, Mod LS 10-14, and list of error codes and it's meaning. Thanks. Lee
5 Suggested Answers
SOURCE: Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Posted on Sep 06, 2009
  • 7 Answers
SOURCE: Zanussi LS 14
for remove C8 error on zanussi LS14 you must press on/off and press cycle2 key and you get FAC press cycle2 key again 8 times and you get CFG enter on family of this paremeter pressing ifinity key go to parameter ALR and you get ALR= 1 change to ALR=0 AND FIX THE PROBLEM.
Posted on Jan 28, 2011
  • 10 Answers
SOURCE: Electrolux dishwasher error c8 What does this
C8 means that at the rinse phase the boiler did not empty.
The reasons are ..
1) the nozzles are blockled
2)Drain pump out of order
3) bad luck
now you must reset c8 from the parameter in order to start again the diswasher
kostas
Posted on Feb 11, 2011
SOURCE: SE error code on Samsung dishwasher
5E code. If your dishwasher has been running fine for awhile then throws a 5E code chances are it could be the pump or a blocked hose or filter but chances are its not. 1. Does the code come on after it has gone through the wash cycle and released the soap dispenser? or 2. Does the code show afer 1 or 10 minutes of running without the wash cycle completing, soap dispenser still closed?
Number 1 is easy to check just diconnect the drain hose and run the hose into a bucket to see if the hose or filter is clogged or pump is working. These machines only use about 2 gallons of water and the pressure is very low its easy to do in a bucket. If number 2 occurs, its not a clogged hose or filter or pump issue the machine is not even cycling.
If number 1 checks out ok you have water flow but shuts down and number 2 has occured, its your Case Level Sensor its the electronic solid state float, DD94-01006A its either sticking due to water impurities or its bad.
Its actually pretty easy to trouble shoot or fix. You have two choices but the machine has to come out. The sensor is located behind a metal plate on the lower left side ofthe machine. You can;t miss it it looks like a float, has a black float inside a clear plastic housing and some wires going to it. You can pull it out and clean it (The float should go up and down with no sticking at all). Or just buy a new one $35.00ish and put in. Also check the inlet hose to the float make sure its clear and clean DD67-0057A.
There is one catch to this that can cause lots of grief if ANY water at all comes out of the float while changing it. If any water gets in the bottom of the catch basin underneath, the very very sentive probes will detct it and throw a LE code and the washer will not work. that is not a big deal just need to pull the basin off and dry it out. The smallest amount of water can cause the sensors to react since its a protection system.
Samsung dishwashers are very quite and wash extremely well but there technology and engineering sucks along with their warrenty and repair manuals there are no manuals for the home owner or much for the repair guy.
That float will have problems again and again and again either its dirty or broken and will cause another 5E code situation.
Side note; food grinders in a dishasher are stupid! All dishes places in a dishwasher should be rinsed! A domestic dishwasher should not be used as a disposal. It makes your house stink and tons of bad bacteriea will grow in places you do not want it to, not to mention they are not made to work like you would think.
Best dishwasher with the least trouble, easy to fix, easy to dignose, easy to work on, good manuals, few problems, good warrenty, best built, quite running, washes great, very well engineered is BOSCH.
Terry
Posted on Dec 21, 2012
Dishwasher electrolux wt30 error code c8
Hello Said Raji - Are you certain the error code is C8? Could it possibly be CE? If so, it typically indicates that the dishwasher has detected a configuration error. A professional will need to check the wiring connections between keypad and main control board.
Jan 16, 2013 | Electrolux WT30H240DU Dishwasher
Zanussi dishwasher LS9 AD/G1 reading code C8 and not working
C8 - During rinse phase boiler doesn't empty:
  • Rinse pump not efficient.
  • Rinse arms obstructed.
  • Boiler level sensor out of order.
Dado
Jun 25, 2012 | Zanussi 29 in. LS14 Free-standing...
Electrolux wt55 error code c8
If there is a set button hold it for 5 seconds.
The reasons are ..
now you must reset c8 from the parameter in order to start again the dishwasher
May 05, 2011 | Dishwashers
Warning C 08 how to reset?
Hold down on/off and prog 2 for 5 sec.
display ``fac``
Press prog 2 until display ``ron``
Press prog 3 until ``c8 / 1 or c8/3.``
Press prog 1 until ``c8/0``
Press prog 3 until ``ron ``
switch off -switch on and o.k.
General
C8 caused from glogged jets or rinse pump problem or bad luck.
If there is a problem at the dishwasher then c8 will appear again
Hope I helped you
kostas
Jan 26, 2011 | Zanussi 24 in. LS6E Free-standing...
Electrolux dishwasher error c8 What does this mean please??
The reasons are ..
3) bad luck
kostas
Nov 08, 2010 | Electrolux 504199 Dishwasher
New Richmond tankless water heater C8 error
I think error code C8 is #13
It has to do with air quality, lack of sufficient air, or lack of venting or dirty air filter.
Check following links to see if they have information:
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Manual shows error 05 or 13:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Sep 01, 2009 | Rheem Tankless Hot Water Heater...
Zanussi LS 14
Feb 28, 2009 | Zanussi 29 in. LS14 Free-standing...
Zanussi ZSF 6161 Dishwasher error codes
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Dishwashers Logo
167 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
