Question about HP Pavilion dv6000z Notebook
Computer will not start up on power up. Computer does a system check with all L.E.D. lights, cooling fan starts, empty cd drive bay does a system check. The computer hard drive will not start and the screen is completly dark with no flicker at all. No stuck bottons, hard drive and memory sticks appear tight. Power cord supply good, battery good. He HP Pavillion dv6000 Computers then cycles on and off indefently.
  • HP Master
  • 2,719 Answers
Notebooks, battery out first, just take it out the leds mean zero.
there is no LED that can tell you a battery is ok,
did you?
if that fails.
next is what, BIOS
get the BIOS screens up. (my guess its DEAD) not even text or HP logo.
if not the pull hdd,dvd and all ram but 1 stick.
and all usb jacks empty , unload it.
fails now. then the Power pack is bad
you do know packs can be, good, bad or weak right
19vdc is good, 10 not.
see?
the GOAL on ALL PC's get BIOS UP.
take no hdd , no dvd to do that. ever
once it works we can move to booting any OS>
we can boot to 5 things on my laptop, even SD,mem.
try to think this way
if the Power pack is 65w+ and 19v
then remove all possible shorted devices from the PC.
strip it down. if it runs now, (means BIOS wakes up an screen)
test 2 on all LT
is the rear VGA jack will run a external screen if the internal is suspected.
black screens only can be CCFL dead.
if it has that.
i cant hear you hdd spin/
nor see the eject work work on the dvd
if the PC self shuts off, that means the power supply has issues
the Power pack bad , the MOBO regulators are in overload
and shut it down (called shorts on devices)
this is normal action on any regulator..... normal for shorts./
Posted on Jul 20, 2017
  • 230 Answers
SOURCE: HP Pavillion dv6000 - dark screen, no power noise, but power lights are on
Sounds like laptop over heat. Keep it off and turn it back on after it has cool down. Another things to check is your memory. Sometimes memory not secure to it "teeth" will cause this problem (like in my Toshiba).
Posted on May 06, 2008
  • 398 Answers
SOURCE: HP pavillion DV6000's battery charger beep sound
try buying a new battery
Posted on Mar 07, 2009
SOURCE: HP Pavillion Entertainment PC screen blank, power lights on
try this put off the laptop and remove the battery and the power cable and then hold the power button from 30-60 seconds then put back the power cable(without battery) and switch it on it should work then shutdown and put battery pack in
Posted on May 10, 2009
SOURCE: black screen when I try to start up
lljlj,mlmlm
Posted on Jul 22, 2009
  • 109 Answers
SOURCE: HP zd8000 will not charge battery or run on power cord
check the dc jack probably is loose that cause the batterie dont get charge
Posted on Aug 13, 2009
How to build a or assemble a computer and troubleshoot?
Building a computer will require: a motherboard, a processor, memory, a video card or motherboard with onboard video, a sound card or motherboard with onboard sound, at least one hard drive, a CD or DVD drive, a case for the computer components, a power supply, fans to cool the computer, an operating system, a monitor, speakers, keyboard, mouse, 2-3 hours to assemble the computer.
You must ensure that all of the components are compatible with one another. After receiving the parts, lay everything out on a large, clean surface. Make sure you are grounded by touching a metal surface; this will prevent the transfer of static electricity to your computer components.
Typically, the steps to install the components are as follows: 1. mount the power supply in the case, 2. mount the motherboard 3. lock the processor in the socket on the motherboard 4. insert the memory sticks into the slots on the motherboard 5. mount the processor fan on the processor 6. insert the video card into the applicable slot on the motherboard 7. insert the hard drive into a hard drive bay in the case, 8. insert the CD drive into a CD drive bay, 9. mount any fans you have to the fan cutouts on the case 10. connect all applicable data cables to the CD and hard drives 11. connect all applicable power cables to the motherboard, video card, processor, hard drive, CD drive, and any other components. 12. connect the front panel USB, power, lights, and reset connectors to the motherboard 13. close the case 14. connect the power, monitor, speakers, keyboard, and mouse to the computer
Because this process is rather involved, I recommend following a guide such as this one: http://www.maximumpc.com/article/how-tos/how-_build_silent_gaming_pc
It details the process, includes pictures, and even provides a list of compatible parts.
Jun 19, 2011 | Computers & Internet
Tip
How to Troubleshoot a Computer That Won't Start
<span>Instructions</span> Things You'll Need: <ul> <li> <span>A Startup Disk Or A CDROM With The Operating System On It</span> </li></ul> <ol> <li> If your desktop computer does nothing at all when you try to start it, first check that the power cable is securely plugged in at the back of the computer as well as into a working power outlet. It's amazing how often this is the case.<br /> </li> <li> If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.<br /> </li> <li> If the computer is plugged into a surge protector, see if the surge protector has a reset switch that you can push. (If it doesn't have a reset switch and the problem is with the surge protector, it will need to be replaced.) Try plugging a lamp or other device into one of the surge protector's outlets to make sure it's working.<br /> </li> <li> If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.<br /> </li> <li> If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.<br /> </li> <li> If the operating system still won't start even though the computer and monitor have power, try restarting with a Windows CD-ROM in the CD-ROM drive or, if you've got a Macintosh, with a Mac OS disc in the CD-ROM drive. (You can start a Mac from the CDROM drive by holding down the C key while starting up.)<br /> </li> <li> If the operating system then starts, your problem is probably with the startup hard drive or with the operating system installed on it. If you can't fix the drive, you'll have to replace it.<br /></li></ol>
on Dec 24, 2010 | Computers & Internet
Power supply compitable for cac-to5-uw?
ATX is a standard.
Any case described as ATX should accept any ATX powers supply.
The only thing you need to decide is how many watts the power supply needs to provide.
To find this out, put "Computer power supply calculator" into Google.
Pick one, or several, and enter the details of what you are going to put in the case.
Enter what you would like to put in the case finally, not just the bits you have to start with.
Like that second internal hard drive, and double the memory, Two DVD drives.
Extra cooling fans?
Then pick a pick a power supply that provides more than that.
No-one has ever run into problems with a power supply running too cool.
Feb 10, 2011 | Cooler Master Elite ATX Midi Tower Case...
Green light on power supply flashes rapidly when I plug the computer in. Computer will not power up at all (no cooling fans start, no lights illuminate and no beeps come from the unit). When the power...
if the cooling fan on your PSU power supply unit does'nt spin when you start your PSU is faulty if it does then
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 21, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
CPU Fan sounds like a jet and computer won't start
It sounds more like the hard drive, the fan has nothing to do with your computer booting up. If the hard drive is starting to go bad it will not boot up, that's what it sounds like your computer is doing. I recommend checking out the hard drive and replacing it.
Jul 02, 2010 | Dell (Fan Only) M/N AFC0912DE, DC12V,...
My Samsung monitor 244T blinked several times and went black. A few days later I rebooted my computer and it blinked twice and went black. Now power light doesn't even go on. Help!
1).check your monitor cable and power cable.search google for how to check if you do not know...
2).change your RAM into another slot and check if u have 2 RAM interchange it and check..i prefer this must be the RAM problem..
normally when u insert any new RAM..sometimes it does not matches.. in this way the blinking can be happened...
3).disconnect all the cables of CD drive and DVD drive and any other except harddisk cables...and start the system with harddisk and without connecting the CD and DVD drive..
4).clean your processor cooling fan..search google for cleaning cooling fan..this makes the processor to reduce heat or apply cool paste to processor..
let me know that your computer monitor works fine with the above steps...."rate"
Feb 02, 2010 | Samsung SyncMaster 244T Monitor
Iomega media drive cooling fan
You can try cleaning and oiling (light oil, like 3 in one)the bearings on the fan but it usualy doesn't work. YOu can obtain replacment fans from : Match diameter of fan .You can measure it withb a ruler.
Newegg.com  Tiger.com   E-bay.com and ever other computer parts place.
Jan 12, 2009 | Iomega (32691) Case Cooling Fan
View cd
Go to the start button (xp), start orb (vista) ....select My Computer (xp) or Computer (vista). Right click the CD/DVD drive and select Explore.
A window will then open showing the contents of the CD.
Dec 12, 2008 | Toshiba Satellite 1715XCDS Cooling Fan...
Computer powers off during boot
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
Oct 26, 2007 | ASUS A8N-E Motherboard
Pc is not starting up
I'm sorry to tell you but your cpu has probably fried. Your pc hanging a lot probably meant something was overheating and the fact that you say your cpu is not hot when you have the cooling fan off of it means it is probably the cpu. When you first turn your system on without a cpu cooling fan, the cpu should be slightly warm, although I do not recommended running a cpu at all without a cooling fan or even touching it when it has power.
Aug 18, 2007 | Intel Pentium 4 1.7G, 1.7 GHz...
HP Pavilion dv6000z Notebook Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
