Question about Rinnai Heating & Cooling
I HAVE A RINNAI CONVECTOR 400 GAS HEATER AND WHEN YOU START IT, IT LIGHTS OKAY BUT THEN A FEW SECONDS AFTER IT GOES OUT AND "BEEPS". IT DOESN'T SEEM TO MATTER IF THE GAS SETTING IS ON HIGH, MEDIUM OR LOW. AFTER ABOUT 10-15 ATTEMPTS IT SEEMS TO "WARM UP" ENOUGH AND RUNS FINE.I DON'T HAVE A MANUAL AS I BOUGHT IT SECONG HAND AND IT IS 3 YEARS OLD. THANKS TRACEY
    Guru:
  • 825 Answers
The relay circuit is the problem... replacin it will fix the problem for sure...
Posted on Aug 04, 2010
506 convector rinnai
if the flame does not start at all, so just ticking from the ignitor you have a main valve problem and this is expensive replacement part and it must be done by a trained gas fitter.
May 21, 2014 | Heating & Cooling
How can I clean inside a rinnai convector 417 gas heater
http://rinnai.co.nz/tradesmart/upload/files/productfile/portable_convector_rce417_operation_and_installation.pdf
Beside cleaning the filters with a vacuum, There are no instructions on how to clean the inside of the heater. The back and front panels would need to be removed. Unless you are confident to remove the panels, just blow it out as you ahve done and make sure the filters are clean.
May 03, 2014 | Heating & Cooling
How to turn off the chid lock on a rinnai
The button to the left of the economy mode is the child lock button. Push it in and hold for one second to either activate or de-activate.
Jul 26, 2010 | Rinnai Desa Vent-Free Infrared Gas Heater:...
How to turn off lock button on gas heater
hold it for a few seconds till the light goes out
Jun 21, 2009 | Rinnai Heating & Cooling
Need to convert rinnai convector 417 gas heater from propane to natural gas, are the nozzles available?
Rinnai New zealand conversion kit number, R1852.
VERY complicated - get a qualified gasfitter to do it.
Jun 10, 2009 | Rinnai Vent Free Gas Heater/
Child lock
Press and hold down on the lock button and wait for a beep.
Aug 07, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Rinnai Convector 406TR
press and hold the child lock button until it beeps...
Jul 02, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Hi - I have a Rinnai Convector 406 gas heater which is 2 years old. Yesterday, it started cutting out with an error code of "12" showing in the display. It can be re-started but only stays on for a few...
I believe the 12 is the error code for "incomplete combustion". In this case you will want to start with the thermocouple. If you are not handy at these things I would call a service tech. You can find a service person on their website.
http://www.rinnai.us/
Jun 15, 2008 | Rinnai Heating & Cooling
Rinnai Convector 404
Hi pinkinfinite,
The 404 is a great heater. I am assuming it is a Natural Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this.
To clean it out internally you only need to remove the front panelling. There are two screws holding the top panel (not to be confused with the side and top). The screws are located inside the bottom grill at the front. There are also screws for the bottom grill there which you will also need to remove and probably best to remove the bottom panel that house the front feet. It should expose all the inside workings of the heater except for the pilot light and jets etc. You should be able to see the fan - it is round and looks like a filter and sits behind the vent section. Make sure you give it a good blow out - it gets all dirt and dust around it. When you do it remove both the rear filters/covers. They are mesh. Blow the top one which is the larger metal one and make sure you blow inside where it fits over to remove the dust and dirt. Same with the other one which should be plastic with mesh. Once you do this put it all back together. Make sure all wires are connected and be wary with the compressed air as it may blow the connectors off from loose fitting parts. Once you get it all back together Test it and hopefully it should work. Hope this helps. I did one the same today that was having trouble starting and it now works like a new one.
Regards
Bryan
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
184 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
