Question about Philips Electronics - Others
Philips dvdr 1500 appear line TV turn on ? I can't turn off and open disc CD.
jaffa012001
  • 376 Answers
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Posted on Aug 12, 2008
SOURCE: connect philips dvdr80 to intigrated freeview tv
Solved the problem by connecting the freeview box back into the dvd recorder. Apparently because the dvdr was made before tvs with integrated freeview, it can only recieve decoded signals from a freeview box, ie analog
Posted on Jan 17, 2009
  • 181 Answers
SOURCE: Have a DVDR 3460 / 97 model of Philips . Have
There are a number of different RW DVDs out there and your problem could be one of the following:-
That you are not following the instructions
That the discs you arer using are not the correct ones(usually they have a leter or a number on the disc that marks the diference between diferent discs from different manufacturers) I would suggest buying the Phillips discs then that cancels that problem.
That the leads you are using are incorrect or faulty.
OR lastly
A fault on the machine.
The last option is that you physically go to either where you bought it or the philipps centre and ask them to show you how to do it. You paid for it so you deserve the service.
Posted on Feb 12, 2010
SOURCE: Philips dvdr 3480 disc draw refuses to open
Illustration:
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
Posted on Mar 23, 2010
  • 567 Answers
SOURCE: Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Posted on May 07, 2010
Dvdr 3330h firmwareupdate data disc
http://forum.videohelp.com/threads/283983-Philips-DVDR-3330H-recording-codec
Dec 05, 2013 | Philips DVDR3330H DVD Player/HDD Recorder
Dvdr philips tray open
its a tray track or belt problem plz contact your Philips service center
Sep 08, 2011 | Philips Audio Players & Recorders
HI, we have a Phillips DVDR 3320V and we cannot get it to open the draw and release the disc that is in it?..the disc has pictures on ith that we have copied from our laptop and wanted to view them on the...
No you haven't done anything wrong this is a common problem.You need to open the case and manually remove the disc, they sometimes get stuck inside.
May 09, 2011 | Philips Televison & Video
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
Illustration:
Future outlook:
Jul 26, 2009 | Philips Televison & Video
PHILIPS DVDR 75/17 error code C003 TRAY BLOCKED
jim, try to open the tray manually open the cover rotate the motor or the belt manually.
Dec 13, 2008 | Philips DVDR755/17 Burner
Philips dvdr880
The DVDR880 displays "IS TV ON?" when it is in factory mode. You need to switch the TV to the DVDR input, as the on-screen instructions will tell you how to proceed.
Download the manual here:
https://www.p4c.philips.com/files/d/dvdr880_051/dvdr880_051_dfu_eng.pdf
Jun 28, 2008 | Philips DVDR80 DVD Recorder
Unlock codes for philips dvdr 3510
Make sure no disc is loaded
Press on the RC:
0 0 8 6 0 0 0
Done!
May 23, 2008 | Televison & Video
I have a philips dvdr 3450h and require a replacement dvdr drive it only plays cds now
it plays cd music ok unit functions h/d ect but no dvd and inside the drive clicks as though its searching when disc inserted if any help? kbg08mcr
Apr 15, 2008 | Televison & Video
Electronics - Others Logo
44 people viewed this question
Top Philips Electronics - Others Experts
Bill Boyd
Tom Chichester
Are you a Philips Electronics - Other Expert? Answer questions, earn points and help others
