Question about Altec Lansing BackBeat Plus Mobile Headset
Can't pair BackBeat 906 with windows 7, kindly help
4 Suggested Answers
SOURCE: Backbeat 903 headphones won't pair with Windows 7 64-bit laptop
I had the same problem as you although I was able to find a solution. If your bluetooth adapter on your computer doesn't support A2DP then you can purchase this adapter from IO Gear: http://www.iogear.com/product/GBU421/ or another adapter that supports this feature. Windows will try to install it as a generic bluetooth adapter (which wont allow you to pair the headset) but if you install the disk that comes with this, it will also install the additional drivers needed for the headset.
Walmart carries it for $20 at most stores or $13 online. I got mine at the store.
http://www.walmart.com/ip/IoGear-Bluetooth-2.0-USB-Micro-Adapter/10299060
If you need help installing it let me know I can provide the steps I did.
TJB
Posted on Aug 06, 2011
HDI Headsets
  • 537 Answers
SOURCE: do you have different kinds of earbuds for the
Here is a link to the type of earbuds that are available for the Backbeat 903.
Plantronics Earbuds for Backbeat 903
Good luck from Headsets Direct!
Posted on Oct 26, 2011
HDI Headsets
  • 537 Answers
SOURCE: Plantronics Backbeat 906: do they
I would not recommend this headset for using on stage, granted it is made to listen to music and answer your phone, but it is not meant as an on-stage microphone with IEM.
Posted on Dec 19, 2011
When i listen to my music from my phone with my backbeat 903, the music skips like a sratched cd. why is this?
Here are a few things you can try to see if they will improve the quality of the sound:
You should always make sure that your mobile phone is located on the left side of your body and that there are no obstructions between it and your headphones.
Also make sure that your headphones are within 33 feet (10 meters) of your mobile phone. Going outside of this range can impact audio quality.
You can also try resetting the headsets and see if that will help.
While plugging in the AC charger, hold the power/pair button.The headphones will show a solid red or blue light when they have been successfully reset.
Below is a link to the Backbeat 903-906 User's Guide, which may give you some more suggestions.
Plantronics Backbeat 903-906 User's Guide
Oct 03, 2011 | Plantronics Backbeat 903 Bluetooth...
MPlantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset red light flashing problems
The red flashing indicates a low (or check) battery. The instructions on page 4 in the link below for the Plantronics Backbeat 903/906 will show you how to charge it up. On page 8 you'll see how to power down and then up the headset to reset it.
Plantronics Backbeat 903/906 User's Guide
Aug 02, 2011 | Plantronics Backbeat 903 Bluetooth...
I cant sink with my iphone 4?
Once you make your iPhone discoverable, then put the Plantronics Backbeat 903 into pairing mode. With the headphones powered off, press and hold the Power / Pairing button until the LED Indicator flashes blue and red. Here is the link below for the Backbeat 903 user guide that has the pairing instructions as well.
Plantronics Backbeat 903 User's Guide
Jul 26, 2011 | Plantronics Backbeat 903 Bluetooth...
Plantronics Backbeat 906: do they have a music delay when connected to the adaptor via BT? as i want to use them as wireless IEM on stage!
Mar 30, 2011 | Plantronics Backbeat 903 Bluetooth...
I go to set up my wireless headset with my playstation 3 but it won't pick up any devices.
You must put both the PS3 and the Backbeat into pairing mode. See your instruction manual for the PS3 for pairing. Once you have both devices searching for each other they should pair right up.
Instructions for putting the Backbeat 903 in pairing mode:
With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
Use the PS3's menu to search for the Bluetooth headphones and select 9xxBackBeat.
If prompted, enter 0000 for the PIN code/passkey.
Here is a link for the User's Guide:
Plantronics Backbeat User's Guide
Mar 23, 2011 | Plantronics Backbeat 903 Bluetooth...
I am not able to connect the headset and my BB
Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete any pairing information for your BackBeat 903 headset and pair it again with your phone, carefully following the instructions on the link below for the Plantronics BackBeat 903.
Plantronics BackBeat 903 User's Guide
Mar 12, 2011 | Plantronics Backbeat 903 Bluetooth...
I just purchased Plantronics BackBeat 906 and am receiving sound only from one earpiece. Is there a setting that I am not aware of that could be causing this problem?
I would try the reset option listed in Plantronics user guide. Here are the steps for the reset and I will include the link to the user guide also.
Instructions to Perform a system reset:
While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Jan 28, 2011 | Plantronics Backbeat 903 Bluetooth...
My backbeat is paired and working with my sprint evo. but the music will not play at all through the headset? calls are fine but no stereo music . it was working fine before i got a jawbone and paired it...
I wonder if Adroid has some issues with its A2DP stack. You see, I have 3 different stereo headsets paired with my WM6.1 phone, and all of them (one at a time, of course) stream music without any flaws.
Anyway, you could try to delete the Backbeat from the list of paired devices on your phone, and, then, pair them again.
Just my 2 cents...
Hope you are able to sort your problems out soon.
Regards, Carlos
Oct 12, 2010 | Plantronics Backbeat 903 Bluetooth...
TJB
Jan 28, 2010 | Altec Lansing BackBeat Plus Mobile ...
Altec Lansing BackBeat Plus Mobile  Headset Logo
398 people viewed this question
Top Altec Lansing Radio Communications Experts
Michial Gueffroy
Jose Ma DM.
Jose Ma DM.
Are you an Altec Lansing Radio Communication Expert? Answer questions, earn points and help others
