Question about Panasonic Televison & Video
Hi good morning,\r\nI am rajeshkumar, technician from kerala. I have with me a Panasosic tc21rx 20cs tv with plain raster. Display and functions are ok but there is no video and audiio both in AV and in RF.While disconnecting the tuner picture is coming in AV and there is a raster also. Could you please advice. Thanks in advance.
techman
  • 3130 Answers
SOURCE: b/w picture
sounds like this set is in the UK??? or somewhere out of the states. If it working good on the tuner or telex box , the equipment your plugging into the AV inputs are not compadible to the tv set or there is a setting in the TV menu to change the format to pal
Posted on Aug 13, 2006
SOURCE: Tuner and AV problem
TRY TUNER ASSEMBLY SOLDER JOINTS COULD BE DRY OR CRACKS GOOD LUCK
Posted on Jul 05, 2007
  • 15 Answers
SOURCE: Sharp LC-15AV4U 15 in. LCD Television
Sounds like a lamp error.... either a defective or broken lamp within the LCD1.gif panel itself, or you have a bad inverter.
Posted on Apr 02, 2008
  • 1011 Answers
SOURCE: av 1 and av2
check its manual in details . u will find that.
regards,
Posted on Aug 05, 2008
WhiteRussian
  • 167 Answers
SOURCE: there is no video capture from video input
This happens sometimes when you use a Windows XP Driver under Windows XP Media Center Edition and vise-versa... They slightly different versions of Windows; Windows Media Center is preset to the default capture application and is very dependant on a DirectX Video Capture SDK.
What does this mean to you?
First, try getting a registry repair tool; I use Registry Booster 2 because it is a Microsoft Certified Partner. Moreover, it fixes driver errors in the system registry and "boosts" the system performance.
If you have McAfee Security Center or Norton System Works they also have a registry repair tool...
Uninstall all the software and drivers for the device...
Run the registry repair tool to remove all the invalid entries still hanging in the system...
After you restart your computer install the...
Lifeview FlyVideo 2000/3000 20.46 WHQL Driver
Posted on Nov 27, 2008
Sound on but no pitcher
Sound on means audio section is ok. No picture is video board problem. Pl check input cables. Or give Hdmi cable input. Disconnect all inputs switch on u should get plain raster that is only dots on screen, or blue back screen, if nothing contact authorised dealer,
Feb 08, 2015 | Panasonic TH-L32C20X 32 inch Multi-System...
Problem with rca big sreen tv
First, try a hard reset.
You must unplug the power cord (turning off the set or the strip will not do it) for a couple of hours, then try again.
This will sometimes correct the problem
When it blinks off: Does the raster go dark or just the picture and the raster remain?
If the raster goes dark when it blinks off it means there is a loss of high voltage to the picture tube. High voltage repair is expensive. It may be a failing flyback transformer that is functional inside the horizontal deflection circuits.
If the raster stays on and you just lose video (picture information) then it may be a simple intermittent IC chip in the video board area. It may require a technician to determine which IC and how to replace it or the parts associated with it, but probably not terribly expensive to repair.
Jan 12, 2008 | Televison & Video
Lcd display PLAIN RASTER
NO onscreen display at all when pressing menu? Could be t con board which may not be available without replacing completed lcd panel or main board. 32 inch tv is not expensive to replace . Shop around before putting money into this set.
Oct 02, 2013 | Sony Klv-32t550a Bravia Multi-system Lcd...
Picture tube
what kind of display have, totally black or only a raster?. if you are watching a local channel then only a raster with sound, it could be a tuner problem. now if totally black screen you need to check if the flyback transformer has high voltage coming out at the anode cap. and then the tube has heater light. this case can be hand held with a trained technician if you don'y have an idea on how to deal with it just leave it to the tv technician for safety reason. however at least you have an idea what to expect if you decide to hire for somebody to fix.
Aug 11, 2012 | Zenith Televison & Video
I have sharp tv.I used to fix Sc-2166 chinese board.but now it will not com display.Its totally black.can i repair this.I used only one month.
check&change pt heater resistor[series in lot].increase screen grid voltage,your problem continue.sound is working normal no display you have this problem than it is plain raster means no picture,no snow.than change croma icµ processor.rarely picyure tube problem.before change p.t.this board check to connect another tv.but not solve this problem change anew board.
My sujession is chineese board cost is very low.so my first prefferance is fix a new board. yhank you.
Sep 06, 2010 | Sharp 21B-S10 21" TV
Samtron sc 428pt no display
Hi...there,
Well, no display usually caused by burnt out backlight inverter. Need to replaced a new one or repaired it... Happy Holidays!
Dec 05, 2008 | Computers & Internet
Blank raster
check eeprom
Dec 21, 2007 | Televison & Video
NO PICTURE
do you see anything on screen.no picture doesnt mean no raster ,raster mean anything that comes out in display.no raster with sound only mean failure in either,connection in heater which means, loose connection or some new sets declare failure in vertical circuit.so be more specific ok?
May 08, 2007 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Pic Bleeding
this sympton is characterized by the presence of red, cyan, green, magenta, blue or yellow colour in a supposedly plain white raster. proper colour reproduction cannot be expected if the raster is coloured. this symptom is caused by a poor white balance adjustment of by a trouble in the CRT, colour amplifier, color demodulation or colour output circuits. if the raster has a tint of red or cyan, check the R-Y output circuits and the first grid, second grid and cathode circuits of the red electron gun. but if you dont know anything about this, just bring it to a qualified service technician. good luck!
Jan 21, 2007 | Sony KV-35S45 35" TV
No raster, No sound, No channel number
wepu, Buddy it sounds like you got a power supply problem. As you say the picture is all blue?? With no video or sound and the fact that the channel display is out is the first indication that i would guess this. Do you still have the owners manual that you got when you first got the set? Good, cause thats the only place i can think of where to look in case of service over in your part of the world as I did try!! Man I tryed but to no avail. No one has heard of this model but that dosent mean that it dos'ent exsit!.. If your a tech or know your way around solid state circuitry then you should have no problem finding the fault once you get a service manual from the service location in your owners manual. Now if your not a tech and a handy man ?? If I were you I wouldnt mess with the tv as theres over 25000 volts inside the set and i've seen it make a grown man cry. Man dont attempt the repair or troubleshooting if you dont have the right or proper tools and equipment!!! Good Luck
May 26, 2006 | Philips 21PT4475 TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
