Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
I have a century wet end pump part# SP10-1N11CB 9.8AMP 115VOLT SERIAL #SP0803317085, I CANNOT FIND ANY THING WITH THIS PART NUMBER CAN YOU PLEASE GIVE ME A VALID PART NUMBER. IT ALSO SAYS A.O. SMITH ON THE PUMP. IT IS FOR MY ABOVE GROUND SWIMMING POOL
    Top Expert:
  • AO Smith Master
  • 8,861 Answers
Less hassle replace whole pump
Posted on Dec 05, 2017
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: I have a AO Smith Century Centurin Swimming Pool
A.O.Smith USQ1152.
Posted on Jan 18, 2010
Where can I get rebuild kit for the pump of my Aker swirlbath model CT26060B0? The seal is leaking at motor shaft end of pump.
That is great, that you posted a picture of the motor....
but unfortunately the motor does not have a seal. It is the wet end that is connected to the motor which makes a pump, and that has the mechanical shaft seal.
if you remove the cover of the wet end, and expose the impeller, then remove the impeller, and expose the shaft seal, we would be able to assist you better. A picture of the wet end and post it, will greatly assist as well.
unfortunately the information that you provided, although very much appreciated, really does not assist. Because the manufacturer of the tub, can use a variety of different vendors for the pump. But,...
if your tub came with a serial number? You can contact the manufacturer and they may have records as to what pump was used on your specific unit. And then from there you would be able to know what pump or more specifically...which Wet End, was used and then you would be able to find out which mechanical shaft seal went into that pump or Wet End!
if I was to venture a guess: it is either a
U.S. Seal PS 200 or PS 201
Mar 28, 2015 | Pool & Spa
Century motor wire for 115V it a pump for water
What is it that you need to know? What is the code & Serial number of the century motor?
posting a good clear picture of the back end of the wiring area of the motor helps too.
Mar 11, 2015 | Century Pool & Spa
How to replace seal on century lasar spa motor
split the motor from the wet end then take off the cover to the impeller remove screw for impeller backwards thread might have to hold the shaft on the back of the motor then unscrew the impeller regular threads separate the motor from the backing plate replace seals then reverse process
Jul 05, 2014 | AO Smith A O Smith Motors Century 1hp 115v...
Have a 94 Buick century. Replaced thermostate. Running hot. Looks as tho is leaking underneath front near pump. And also in passenger floor board can't see the leak from inside. It's just alwa
Whenever I see a system which is leaking from more than one or two places, I do a head gasket check because that tells me that the system is experiencing above normal pressures. the wet floor is a heater core. whether it's a water pump or some other thing near it only you can tell. Actually it rarely happens, but the wet floor could be the hose where it meets the heater core at the firewall; again, only you will be able to tell the difference. if the hose connection looks dry, assume that it is the core itself.
Mar 03, 2013 | 1994 Buick Century
Bleeder screw
on the wet end of the pump or filter top
Feb 06, 2013 | Century New Magnetek Pool Spa Pump Motor...
What is the flow rate ?
depends on wet end and filter and piping
Feb 04, 2013 | Century New Magnetek Pool Spa Pump Motor...
Inead a new timer for a jacuzzi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First thing:
Determine Hp (horsepower), wattage and volts. There is a label that shows these values
1) Indoor Jacuzzi pumps are usually 115Volt and 1 Hp to 1.5 Hp. 1 Hp or horsepower is 746 Watt, 1.5 Hp is 1119 Watts
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Which timer? If wiring is already connected to a switch, ordinary in-wall 15Amp timer can handle up to 1400 Watts.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 2) Outdoor Jacuzzi or Hot Tub pumps can be 115Volt or 240Volt and up to 5 Hp. 5 Hp is 3730 Watts
Which timer?: Wide variety of Pool and spa controls at Aplus
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.aplussupply.com/intermatic/timerpool.htm
If you need more help, re-post electrical details about your jacuzzi and exactly what you want timer to do.
Sep 19, 2010 | Jacuzzi Hardware & Accessories
What do i replace my 4hp Flo Master XP2 wet end with? Everything now is for 3hp or less
Thank you for posting your question here on Fixya.com.
Your wet end was most likely the 3HP version all along. Most pump manufacturers use the motor service factor to exaggerate the HP rating to try and sell the unit as 'better' than the competitors. You are best off using the part number molded into the original impeller as a means of identifying what pump you really have and ordering the wet end based on that information. If you can get the 8 digit number please post it in a comment to this message and we can verify the correct wet end for you. Another alternative will be to use a Waterway Executive model wet end if yours is indeed a discontinued 4HP rating.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Aug 18, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
107 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
