Question about Compaq CV 7500 17" CRT Monitor
When I start the PC the msg' out of frequency; set low resolution' appears on the monitor. The basic clor is also yellow on the monitor
  • Compaq Master
  • 11,800 Answers
The monitor is dying of old age, replace it, nothing more can be done to save it.
Posted on Aug 04, 2010
My pc is hcl monitor working on windows 7 When I start my Pc the windows comes directly shows that Attention Not Support Out Of Range I.know pressing F8 Key but Nothing is happening help
Sounds like you set the refresh frequency/resolution of your monitor to a value not supported by the monitor. You need to restart in safe mode and reset the resolution.
Keep pressing F8 at boot until the menu appears. Try restoring to a previous point.
Or try
- Boot in Safe Mode with networking and Uninstall your current GPU Drivers.
- Download the current Drivers and install
- Restart the PC in the Low resolution Mode (F8 Safe Mode launch menu)
- Use your Graphics Card Control Panel and Force change your settings back to the original working ones.
Mar 21, 2016 | Computers & Internet
My acer 19in LCD monitor goes blank after initial startup and msg "Input not Supported" appears. Startup msg are shown but once Windows starts, this error appears. I have tried to adjust the...
May I ask to what you mean by "adjust the resolution in safe mode, this has not helped"?
Did you set it to native resolution of this monitor? Unless it has problem inside the monitor, try it with another PC also.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 08, 2010 | Acer AL1916W 19" LCD Monitor
Frequency out of range
the monitors resolution range is only to 1280X740 or 780
and your video card may also need an upgrade.
The game may require a higher resolution that is not compatible with the the devices mentioned.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
Intstalled starlogic moniter to PC and got error message
the "Out of Range" message usually appears when the video card is putting out a video resolution or frequency that the monitor isn't able to handle. You should reboot your computer and BEFORE the Windows screen shows up, press the F8 button once every half-second. THis will bring up the boot menu for Windows. Select "Enable VGA Mode" and press enter. THis will load Windows in VGA mode where the screen resolution will be 800x600 @ 60Hz. Any modern monitor is able to use this. Once you log into Windows with the basic video settings, you can go into the Display properties within Windows and bump up your resolution and frequency as needed.
May 11, 2009 | Computers & Internet
AOC 771S monitor always appear "not support out of range even if i already set my resolution to lowest.
the lowest resolution is not always supported. by the range maybe referring to the frequency. change that, that should work. if you are not sure, look at your monitors manual, it will tell you resolution as well as frequency optimal settings
Apr 20, 2009 | Computers & Internet
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
Out of frequency range set low resolution or refer monitor manual
TO RESET IT START YOUR COMPUTER IN SAFE MODE AND GO TO DISPLY SEETTINGS SET YOUR MONITOR AT VERY LOW 32BIT 800 BY 600 PIXELS IT WILL SOLVE THE PROBLEM THAN RESTART THE COMPUTER
Feb 06, 2009 | Compaq CV 7500 17" CRT Monitor
Relisys Monitor model TL528A - Plug it in, screen is blank panel light is yellow. push ON button and I get a 5 second message stating: OUT OF RANGE HS: 53.5 KHz VS: 84.8 HZ WORK RANGE ...
It normally means that you have connected the monitor to a computer whose resolution and frequency are beyond the range that this monitor are capable of.
To fix this, you can do one of two things: reconnect the old monitor and reduce the resolution to 800 by 600, which every monitor can handle and then reconnect the new monitor and change the resolution settings again. by default, Windows will restrict you to only settings that the monitor can handle. The second option would be to start your computer in safe mode (F8, just before you get the windows screen during boot). and change you monitor settings that way, rebooting afterwards.
Jul 10, 2008 | Computers & Internet
Hello, i have a windows vista basic from walmart and i just purchased a proview model#pl926w series flat panel monitor from walmart and need to know how to obtain the 1440x900 resolution. the set up guide...
Yes,you obtain high resolutions.
Do the following steps.
1. Open Display Settings by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Mar 07, 2008 | Computers & Internet
Compaq CV 7500 17" CRT Monitor Logo
78 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
