Question about Cameras
Camera stating protected card. won't allow me to take anymore photo's
  • sharonmc7 Aug 07, 2010
    \Thank you for your reply to my question, I thought there was a cost with making these queries and appreciate that there isn't. It seems a simple solution although i would never have found it myself. Thank you again.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Since you didn't specify the make and model camera, I'll assume it uses SD and/or SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Aug 04, 2010
Testimonial: "Although this sounds a simple solution, i would never have found that button myself. Thank you so much for the free advice."
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
Card protect won't allow me to take photos
SD and SDHC memory cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 05, 2012 | Video Cameras
I cant take photos anymore and the LCD screen says CARD'S WRITE PROTECT SWITCH IS SET TO LOCK.How can i solve this problem?
You didn't specify the make and model of your camera, so I'm going to assume it uses SD and/or SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If this doesn't do it, try another card.
Dec 28, 2011 | Cameras
Camera wont allow me to take photos says
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 13, 2010 | Panasonic Lumix DMC-FZ20 Digital Camera
Can't take photos as it says card protected. I don't know how to unprotect it?
There are 2 protection that you have to check:
1) Check on your SD Memory card that on the side there is a small switch. Move it to the opposite position and reinsert in the camera. Take a picture and see if it is OK.
2) If still appearing the message go in the PLAY menu of the camera and where there is the entry PROTECT with a Key Logo select NO.
Then it should be working fine.
Remember that then your pictures are not protected anymore.
Regards,
PDG
May 09, 2010 | Fuji FinePix S1000FD Digital Camera
Memory card photos cannot be downloaded onto computer, tried two diferent computers, also kiosk at walmart, pics can be viewed on camera in multiviewing setting, but not individual setting. windows pop up...
Check the menu, many cameras allow you to enable photo protection, you may have some photos protected. You won't be able until that protection is removed.
Mar 07, 2010 | Cameras
"the media is write protected"
Look on the memory card, some have a tiny switch that write protects them.
Mar 04, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Card protect message doesn't allow any activity with camera how to remove?
Hi there
Face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for using Fixya!!
May 25, 2009 | Toshiba PDR-4300 Digital Camera
Card Protected
If you read the manual there is a section on protecting frames. You should be able to go into the menu on the camera and unprotect all, which should allow you to then write new photos and remove old ones on the card.
HopHead
Oct 28, 2008 | Fuji FinePix S7000 Digital Camera
Cameras Logo
20 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
