Question about EuroTech EDC158 Electric Dryer
Heating element replaced. Worked one load and back or dryer seemed very hot. Turned off and later ran on low. Next load no heat.
  • Lauri Garber
    Lauri Garber Aug 04, 2010
    I will show your solution to the service man who has already replaced the heating element twice.
  • EuroTech Master
  • 19,396 Answers
Hi.
There is either a problem with the thermostats that turn off the heating element, or the heating element is plugged (elements has contact to ground and stays always on).
Heating element and thermostats are tested reading Ohms with a multimeter set at Rx1. If the circuit is open (Ohms stay infinite), then the part is defective.
If the machine overheated, then the element may be gone again. Test reading Ohms.
Also replace the thermostats (there should be two or three of them), unless the element had a contact, the most common cause for overheating is a shorted thermostat.
Posted on Aug 04, 2010
My Whirlpool duet sport dryer got hot and shut off after running 20 minutes.
Sounds like you may have a bad heating element that has grounded. You should have this looked at to make sure if you aren ot handy to open the dryer up and inspect the heating element your self. make sure the element wire has not broken and fused itself to metal inside the dryer heater housing.
Feb 02, 2017 | Whirlpool Dryers
Maytag neptune dryer doesnt heat
On the housing the element mounts in is a couple of safetys The smaller one is rated for 300f and the bigger one is rated for 250f. If the smaller one is tripped obviously you replace them both, making sure the vent to outside is clear. Them fuses blow or trip because of air restrictions.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2012 | Maytag Dryers
Whirlpool electric dryer not drying
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Jan 28, 2009 | Whirlpool LER8648L Electric Dryer
Poorly heating clothes dryer
Best way to test the elements and stats is to disconnect each one in turn, and with your meter set on the ohms range ,test each one in turn for continuity, you should get F.S.D.(full scale deflection) on each component.
Another way to test the element, is to bypas the stats, and connect the 240v suplly directly to the element, it should get red hot, but do not leave it on for more than a few seconds..
If it had gone down to earth, then theoretically it should trip the circuit breaker.
Plz rate my solution.
Thanks.
Dec 25, 2008 | Dryers
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
Dryer heating element(s) are inconsistent
there is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Nov 23, 2008 | Whirlpool GEQ9800P Electric Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
EuroTech EDC158 Electric Dryer Logo
321 people viewed this question
Top EuroTech Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you an EuroTech Dryer Expert? Answer questions, earn points and help others
