Question about Samsung Office Equipment & Supplies
I have installed a refillid cartridge into Samsung fax machine SF-375TP and I get message"Install ink cartridge".What must I do in order to get machine to start working again?
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Try cleaning well the contacts on the cartridge
try cleaning liquids with amonia
Posted on Aug 10, 2010
  • Samsung Master
  • 12,061 Answers
Many cartridges DO NOT respond well to being refilled, and if you don't use a manufacturers ink cartridge. And if you don't you will get that message.
Sometimes you can reset the "Chip" in the cartridge, yes, there is one in there too, especially so it cannot be refilled by a third party,
There is NO simple way around this, "They" want you to buy NEW inks each time, and NOT refill, it sux huh?
www.crowson-ward.co.uk/media/pdf/Samsung%20SF375TP.pdf
Manual above.
www.futuregraphicsllc.com/lit/instructions/CLPCRSTECH_ud.pdf
Above is a link on resetting the cartridge.
Posted on Aug 04, 2010
Testimonial: "You're right it sucks"
    New Friend:
I refilled ink in mono laser printer (sumsung)...but when i start the machine..it gives error to installed catidge..so, how cartidge installed ? kindly reply thanx !
Posted on Nov 28, 2012
  • hamna Nov 28, 2012
    i refilled ink in mono laser printer (sumsung)...but when i start the machine..it gives error to installed catidge..so, how cartidge installed ? kindly reply thanx !
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
How do you change the ink cartridge on samsung sf31oo
Hi
It's very easy to remove the ink cartridges of Samsung printers. I have provided you the link to download and see the manual of the printer you are using, please go through the weblink and you can easily remove the ink cartridges.
Here is the weblink
http://www.samsung.com/in/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=06011300&prd_mdl_cd=SF-371P%2fXIP&prd_mdl_name=SF-371P
Jan 28, 2010 | Office Equipment & Supplies
Replaced Ink on Samsung SF-330 and still says install ink
There is something wrong with the cartrige head. First try to take out the cartrige and in the head there is contact points. You can try and clean it with a dry cloth.
Aug 18, 2009 | Samsung SF-330 Plain Paper Inkjet Fax
I need to set up the Fax on the Samsung ink jet fax SF-375TP
I worked it out throught the menu eventually thanks
Jun 29, 2009 | Lands Phones
Fax saying no cartridge, but have just put new one in machine
That means that your fax machine is not recognising the cartridge. Either is not been put correctly or the cartridge suport is broken. Try with the old cartridge or with the new one use a bit of tape to old it against the contacts of suport cartridge. GOOD LUCK.
Nov 02, 2008 | Samsung SF-3200 Fax
Samung Sf-330 fax.
probably you did not fix properly the ink cartridge.check the cartridge for proper seating.
Jun 02, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Samsung SF560.
Check if there is a fuse in place (usually fitted to the front edge of the cartridge) and always replace when refilling.
Aug 31, 2007 | Samsung SF-560 Plain Paper Laser Fax
683 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
