Question about Microwave Ovens
My ewave kot131uw microwave quit working. what can I do to get it going again?
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Ewave OTR Microwave Oven, Model KOT-153UW. Light
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 13, 2009
hiltonjug
  • 612 Answers
SOURCE: Ewave over the stove microwave fuse blows when I
The light is the only thing that comes on when you open door. You either have a shorted door switch (Micro switch) or a shorted bulb. You have either a shorted bulb or bad socket. From my experience, it's the bulb. Just because it may seem to start to come on when you open the door, it's most likely bad. At least it not expensive.
Please rate solution
Posted on Aug 28, 2009
Testimonial: "Thanks, yes the light comes on for a second then fuse blows. I'll replace it, thanks!"
MicrowaveSvc
  • 9098 Answers
SOURCE: ewave panel is on lock
As per the owner's manual:
The oven operation can be locked to prevent the microwave from accidentally being turned on. All oven functions can be locked.
To Set: Touch and hold the CANCEL/OFF Pad for three seconds. The Display shows “LOCKED” and the oven beeps.
To Cancel: Touch and hold the CANCEL/OFF Pad for three seconds. “LOCKED” disappears from the Display and the oven beeps.
If this does not work, then try a hard reset: Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you probably have a problem with the controller.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee. It may cost a little more if you need parts, such as a new keypad.
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Posted on Aug 30, 2009
Ewave microwave
Over the range microwaves are generally the same as far as the rear dimensions but you will still need to install new mounting brackets and drill new holes in the cabinet. Each brand is slightly differnt in its mounting.
Nov 25, 2013 | Microwave Ovens
The turntable on our Ewave KOT 170SW Microwave oven has quit rotating. Other than that the oven works fine. Any troubleshooting tips? If the turntable needs to be replaced, how big a job is it? I'm not...
i went to replace lite bulbs but didnt unplug it..removed cover and shorted out...now no lite and no turntable but does come on & heats food is it fixable.......ewave microwave kot-131uw....
Feb 28, 2011 | Kenmore 80412 Microwave Oven
I want to buy the handle for my EWAVE microwave
You can order Ewave parts here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Jul 02, 2010 | Kenmore Microwave Ovens
Change handle on ewave microwave
Take a look on amazon for replacements, here Amazon com microwave handle. I hope this was helpful. cheers
Jan 15, 2010 | Microwave Ovens
How to replace the door handle on an Ewave KOT 170SW Microwave
Ewave KOT 170SW Microwave, it starts runs for a few mins. then stops. Shorter then time set for.
Dec 10, 2009 | Microwave Ovens
I have an Ewave microwave/range hood. How do I
Depends on the model number but here are some owner's manuals to check:
HTML clipboard http://www.microwavedisplay.com/KOT131UB.pdf
http://www.microwavedisplay.com/KOT131UW.pdf
http://www.microwavedisplay.com/KOT152UB.pdf
http://www.microwavedisplay.com/KOT152UW.pdf
http://www.microwavedisplay.com/KOT153UB.pdf
http://www.microwavedisplay.com/KOT153UW.pdf
http://www.microwavedisplay.com/KOT170SB.pdf
http://www.microwavedisplay.com/KOT170SW.pdf
http://www.microwavedisplay.com/KOT171S.pdf
If you find that you still have trouble after replacing the bulbs, you probably have a problem on the circuit board.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
prototech@usa.net
Oct 29, 2009 | Daewoo Microwave Ovens
Oven light only, everything else dead. no display. ewave mod. kot131uw
Usually means the internal 20A fuse is blown because the magnetron is shorted. If it's over 5 years old, it's probably a goner. You can check the fuse by removing the access panels but be sure you've unplugged it from power first.
Jun 12, 2009 | Microwave Ovens
Replace OTR Microwave
Thanks for responding. It is a EWave KOT-152UW. I think EWave is part of Magic Chef. I think it is the door switch. When I opened the microwave, the circuit breaker tripped. I reset the circuit breaker, and it worked for several days, but the last time, the microwave went dead. The reason I want to use the same bracket is it has through the wall (horizontal) venting to the outside, and I am not keen on trying to cut more holes.
Nov 04, 2008 | Microwave Ovens
Microwave Ovens Logo
126 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
