Question about Car Audio & Video
How to remove dash panel of new zen estilo? - Car Audio & Video
Out put to the back speakers are low
Check your fader control on the unit maybe it has been adjusted to supply more power to the front speakers.
Dec 27, 2009 | Sony Car Audio & Video
My zen doesnt want to connect
I think I found my answer. With my player connected I went to Control Panel- System- Hardware- Device Manager and under Portable Devices removed my Zen Player. I then went back to Control Panel- Add Hardware- and let the Add Hardware Wizard add my player back.
My Zen Micro Photo now connects to computer and I can charge the battery with no problem.
Nov 04, 2008 | Creative Labs Zen MicroPhoto MP3 Player
NECESITO SABER A QUE ESTILO DE VEH?CULO PERTENECE EL VIN WDB38011315337818
Hola,
Profavor pregunta esta pregunta en carros("cars") y usa ingles.
Trate de buscarte el model o estilo pero no encontre nada:
http://www.autocheck.com/
Suerte
Daniel
Sep 23, 2008 | Computers & Internet
Zen vision m not recognized
Same problem. Solved by downgrading Windows Media Player to v.10. Do it through Control Panel and click Remove WMP11 and WMP11 runtime. Restart, connect your player and if not recognized do go to Control Panel=>System=>Hardware tab=>Devices. Find Portable Devices drivers in the menu and click Uninstall MTP device. If still not detected, go to Control Panel=>Detect New Hardware and run that. The player should connect automatically. WMP 11 has a glitch that disallows 3rd party MTP players. Intentional or purposeful? Ask B. Gates.
Jul 22, 2008 | Creative Labs Zen Vision Digital Media...
Zen Media Explorer keeps saying "Player not connected"
This worked for me - My Zen player had the same 'not connected problem'
From the Start menu, select Control Panel > System. From the window that appears, select the Hardware tab and then click on Device Manager. You will find a listing for your Zen Player - probably under Portable Devices. You may well see that the entry for Zen has an exclamation mark in it - delete this entry by right clicking your mouse. Reboot your PC with the Zen player still attached and you should find that the problem is cured.
Chris
May 02, 2008 | Creative Labs Zen Digital Media Player
Creative Zen Touch firmware problem
Before preceding, goto control panel, add/remove programs (vista equivalent) select windows media player and uninstall note the response it gives you. If it is going to allow you to uninstall OR downgrade windows media player to version 9 then keep going. If not, then find another computer that you've never used the player on try upgrading firmware there, make SURE it's got windows media player 9 by downgrading it in add/remove programs.
Now for the fun stuff:
Sounds like the same problem I've resolved several times in the past on here.
1. Plug in the device.
2. Goto device manager in control panel and remove the device drivers.
3. Reboot if it asks you to, make sure to unplug the device.
4. Goto device manager again, remove the USB hubs.
5. Don't reboot.
6. Goto control panel, add remove software or equivalent for windows vista ultimate.
7. Select creative labs, and uninstall any and every zen related software.
8. Don't reboot.
9. Goto my computer, find the creative directory located on your main hard drive at \program files\creative. Deleted it completely.
10. Select windows media player select uninstall, or downgrade accordingly.
11. Make sure your zen touch is not plugged in and reboot your system.
12. After system loads, plug in the device and run the firmware software again.
And if you wish, reinstall windows media player 10 and the creative software (which you don't need at all with vista) all the other drivers should reinstall themselves.
BTW it's a hell of alot easier to just use another CPU if you have access to one, I've done it both ways and it saves alot of time.
Mar 15, 2008 | Creative Labs Zen Touch MP3 Player
Creative zen micro doesn't show so I can transfer
1. remove all creative software from your pc (do this from start menu/settings/control panel/add or remove programs)
2. Uninstall Windows Media Player 11 and Windows Media Player 11 runtime. This will rollback the pc to an earlier version of WMP.
3. Download the latest version of the zen driver from this location:
http://us.creative.com/support/downl...ame=Windows+XP
4. Make sure the zen is not connected to the pc and install run the exe file to install the software on your pc. at some point, the install will tell you that the unit is not connected. Connect the unit to proceed. it will also notify you that you are replacing an existing software, or something to that effect. I accepted or said OK to this popup. Once the firmware is installed, my started to work fine. You can now reinstall WMP from microsoft website. Hope this works for you.
you might want to verify that your new player has the latest firmware available, as this might address the unresponsive-button issue you're having. Firmware updates are surprisingly easy - you just download the firmware file from Creative's website, plug in your player, and double-click the downloaded file. It's that easy.
Jan 18, 2008 | Creative Labs Zen Micro MP3 Player
Creative Firmware Upgrade Does Not Recognize Zen Micro
I had this same problem and almost threw out the Zen.
The trick to getting the Zen recognized by the firmware update software is to make sure you uninstall BOTH WMP11 as well as the WMP11 Runtime. Those two things are listed separately in Add/Remove programs.
BOTH must be uninstalled before the firmware updater will recognize your Zen.
Now I'm back to using my Zen. It's all good.
Dec 13, 2007 | Creative Labs Zen Micro MP3 Player
ZEN V PLUS Software Installation
hi,
Can u help me to find a link som I can download instellation cd for my creative zen touch 20 GB.?
SEC. Katy
Aug 11, 2007 | Creative Labs ZEN SLEEK MP3 Player
Car Audio & Video Logo
194 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
