Question about M-Audio Fast Track Pro External Sound System
While instaaling fast track pro i get a msg that your computer's operating system is not supported for the use of fast track pro at this time
    Guru:
  • 825 Answers
It requires a higher standard operating systems to install this software... if you are running in windows Xp try upgrading to vista and install the software... if you are already running in vista or win7 then it says that it requires a 64 bit operating system.....
Posted on Aug 04, 2010
My m-audio fast track pro doesnt come on could it be the fuse
Short answer to your question NO !!!
Most likely the driver in the computer is NOT active or loaded properly... You haven't even told us what computer or operating system you have. The unit will NOT come on till the computer recognizes it and loads driver.
Jan 19, 2011 | M-Audio Fast Track Pro Mobile Audio/MIDI...
I am using M Audio Fast track Pro on Windows 7, and, after a lot of time spent trying to figure out which input and output channels were which (via the Control Panel) managed to get the sound operational...
My suggestion is to uninstall the Fast Track device, restart and then reinstall the software. Also, not knowing the computer you are working with, I would also suggest that the speakers are not disabled somehow ( IE, Mute button that got accidentlly activated). Was anything else done to the computer between the time is was working and the time it stopped working). If your audio card and and software are working properly, your speakers are the problem.
Let me know if you can add any more detail to the issue so I can help your further if necessary.
Brian
Dec 31, 2010 | M-Audio Fast Track Pro External Sound...
How do we connect an m audio fast track pro to my pc and mixer (dp-01fx)?
All you have to do is to connect with 2 cables your mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 20, 2010 | M-Audio Fast Track Pro Mobile USB...
I can't open a bundle file from one computer to another
1) after copying it to the new computer, right click and hit the properties tab. Make sure that you UNcheck the read-only tab and press apply when your done. For some stupid reason GT-pro 2 will not open read only files. I had this problem many times when backing up to cd since the files on the cd were read only.
May 09, 2009 | Cakewalk Guitar Tracks Pro 2 Classic
How Do I Capture Live Audio with M-Audio Fast Track Pro
All you have to do is to connect with 2 cables your cd's or dvd's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Thanks and regards
Stelios
Aug 31, 2008 | M-Audio Fast Track Pro Mobile USB...
How to hock up my behringer mixer to m-audio
All you have to do is to connect with 2 cables your behringer mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Thanks and regards
Stelios
Aug 20, 2008 | M-Audio Fast Track Pro Mobile USB...
Taking recordings from mixing desk
As the Fastrack can only receive one audio signal at a time you would have to record each track seperatly into Pro Tools.
I'm guessing your mixer is a multitrack recorder.
Solo track 1 on the multitracker and playback from there into the Fastrack, with track 1 on Pro Tools set to record. Repeat this for each or your tracks on the multitracker.
When you've finished you'll need to align all the tracks in Pro Tools so they all playback in time with each other.
Jun 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
I guess if your still looking for an answer your probably desperate. Never the less, if someone else is looking for an answer you need to select FT Pro in the preferances. Basically, you have to tell the software what to record and when. Pretty easy really.
Apr 19, 2008 | M-Audio Fast Track Pro External Sound...
M-Audio Fast Track Pro External Sound System Logo
183 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
