Question about Cameras
My mp4 battery is down and i don't know how to charge it through computer. I also don't know to go where... What should I do and How should I charge.
    Sergeant:
    Champion:
  • 301 Answers
Ok with pc you need a olmost always a usb cable universal , jut conect one part in to the mp4 and the other to pc
Posted on Aug 04, 2010
The mp4 player will be fully charged and when i take it off the charger and i want to listen to it. It will pause and freeze then will turn off right away. I will try to turn it back on and it wont turn...
i think in 3 possible solutions: 1- try to charge it with another charger 2- connect your mp4 to a computer and run a virus scan, after this try it. if don't, format your mp4 and try to charge it again. 3- the charge system of your mp4 is damaged, so take it to the technical support for to repair it.
Aug 05, 2011 | Mach Speed Trio V430 MP3 Player
Acer Aspire One D255E battery meter says 100% charged but computer shuts down when you unplug power cord
That's often the sign of a worn-out or defective battery. They appear to charge but don't store enough energy to work. It's also possible the motherboard's power circuit isn't working. The only way to know for sure is to have a known good battery as a test, or to try your battery in another computer. If your computer works with a good test battery, or your battery causes another computer to shut down, you know you need a new battery. If the trouble continues with a good test battery, you'll need to have the computer serviced.
Jul 03, 2011 | Acer Aspire One D255E13438 Netbook
My mp4 is not charging.
It is working but not getting charge
Feb 01, 2010 | Audio Players & Recorders
Hae bought 2gb Veg MP4 players. Can add music files to players when connectd to computer. But have tried to charge on numerous computers and they won't charge. Anybdy got any ideas or know how to fix? ...
Try to charge it via a battery charger. Change a USB cable to connect PC to make sure the USB cable is good. And change PC to charge the mp4 player. Compare the results, you will know where the problem is.
Jan 09, 2010 | Umax Vega108 MP3 Player
Mp4 player not charging up
may the connection is lost contact! use multitester to know if your component have continuity? next is battery if have proper voltage of it?
Jan 17, 2009 | Audio Players & Recorders
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
Craig cmp615d mp4 player
Turn off the player and let charge for about 4 hrs via USB port. This will charge the battery.
To upload songs to the player plug in to USB port and look for the removable drive through my computer or windows explorer. drag and drop MP3s into to removable drive window.
Jan 20, 2008 | Samsung Yepp YP-P2 Digital Media Player
Craig mp4 player
Keep your mp4 player turned OFF while charging and keep it in for an hour. Let it charge up. If that doesn't work something else will - Follow these directions carefully!
1. GENTLY hold your Craig MP4 player in hand. 2. Walk over to window and hold it near sunlight for 2 minutes. 3. Shake it gently 3 times. 4. GENTLY place it down and wait 2 minutes. 5. Grab mp4 player and smash it into trash can.
Voila! Problem solved!
Jan 08, 2008 | iLO (2 GB) MP3 Player
Portege 7200CTe battery life short
I don't know for sure if this is your problem, but I do know that laptop batteries normally have a certain number of full charges before they tend to stop working well. I have seen your problem happen to several different laptops. One way to check this would be buy a new battery for it. If it works fine with that, the problem was the battery and you now have a replacement. If it isn't, however, you have spent the money on the battery and it hasn't done anything. So, that is up to you. That's the only thing I know of, tho. Or if you know someone else with the same laptop, try putting their battery in. Like I said, I don't know for sure if this is the issue, but I have seen it happen to several laptops and a new battery usually fixed it or at least figured out what the problem was. I don't know any way to figure out if that's your problem without buying the battery first, but there might be a way.
Jan 06, 2008 | Toshiba Portege 7200CTe Notebook
Cameras Logo
29 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
