Question about Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive
Helloo, my cd/dvd drive can read cd but not dvd. i checked for the upperfilter n all the other filters in the driver register but dint find anything. but still its is not working. kindly find a solution for this.
    Guru:
  • 825 Answers
The lens has lost its potential to read DVD... it is a common problem in Combo players... if you drive is in warranty you can ask for a replacement... or else add another drive to your computer... because repairing the drive will never make it to work better...
Posted on Aug 04, 2010
My toshiba satellite E205-S1904 won't read cd disk.
System: Toshiba satellite E205-S1904
Pre-Installed O/S: Microsoft Windows 7 Home Premium 64-bit Edition
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
  1. Click Start vistastartbutton.jpg, type regedit in the Start Search box, and then click regedit in the Programs list.
    securityshield.jpg If you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, if you have UpperFilters, right-click UpperFilters, and then click Delete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, if you have LowerFilters, right-click LowerFilters, and then click Delete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
Regards,
Deathschythe33
Aug 05, 2011 | Toshiba Computers & Internet
I've got a studio 1737 with dvd/cd rom driver CDEXK4LE3GHQZ01 SCSI cdRom Device TSSTcorpDVD+_RW TS-T633AATA Device. The driver no longer reads any dvd (film, game) but it reads audio cd without...
Hi!
Try this fix:
For windows XP: Click on start Click on run Then type Regedit HKEY_LOCAL_MACHINE> SYSTEM > CurrentControlSet > Control > Class > {4D36E965-E325-11CE-BFC1-08002BE10318}. In the right pane, if you have UpperFilters / LowerFilters, right-click UpperFilters / LowerFilters, then delete it. Exit registry editor Restart the computer
For Windows Vista / 7: Click on start Then type Regedit in the search box. HKEY_LOCAL_MACHINE> SYSTEM > CurrentControlSet > Control > Class > {4D36E965-E325-11CE-BFC1-08002BE10318}. In the right pane, if you have UpperFilters / LowerFilters, right-click UpperFilters / LowerFilters, then delete it. Exit registry editor Restart the computer
You can also check this link: DVD Drive Problem
Thanks!!
Jul 17, 2011 | Dell (0F146) Internal DVD Drive
I use Samsung R 248. Recently my dvd drive is not working. It can't read any cd or dvd. what should I do?
Try to delete the upper and lower filters in the registry.
) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned.
Apart from this, make sure that the driver is enabled.
Thank you!
Feb 22, 2011 | Samsung Computers & Internet
Am using Nero Vision to burn DVD and always comes back with insert blank disk even though there is a blank disk already in the drive.
Please fit all the cable if you are using desktop.(Power and data)
Follow the bellow link,
http://www.helpwithpcs.com/upgrading/installing_cd_recorder.htm
Delete all temp file and restart
1. Click Start, click Run, type> %temp% >enter and delete all .
If the problem is same please follow
R_click on my computer>Properties>Hardware>Device manager>uninstall all the usb hub ,one after one .
After UN install all the usb, restart your PC .
If same please
Click on the link bellow link
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
And clink on RUN NOW from right side box
It will fix your problem.
You can try this trick - It might work - But, only if this is the root cause of your problem:
Many third-party programs that control CD or DVD burning (as well as some player applications) install CD- or DVD-ROM filter device drivers into Windows. These filter drivers are meant to allow for low-level hooks into the hardware, to allow for functions such as packet writing (where a CD-R/W or DVD-/+RW can be written incrementally, like a hard disk).
How CD/DVD issues can occur
These filter drivers sometimes have problems that can cause the CD or DVD drive to stop working correctly. The device entry for the CD or DVD drive in the Device Manager may show up with an error descriptor that reads "The device could not start." Additionally, there may be an error message that reads "One of the filter drivers for this device is invalid." The devices themselves do not show up in Explorer. Error codes for the device include code 31, code 32, code 19 or code 39, and sometimes the even more ominous warning "Your registry might be corrupted" appears.
Fixing the CD/DVD problem simply involves deleting the filter entries for the third-party device drivers. These entries can sometimes become damaged (which is what produces the "corrupt registry" warning).
How to fix CD/DVD issues
First Backup the registry.
Step 1: Start Registry Editor
type "regedit" in the Start Run box.
Step 2: Delete the UpperFilters registry entry
1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2. Expand SYSTEM, and then expand CurrentControlSet.
3. Expand Control, and then expand Class.
4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5. In the details pane of Registry Editor, on the right side, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
* If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
* If you do not see the UpperFilters registry entry, you still might have to remove the
LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
6. On the Edit menu, click Delete.
7. Click Yes when you receive the following message:
Are you sure you want to delete this value?
The UpperFilters registry entry is removed.
1. In the details pane of Registry Editor, on the right side, click LowerFilters.
Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
2. On the Edit menu, click Delete.
3. Click Yes when you receive the following message:
The LowerFilters registry entry is removed.
4. Exit Registry Editor.
Step 4: Restart your computer
Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
Several of the products made by Roxio are infamous for causing this problem, although in fairness to the company the most recent versions of their Roxio CD/DVD writing software (6.2 and higher) do not have these problems. Users of 5.0 or 6.0 editions of the Easy CD & DVD Creator product, which has been bundled with many new PCs in the past, should upgrade to 6.2 or better. Other programs can also cause this problem, with the same solution.
Note that after you do this, you may lose functionality in the program that uses the filter drivers, which may need to be reinstalled.
Hope this helps
Jan 07, 2011 | Toshiba (P000400770) Burner
My computer will not read a cd or a dvd. It say "No disc in F:drive
1.delete the upper and lower filter from registery
  1. Click Start RUN---TYPE REGEDIT
  2. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
2.bootable disk also not working means suspected issue with dvd drive,So change the dvd driver.
Nov 17, 2010 | Computers & Internet
Cd player wont work on acer laptop
Note that after you do this, you may lose functionality in the program that uses the filter drivers, which may need to be reinstalled..hope this will help you
Oct 23, 2010 | Computers & Internet
My Hp pavilion 533w Desktop's dvd drive wont open or blink(light)
Try the brute force method: stop the pc, open its case, disconnect the data cable from the dvd, close the case and reboot, run a registry cleaner,stop the pc, make sure the hard disk is set as master and the dvd set as slave and reconnect the dvd, start the pc.
May 05, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Cd/dvd drive cant read
Try Uninstalling the driver & restart the system & Try Updating the device driver from support.dell.com And also try this work well for more people
  1. Click Start, type regedit in the Start Search box, and then click regedit in thePrograms list.
  3. In the right pane, right-click UpperFilters, and then click Delete.
  5. In the right pane, right-click LowerFilters, and then click Delete.
Jan 09, 2010 | Dell XPS M1330 Notebook
Itunes will not write to my PIONEER DVD-RW DVR-106D
Install NERO software for burning. It has all the capabilities, specially ver 8 onwards......sodeep
Mar 19, 2009 | Computers & Internet
Crz320ae not read dvd
Download the driver from Sony for this product that matches your operating system
Feb 17, 2008 | BenQ CRW 4012A (99.B9712.036) CD-RW Burner
Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive Logo
105 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
