Question about Samsung N150 (36725723009) Netbook
My wife was using our N150 netbook, and had set it down for a minute. When she came back she picked it up in the corner, and accidentally pressed some of the buttons (like ctrl, shift, etc.). The screen went blank, and she is unable to turn it back on. Is there an easy solution for this? Thanks very much for your help!
    Problem Solver:
  • 5 Answers
Check brightness key to adjust screen bright ness or may be your laptop is sleep mode. Press power button for few seconds and restart the PC
Posted on Aug 04, 2010
  • lajoyce Aug 04, 2010
    Restarting does not change the problem. Are there any other possibilities?
    Neither of those possibilities resolved our problem. Is there anything else that is possible? We tried restarting, and the screen is still black.
Formeting prosses samsung n150
You should be able to press 'F4' at boot time and access Samsung Recovery Software, and then reinstall the back-up that would have been made the first time the netbook was switched on - a 'factory reset'...
Oct 27, 2014 | Samsung N150 (36725723009) Netbook
Why my samsung n150 cannot read any USB disk
Have you checked the bios usb set up ,perhaps is disable
at logo screen press f2 ,enter bios set up and change to usb enable if disable
Jun 09, 2014 | Samsung N150 (36725723009) Netbook
My problem is this that numbering write instead alphabed
Rigth top side of your keyboard , accidentally you pressed a key function that changed the layout ,look for i and change it
Dec 18, 2013 | Samsung N150 (36725723009) Netbook
How do i factory reset samsung N150 plus
Sep 08, 2012 | Samsung N150 Netbook
Factory reset samsung N150 plus
Sep 08, 2012 | Samsung N150 Plus 101inch netbook
My samsung netbook PC goes to sleep every few minutes and need to be started again pressing the switch button on. Sometimes it comes to operation on its own ''as if some divine power has come into...
Look under control panel for Power Management options. Adjust those to set the screen to always on when you have power and to power down after 20 minutes on battery. Making adjustments to these settings will cause battery life to drop but will accomplish what you desire as far as keeping the screen and hard drive on. Adjust the Hard Drive power settings in the same fashion.
Aug 09, 2011 | Samsung N150 (36725723009) Netbook
Samsung N150 plus working perfect last night..I sent 2 e-mails then purchased theatre tickets online.I then shut down a sper normal.This morning wy wife switched on notebook...some message came up very...
Hi
you could try this
Power up and immediately press the F8 key a few times hopefully it will take you into a repair screen
i would then try to click on the last known good configuration to see if windows will repair itself
it should restart straight away then try to repair
if this fails you could restart the laptop press the F4 instead of the F8 and this will hopefully take you into the samsung recovery management then follow the onscreen instructions but by doing this you will loose anything that you may of stored on your c drive
If you succeed in repairing the laptop and when you have it running again as you like it
please Set a restore point naming it something that you will remember as being all good and working properly i normally name my restore point ( all good )
this will help you to restore back to this point if you have problems in the future
many thanks
please let us know if this has helped you
Jun 06, 2011 | Samsung N150 (36725723009) Netbook
Where's the num lock of n150? been looking for it but i cant find it.p0ls help
Hi Irenegrace_l,
Here is the numlock for N150:
Kindly press FN + F11, you will see F11 have a picture of a lock with a number inside.
The following function key was found in the user manual for N150 under samsung website:
http://www.samsung.com/hk_en/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=1401&prd_mdl_cd=NP-N150-JP0AHK&prd_mdl_name=NP-N150P&srchword=N150-JP0A%2FJP0B
Hope this will solve your issue
Thank you for using Fixya,
avf110686
Apr 09, 2011 | Samsung N150 Netbook
I accidentally erased most of the files on my Sylvania netbook. Can I use flash drive to reload everything or do I have to use sdc card ? The only files I see are 'my computer' and 'recycle bin'. The...
First try this:
Flip the machine over and find a small hole about 1in. diagonally from the right lower corner of the data plate. Insert the tip of a tooth pick into the hole and press down for about 10 second, with the AC power connected to the machine. It should re-load a fresh copy of the operating system
Jan 24, 2011 | Sylvania G-Netbook
My Samsung N150 Netbook - BRAND NEW goes to SCREEN WITH A BLINKING CURSOR. What can I do?
Turn it off and ran again after 1 minute. Allow it to return to its default setting.
Nov 17, 2010 | Samsung N150 (36725723009) Netbook
Samsung N150 (36725723009) Netbook Logo
255 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
