Question about Sony Televison & Video
When i turn TV on the pic gos on for about 5min and then no pic has sound . Every time i turn it on
  • bekka1997 Aug 05, 2010
    My TV comes on with lines and then it gos off the pic gos off but the sound stays on i have to turn the TV off and on about 3 to 5 times before it stays on good
  • 4,889 Answers
Can I have the make and model of the set so that I can help you with your problem?
Posted on Aug 05, 2010
  • Sony Master
  • 11,800 Answers
Without knowing the exact model of your tv all i can say is that it's a loose connection: as the tv warms up it interrupts. Open the back of the tv (with the mains unplugged of course and firmly reseat all wires and connectors). If this doesn't fix it the it must be a soldering that has aged. Modern tv's have the components very tightly packed together, if you haven't worked on one of them until now you should be very careful when soldering, you can very easily create solder shorts and fry your entire tv. I recommend that you call a pro for this, it will be cheaper in the end.
Posted on Aug 04, 2010
  • Azrael SRL Aug 05, 2010
    If the image appears to have evenly spaced lines all across the screen then the problem is in the video final module. Check the connections and transistors there, then the connections to that board. Knowing the exact model of your tv and how these lines look would have helped with the diagnostic.
Rca pitcher gos off and sound stays onl lite blinks 5 times twice thep pic comes on for a few min and repeats
This is surely an error code generated by TV computer and your only way to see what it is is get the maintenance manual (maybe from the TVs website). Probably not worth fixing if you need to take it to the shop. I just bought a 40" LED TV for $199 and the minimum diagnostic is often quite high. Worse, the repairs are getting much more expensive due to manufactures not wanting to stock small repair parts. So even if it is a small cheap part broke, they only can replace large expensive modules (if at all).
Oct 21, 2015 | RCA Televison & Video
Screen GO'S Black then the sound & tv go's off
check the door switch for the bulb, if it is not contacting with the switch the tv will turn off. it somtimes dont catch the switch when you put the door back on.
Mar 31, 2014 | DSMiller Inc Samsung Rpt50v24dx/sms 150...
Tv comes on has a great pic and sound for about 1 minuite then screen gos off?
Check for any loose soder terminals at its main power regulator section. Resolder all the suspected solder terminals, by applying a little more solder.
Apr 25, 2012 | RCA TruFlat 27F520T 27" TV
My lg 37lc46 wont power up,no pic,green light flashes for about 10sec then gos red,sound up to the point were it gos off
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jun 15, 2011 | LG 42LC2D 42 in. LCD HDTV
LG 32lc7d lcd tv the work find for about 5min. Then the on screen menu comes on the screen then it gos off the remote will not work what board is it ?
Maybe the remote has some keys that are stuck together on the membrane pad. Take the batteries out of the remote, then turn the TV on again see if the menu problem is still happening. Also check the menu button on the TV see if it is stuck by pressing it a few times.......
If all seems ok but still have the same problem, then the the keypad board in the TV needs to be checked for intermittent shorts or opens. If the keypad board is good then the main board needs troubleshooting. This seems like an EEPROM problem, you may want to test that first on the main board.
any questions please ask....
CWR
Jan 20, 2010 | LG 32LC7D Television
Audio is fine, but video will off after 5min ON time
Good Day, howac506;
The most common problem for your 1991 TV is the vertical out put IC (IC) part number 272p239040.
I hope this was helpful.
Good Luck again, big IRISH.
Aug 04, 2008 | Televison & Video
Xbox 360 plays then just gos off an the green sign just flashes and i cnt get the game out
Send the piece of garbage back to Microsoft. Most likely it is a hardware failure inside the unit. Same thing happened to me after their fall update to the dashboard. It bricked my unit and could not play any of my games for longer than 5 minutes. You can try to power off your unit, remove your hard drive, turn it back on, and see if you can play without your hard drive.
Mar 02, 2008 | Microsoft Xbox 360 Console
Sony kv 32s42 32 tv
turn up your master screen control on flyback transformer. if when sceen gos black ,the timer light will be blinking. this means your picture tube is week. by turning up the screen control you may give it more time.
Aug 05, 2007 | Sony KV-32S42 32" TV
Televison & Video Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
