Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Kp-51ws510 red shadow convergence...
Suddenly while playin my ps3 the left half and the far right few inches of the screen had a red duplicate image coming off of everything gradually separating from whatever image is on screen more as you reach the edges of the screen. Sorry that was a huge run on sentence. I was able to slightly fix the problem through the convergence setting but am not able to move it enough. I've been told a light is out? I don't know... Please help... Anything...
  • Twistedhb Apr 27, 2008
    My red will NOT line up with the others, it just keeps jumping around... Flash focus doesn't help either
Can i get the picture installation as well, also i've read that STK392-570 is better, is this true? and how many do I need? I have the exact same problem. Also, in regards to the picture installation you have is that step by step from the beginning i.e removing the panel etc..
Thanks,
Posted on Aug 21, 2008
  • 121 Answers
You need to replace your convergence ic's STK392-560's they both need replacing I will post a link where you can get the ic's and picture installation instructions as well as free online tech support should take about 45mins to repair if you do it yourself and save you alot of money
http://servicemanuals.vstore.ca/
Posted on Apr 26, 2008
I have a sony kp-51ws510 projection tv, i replaced the convergence ic's and a pico fuse and then reset the convergence. The tv looks good except for a green shadow on lettering, also on the convergence...
Did you check the two pico fuses on the G board? Usually at least one will blow when the original ICs failed. I am attaching a pic that shows the 2 pico fuses on the G board.
Jul 08, 2011 | Sony KP-51WS510 51" Rear Projection...
Sony KP 51 HW 40 - in left half of screen picture has double images, right half of screen picture is normal.
This problems very common on DLP Tvs.This problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board is dead.Require to be replaced on the tv convergence board 2 STK convergence ICS and some or all it resistors to solved the tv convergence board problems,to solved tv convergence picture problems.The shop,will cost about $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-51HW40 51" Rear Projection...
Have red outline of images on left side of screen
Convergence is dead.Must Know how to solders.Replaced the 2 convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit,to do it ur self.The shop will cost u $300 for parts and labors.
Feb 04, 2010 | Sony KP-51WS510 51" Rear Projection...
Colors on the left side of the screen are shadowed with duplicate
Your set has a convergence problem which is a common issue.
Take a look at this solution posted earlier on Fixya. It worked for me.
http://www.fixya.com/support/t2703612-double_red_image
Aug 20, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony kp53v75 TV with blue convergence off right by half inch
it is a convergence problem u may have 2 replace conv ic's and some resistors
May 11, 2009 | Sony KP-51WS500 51" Rear Projection...
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Kp-46wt500 shadow and slanted images with rainbow colors
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 04, 2009 | Sony KP-46WT500 46" Rear Projection...
KP-51WS510
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
>>>Solution<<<<
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Feb 01, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony Model KP-51WS510 Issue
You will need to replace both convergence ICs STK392-560 you can get replacements at the following link and the give free instalation instructions plus free online tech support if you need help installing them. Here is the link.
Apr 27, 2008 | Sony KP-51WS510 51" Rear Projection...
Red Shadow
UNDER THE FRONT DOOR PRESS THE BOTTOM BUTTON "FLASH FOCUS" AND SEE IF IT FIXES IT. IF NOT AND YOU SEEN RED DOUBLE OF THE IMAGE, THEN THE SET PROBABLY NEEDS THE CONVERGENCE CIRCUIT REPAIRED.
DON.
Feb 01, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
