Question about Tascam 302MKII Single Cassette Deck
Sound is wavering and distorted on playback as though tape is slipping. Old thicker TD60 tapes work much better than modern SA90 tapes. Heads have been cleaned to no avail. Can you help please? Regards, Alan J. Peters
  • 3,230 Answers
Well this may because of worn belts that are slipping. All cassette player are using belts to run the tape. Both decks are run using belts. If the belt on decks is slipping, You can open up the top and and check the belt for decks. You need to change the belts cost $2 to $4. Once this is done, problem solved. you may please follow the link below -
http://www.cse.iitk.ac.in/~amit/courses/371/adarsh/contents.html
Good Luck!!
Thanks
Posted on Aug 04, 2010
Jittery video and sound, and now no playback
You may have damaged the heads if your cleaner tape was old and dryed out and had grit on it, buy a new camera head cleaning tape for a start, never rewind it as lots of folk do, if you do that all you do is put the old dirt back on the head.
May 22, 2010 | Sony Handycam DCR-TRV460 Digital Camcorder
Hear both sides of tape on playback ??
It's a 4-head reversable deck where the Forward tracks are arranged across the physical tape surface, front-to-back as follows:
ForwardLeft ReverseRight ForwardRight ReverseLeft
...so it sounds like the Reverse playback heads are engaged at the same time you play Forward, so you would hear those adjacent tracks backward. If you play the tape in the Reverse direction, is the Forward program audible (but backward)?
If so and in otherwise high fidelity, something in the Forward/Reverse head selection may be hosed.
Or, if the out-of-phase tracks are mushy and low volume, the physical tracking of the tape across the heads could be WA-A-A-A-Y bad. That would probably be visible as sideways distortion in the tape path. Shine a high-intensity light on the tape where is passes over the heads, then reverse it while watching where it sets up on the heads. It should be centered on the heads and not change its orientation when reversed. Compare where it tracks in motion with the probable visible wear marks (shiny bars across the heads perpendicular to the travel) where the tape has polished the heads over the years.
Or, the heads are so worn the coils pick up signals from their neighboring tracks.
Mar 04, 2010 | Quantegy 456 Reel-To-Reel Recording Tape
Gunk fused to record & playback heads of Onkyo cassette deck
The best cleaner for heads is Servisol Video 40. You can get it from Maplin's UK or Amazon.
Mar 19, 2009 | Onkyo TA-RW244 Single Cassette Deck
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
Distortion!
did you record them on the same unit?
It may be an alignment problem.
If it's the same unit, try cleaning the heads.
There are dat cleaning tapes too, but they beat on the heads.
Jul 31, 2008 | Sony Walkman TCD-D8 Personal Cassette...
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Image and sound problems at playback
your tape guides are out of calibration on all your pre - recorded tapes , or they are out of adjustment ( maybe even loose ) now ; - - put your camcorder close , next to your ear ? and . . . listen ! to a new tape in play mode - if you hear a fluttering sound like a deck of cards being shuffled softly , the camera is damaging all your tapes and needs alignment ;
Jul 28, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
Bad playback quality
Some possible cause of lines, noise or pixelation during playback are: 1. Dirty heads on the recording machine. If the heads were dirty at the time of recording, the dirty heads didn't record a strong enough signal on the tape. The damage is done for this tape and recovery is unlikely. Best advice here is to use only premium grade new tapes and keep your camcorder clean by occasionally running a cleaning tape. 2. Physical tape damage. Any distortion of the tape will result in mistracking and subsequent loss of data. 3. Built up oxide deposits or other debris in the guidepost corners can also result in tape edge damage. Keep your machine clean! 4. Improper tape storage - Even short term exposure to high temperatures over 130 deg f. can permanently damage the tape. The black cassette housing readily absorbs the sun's infrared rays and internal cassette temperatures can soar even if left in direct sunlight on just a warm day. It doesn't take much heat to slightly distort the plastic shell or ruin the tape contained within. * Try other tapes to ensure the problem lies within the tape and not the camcorder. * If the problem becomes apparent on all tapes, try a head cleaner. After cleaning the heads, the tapes may not play cleaner if the recording was done while the heads were dirty.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Tascam 302MKII Single Cassette Deck Logo
109 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
