Question about Noritz Tankless Water Heater Natural Gas N-0751m-od Ng
We hada power outage. The light on the power button from the noritz tankless water heater remote control does not come on.
    Scholar:
  • 73 Answers
I'd first try cutting electricity to the unit and then powering it back up; however, there's a good chance you unit was damaged from a voltage surge following the power return. If you have a volt meter, here are a few things to check:
-voltage across the gfi - the gfi is located on the bottom of the unit; it is a black box with a blue, white, green, black, and white wires coming into it. There should be about 100VAC across the blue/white and black/white pairs.
-If there's no voltage across either pair, your transformer is fried and needs to be replaced.
-If there is voltage across the blue/white but not the black/white, look for moisture in the bottom of the unit. If there's no visible moisture (indicating a leak), you may need to replace the gfi.
-If there's voltage on both sides of the gfi, measure voltage at the remote terminals (location depends on model). You should have 15VDC across the terminals. If there's no voltage, your circuit board is dead.
Good Luck!
Posted on Aug 04, 2010
I have a Noritz tankless water heater (model n-132m). I am getting an error code of 71. What does that mean?
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
Sep 12, 2014 | Noritz Commerical Tankless Water Heater...
Why won't my noritz tankless water heater come on after a power outage
reset circuit breaker fully off the on
power outage can call surge
check fuse on circuit board
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 13, 2014 | Noritz 6.3 Gallon Residential Tankless...
Error 71
EC 71 usually means you are using a battery backup that doesn't produce a pure sine wave. OR you recently had a power outage and it shorted the circuit board. if you have a battery backup try unplugging that and see if it works okay. If not, just call Noritz for a replacement c/b.
Dec 06, 2013 | Noritz 6.9 Gallon Residential Tankless...
How do I manually change the temperature on Noritz N-0631S tankless water heater if I don't have the optional remote controler?
There are temperature jumper clips located on the inside left wall of the heater. They will be in a small plastic baggie. The procedure is as follows:
1. disconnect power
2. install the jumper connector in the plastic slot located between the remote control screws on the circuit board (right hand side of the heater)
3. reconnect power
Mar 06, 2011 | Noritz Residential Heaters Tankless Water...
What is error code 043 on NORITZ tankless heater?
There is no error 43 on a NR71. There is a 73 error code which is caused by disconnecting jumper cables while the power is on.
Oct 29, 2010 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
What does F-76 code mean on a Noritz M-069 panel
F76 is a communication error. It usually occurs if you connect or disconnect a quick connect cable or remote control when the tankless heater is connected to electricity. (If you have a quick connect system, make sure you only have 1 remote and 1 quick connect cable.) To get rid of the code, try disconnecting electricity for 20 seconds, reconnecting electricity, and turning the remote on. If the code returns, you may need to replace your quick connect cable, remote cable, or even remote control
Sep 14, 2010 | Noritz 6.9 Gallon Residential Tankless...
We had a power outage. The light on the power button of the Noritz tankless water heater remote control does not come on. Help1
Good Luck!
Aug 04, 2010 | Noritz 6.3 Gallon Residential Tankless...
We have a noritz tankless water heater that we installed & it stayed on all evening, provided hot water etc. Decided to move the display & turned off. Now when we go to turn it on, it will flash...
check the wiring connections for your remote. The FF is related to communication problems with the remote. You should also reset the unit by disconnecting electricity, waiting 20 seconds, and then reconnecting electricity to the heater.
Apr 26, 2010 | Noritz 6.3 Gallon Residential Tankless...
I have a noritz water tankless heater and hot water stopped. Red light blinking three times. Need help.
Three flashes typically indicates the unit is overheating due to scale. I'd try a descale initially and see if that remedies the problem.
Dec 27, 2009 | Noritz 6.3 Gallon Residential Tankless...
Reset button for tankless water heater
you need to unplug the unit, wait for 30 seconds reset the temp to the lowest temp, then try it, if this does not work it might have done something to the circuit board, are you on a gfi out let it needs to be there is water and ele, and should be on the gfi with a reset on it,,
Jun 01, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Noritz Tankless Water Heater Natural Gas N-0751m-od Ng Logo
295 people viewed this question
Top Noritz Water Heaters Experts
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
