Question about Ovens
My Gold star MS-283MC microwave oven is not working now. When i switched On, the display showing '0'and than i press seconds or minutes button some times first press it is displaying and than stuck.I cannot proceed the second step(Even start or other buttons). Than i switched off the power and again switched On, the display showing fail.This is continuing always.No button is working after that one.Please specify the solution as soon as possible.
Krazytech
  • 725 Answers
SOURCE: display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Posted on Aug 26, 2007
Powerman
  • 68 Answers
SOURCE: GE Profile 2002 Wall oven JCKP18BA2BB Code faults
Try my solution for the F7 problem at the following link:
http://www.applianceblog.com/manuals/Dreaded_F7_Problem.pdf
I have shared this with over 1500 folks and most report success.
Please let me know. Also, what is your model number, how old is your oven and where are you located? I am making a study of this problem. You can email me at: hutchipop@yahoo.com
Posted on Jan 08, 2008
SOURCE: Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Posted on Jul 14, 2008
rylee_smith
  • 8619 Answers
SOURCE: F93 error. Oven door is stuck, won't open.
Hi
Thanks for using FixYa. F93 code means "Maximum oven door lock time exceeded." Actually it's trying to lock the door but is not aware of the time to stop. Please check the micro switch and lock’s motor. Replace whichever has gone bad. To reset it turn it off for more than 10 minutes and then turn it on.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 17, 2009
SOURCE: Digital display is blank. power is connected, oven
You need a new clock most likely.
Whirlpool oven repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 07, 2010
I have a double electric creda oven and i have just had the house re wired. becasue the power has been off the oven is flashing on the display at 0:00 auto and i cannot switch my main oven on as when i...
While holding minute minder and cook period buttons press + or - to set the time after time is set release buttons this should allow for normal operation
May 27, 2014 | Creda Ovens
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
I have a 720ef s/s built under oven. How do i set the clock
For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time
Jan 27, 2011 | Stoves 720EF Electric Double Oven
The display shows F 7 E 6, the oven buttons do not work but the broiler acts like its coming on but does not message. The maual asked to cut the power for 30 secs and restart. Tried that did not work...
http://appliancejunk.com/ge/cookingproduct/31-20105.pdf
Please find above your service and repair manual, use this to troubleshoot and resolve your issue
This website below will also assist in locating an reolving your problem.
http://www.acmehowto.com/howto/appliance/range/erange.php
E6 - Drain pump error Water level does not decrease to reset point within 15 minutes from draining water from the washer. Press POWER button. No other buttons work:
· Check wiring harness
· Check pump motor
· Check circuit board
0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
Aug 20, 2010 | GE Ovens
Simpson Apollo can't set clock so oven won't work
I don't know if this will help. For the 720ef , this is what you need to do.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Apr 30, 2010 | Stoves 720EF Electric Double Oven
KEMC308 has frozen, unusual looking display info. Nothing works.
Try unplugging it or flipping the breaker to the oven. Leave the power off to it for a minute, then turn it back on.
Mar 27, 2009 | KitchenAid KEMC308 Electric Double Oven
What does the error code F1 indicate, on a Wolf Oven?
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 24, 2009 | Ovens
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
Kitchenaid Convection oven
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
Mar 30, 2008 | KitchenAid KEWD105HSS Oven
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Ovens Logo
85 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
