Question about Refrigerators
Servis Fridge freezer It is noisy and snow forms on the back inside of the fridge. We altered the setting and it switched itself off completely. We thought it had broken down but it came on in the night much to our surprise.
  • 119 Answers
ICE/SNOW BUILD UP IN THE FREEZER SIDE? IF SO, YOUR BI METAL THERMOSTAT OR HEATER IS BAD. THAT NOISE IS PROBABLY THE FAN BLADE HITTING THE ICE THAT IS BUILT UP BEHIND THAT PANEL. GOOD LUCK
TIMOTHY DO 714-334-1998
Posted on Aug 04, 2010
Fridge not cooling
Sometimes the air duct bewteen the fridge and freezer becomes blocked with snowy ice what forms when the freezer has been running without an operative fan - solution switch the unit off with the doors open for 24hrs then clean close it up and switch it on - if it was snow problem will be gone - cheap and easy to give it a try
Feb 21, 2014 | Electrolux Refrigerators
Servis Fridge Freezer Model # M7973B-I/1 light flashing
Likely problem is the temperature setting control is failing.
Apr 04, 2012 | Refrigerators
Have a servis fridge freezer and it kept over freezing no matter what setting, ice would keep forming on back of fridge, and the motor never seems to go off. so i replaced the thermostat yesterday but...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Mar 30, 2011 | Refrigerators
Fridge freezer isnt cold as normal
I have a Servis Fridge Freezer but the fridge is not as cold as it should be I think it just seems cool because the Freezer compartment is working
May 24, 2010 | Refrigerators
I have a servis fridg freezer and the fridge is
sounds like the thermostat has packed in, it works as a switch for the compressor (which will be constantly on) if its a conventional model and should be replaced. if its a frost free it will be a control module thats faulty.
never work on a live appliance and get expert advice if you are at all unsure when replacing parts as if not isolated properly you will give yourself a nasty shock.
Jul 22, 2009 | Freezers
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Water forming in fridge part of fridge/freezer
check your gasket on the refrigeratordoor with a dollar bill. it should have resistance when pulled out from between the gasket and door. if not then replace the gasket. or the drain tube in the freezer compoartment is clogged up and not draining properly. good luck and contqact me if theres more to the problem ok.
Jan 11, 2009 | Refrigerators
Servis frost free fridge freezer makin crackin noise afew tyms a day
this is not unusual on any make. the cracking noise is the cabinet creaking with change in temperatue. don't worry about it
Oct 18, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Servis Fridge not cold enough
Hi ruthcart1,
I'm Harvey the Master Plumber.
Your problem is: You have a free standing fridge freezer from Servis (silver) and the fridge doesn't seem to be as cold as it should be. The freezer is absolutely fine just the fridge even though you have adjusted the thermometer inside.YouI've had it maybe 3/4 years.
You're still under warranty. Modification now voids the warranty. I would call warranty repair. This should be their headache not yours.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Refrigerators
Fridge freezer lights flashing
the flashing red light indicates a cooling problem,you should call honest local appliance repair shop(not sears they rob you blind)one other thing to try is to unplug for 5 minutes then plug back in and see if it reset sets itself,could be just a board reset issue,let me know-mike
Jun 10, 2008 | Freezers
Refrigerators Logo
208 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
