Question about Samsung HT-XQ100GT System
When i switch on the system, a blue circle with a line through it appears, then the system just shuts down. There is a dvd blocked inside.
How can I change language from Chinese to English in my phone Samsung gt s8000h
Hit the Apps logo on your home screen ( looks like a dice with 9 dots on it.
Now hit the Settings app ( Blue square with white gearwheel inside)
First apps are Connections ( blue circles with logos inside)
Scroll down past Device apps ( orange circles )
scroll down past Personal apps (Buff circles)
When you get to the System apps ( green circles) hit the first one (This is language and input)
When the menu opens hit the first one (this is language)
Scroll down to find the language of your choice.
Nov 16, 2017 | Samsung Cell Phones
System shuts down while playing movie
It is probably a oveheating problem
Jul 17, 2008 | Sony DVP-NC80V DVD Player
MY 2006 vtx 1800 SHUT DOWN WHILE RIDING I GO AROUND 10 -20 MILES THE BIKE JUST SHUTE DOWN EVEN ON THE INTERSTATE RIDING AROUND 80 MILES A HOUR
Hi, Joel and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a "LOAD" test if necessary, your battery may show 12.5 volts but have little or zero amps and needs to be replaced.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, stator, magneto, points/condenser ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. Fuel tank contaminated with ethanol sludge.
15. The gas cap is not venting properly or fuel tank venting system blocked.
16. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
17. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
VTX 1800 Stalling while riding
VTX 1300 engine shut down problem
https://motosvit.com/HONDA%20vtx1800/Manual.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda 2005 VTX1800C Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 02, 2017 | 2006 Honda VTX 1800
Want to block sms
Easy.
In your "MESSAGE" Window... (on my I-Phone)
Look at the top right corner (after the sender's number)
press the blue word "Details"
another window will appear that shows a
small blue telephone handset.. AND a circled "I"
Press the Circled 'I'
and scroll to the bottom of the next page
You will see "Block this Caller".
Your phone will ask you to confirm the block
Do so...
and you are done!
Exit carefully... "Unblocking" requires no confirmation."
Are these phones cool or what?
Nov 11, 2015 | Cell Phones
What does hdmi is blocked mean
Hello!
HDMI blocked could mean, that one or more HDMI inputs are turned off. In WD- series DLP TVs it's possible to disable one or more inputs, which are not to be in use, to speed up signal source switching. Most of modern sets are constantly monitoring inputs and automatically recognizing "plug"n"play" signals. blocking any input would not cause TV to shut down.
Yellow(amber) light means: lamp door interlock switch is off or malfunction. green blinking: set is initializing, about to begin normal operation. So: quite possible that lamp has been replaced incorrectly or door is not tight intermittently. Last possible issue: door's interlock switch is bad. Take lamp door off and you will find the switch with blue lever on the left side of the door inside plastic compartment. Push it with your "pinky" or pencil carefully, then ask someone to turn set on. Make sure, yellow light is off, before do so. If set starts normally, observe lamp's activity: it should stay on and getting brighter, while you holding switch. If lamp stops working, while there is no "amber" light, then TV shuts off, red blinks, lamp is bad. I just had to replace lamp twice, due to defective batch of lamps with housing. 3rd time I replaced bare bulb and it solved the problem. But there was no "amber" issue!
good luck,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
I can not close my front door. it appear that the half circle locking part of the door, which is located on the side of the door that opens, has a piece of medal that is blocking the door from closing. I...
Try to hold the door handle in the open position while you pull on the door latch, the medal piece, should open so that the door will shut close.
Dec 01, 2010 | 2001 GMC Denali
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Samsung HT-XQ100GT System Logo
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
