Question about Pioneer PDP5016HD 50 in. Plasma Television
How can I perform a factory reset on Pioneer PDP-506HD? (I'm at work now) Wife saw TV shut down several times to standby mode. She is 9-mos pregnant and cant physically move the TV/uplug cords as suggested by the Pioneer support center. As my manual is in Japanese, I can't read it. And support won't tell her the full steps to do a reset...
thedayos
  • 57 Answers
SOURCE: Pioneer PDP-R06U media receiver
On this model, this is a "fault code". The unit has attempted to power up and the processor has determined a fault with it's "self check" diagnostic test it runs each time the unit is turned on. A technician will have to test the unit to determine the nature of the fault.
Posted on Feb 27, 2009
  • 3 Answers
SOURCE: Pioneer PDP-5030HD power supply
click link -ebay shop selling power supply boards for 503hde/pe at 180 pounds you will have to contact him has he does not list them as pioneer are only ment to replace these boards or shops under contract with pioneer i changed mine and only takes min's when you have got the back cover off...
http://stores.ebay.co.uk/Plasma-Parts-UK
hope this helps mark doran
Posted on Mar 17, 2009
SOURCE: pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
Posted on Mar 29, 2009
  • 41 Answers
SOURCE: pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Posted on Mar 30, 2009
SOURCE: My Pioneer PDP-507CMX won't turn on. Standby light
wot is buttons&ir lock
Posted on Sep 05, 2009
How do i fix pioneer tv model pdp 5070pu power an standby lightsturn on but tv an remote does not work
Do a hard reset to this set, and then check. If it do not help, the main digital board is faulty. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 27, 2016 | Pioneer Televison & Video
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
Unit will shut down and go into standby mode blue standby light will flash 12 times
its a B+ OVER CURRENT PROTECTION it could be you have a short in the in the power supply of any circuit pertaining to the power supply check T602 AND R672.good luck.
Sep 13, 2011 | Pioneer PDP-5010FD 50 in. Plasma HDTV
Pioneer pdp 507cmx has no sound does this tv have speakers
Yes,every tvs have a basic pair of speakers.Tries tv unplug,replug it back like about an hour later.Go into the tv Menu go to PICTUTRE SETTING go down to do a resetting for a back to factory setting of the whole tv main Tuner signal board.Go to Audio Setting go down to a resetting for the factory audio setting.Tries these steps,tv now should have sound back.
May 10, 2011 | Pioneer PDP-507CMX Television
Lost the color on my pioneer 50 inch tv
Hello
Your Tv may be misadjusted by any way I thinks. Set all the modes to factory defaults. To set it to factory defaults do the folloing:
1 Press HOME MENU
2 Select "Option with (UP or DOWN button then ENTER)
3 Select RESET with (UP or DOWN button then ENTER)
confirmation screen appears. Press [ => or then press ENTER
This process will reset all the parameters to factory set levels. You have to adjust the Parential controls and other parameters by yourself later.
OK
Jan 20, 2011 | Pioneer PDP-5070HD 50 in. Plasma...
I have a pioneer plasma tv about 2 yrs old.It goes to standby mode every 30-40 min.Even when shut off it will return to stdby???Thanks
check batteries on ur remote even hide it in other room/if not it could be power supply over heats it
will shut down/another thing go to menu reset to factory default.
Jan 05, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
My Pioneer PDP-435XDE was taken down to decorate the wall it is currently mounted to. When re-mounted and connected it happily goes from Standby to ON for about 10 - 15 seconds and then trips itself back...
did you try althe different inputs, maybe it's a unsupported signal being ent to the tv, liek a HD resolution that the tv doesn't support?
change the input and see if you can get anything to display. if the tv continues to go into ower up and standby no matter the input, it needs service.
Sep 10, 2009 | Pioneer PureVision PDP-435XDE 43 in....
PIONEER PDP-424MV Plasma TV
I have the same TV, well, nearly, PDP434.
The only part I ever sell for these is the main PSU (power supply).
The TV "checks" it self using a self diagnostic system. As soon as it discovers a problem, it shuts down and blinks an error code on the front LED.
It always seems to be the PSU.
I hope this helps at least a bit.
Mar 28, 2009 | Pioneer PureVision PDP-424MV 42 in. Plasma...
Pioneer PDP5016HD 50 in. Plasma Television Logo
355 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
