Recently moved apartments. After reconnecting my computer when I start it up the screen shows 'S-SUB Power Savimg Mode and then goes to sleep'. Any thoughts on how to resolve?
    Brigadier General:
  • 7,191 Answers
Please elaborate the problem providing us with more details like the brand and model number of the computer and the monitor. Also, let us know the type of connection you are using to connect the computer to the monitor (VGA, etc)
Usually, this problem is seen when the monitor cable is not connected securely or the cable is damaged. It can also be due to a malfunctioning video card of your computer.
Kindly reply to this post with the details. Thanks for using FixYa.
Posted on Aug 04, 2010
I put my Dell Dimension 9200 XPS 410 into sleep mode after connecting a wireless keyboard and mouse and the only way to wake it is to hold the power button in until it shuts off and then switch the power...
I would say it is in the Hibernation Mode To get it out of this mode you need to go to your Control Panel, open "POWER OPTION'S" and deselect the Hibernation mode then reboot.
Sep 26, 2013 | Dell Dimension 9200 PC Desktop
My computer is stuck in sleep mode and it says to touch any keys or move the mouse, i did and nothing is happening, i have restarted and same thing. just a blank screen. please heklp
turn off computer and remove power cable
and reconnect power on
by pressing F8 go in to SAFE MODE REMOVE ANY TEMP FILES RESTART MAY FIX UR PROBLEM
Mar 01, 2012 | Dell Inspiron 530s Desktop Computer...
When I turn the monitor on I get a message "In
Most Dell LCDs have multiple inputs and they will go into "standby" while waiting for a signal from your PC. This happens when your PC goes into "sleep" mode or if you are sure your PC is not in "sleep" mode then usually the LCD is not in the correct input selection. Check the input selection for the appropriate input. As always, make sure the cables are securely connected. Hope this helps.
Jun 15, 2011 | Dell E173FP 17" LCD Monitor
Hi ,My dell screen goes to sleep mode after a long wait of not being used, say an hour, ..............but the pc sleep is not set ? The message comes up to move mouse ,or press any key ,but this does not...
please check your monitor settings may be sleep time is defined there. secondly check your system sleep time again. and also check window power saving mode. may be your system goes to power saving mode.
If you like this rate me kindly
Oct 12, 2010 | Dell E153FP 15" LCD Monitor
My HP 2009m goes into sleep mode & shuts down
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
Feb 15, 2010 | Computers & Internet
Computer goes to sleep before it even starts up
Hi there, it appears as though the Power Options are set too short a time and the PC is going into sleep mode. Go to Start menu/Control Panel and look for Power options. Set them all to "never" This will prevent her PC from going into sleep mode. Good Luck.
Oct 26, 2009 | Dell Dimension 4600 PC Desktop
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Monitor going to sleep
Within the control panel select performance and maintenance within that select power options.
Once in there check that the power is set for desktop computer and that never sleep on monitor or Hard disks.
If this doesn't work then press the OSD button on the monitor and scroll through the setting and make sure that there isn't one that is auto sleep mode after and amount of time.
Thanks J
Jan 02, 2008 | HP Pavilion Media Center TV m7360n...
Computers & Internet Logo
19 people viewed this question
Alun Cox
David Payne
David Payne
