Question about Vacuums
The top of my 500ml/0.6qt thermal vacuum flask is broken and i'm not sure if i can get a replacement as the thermos is still okay. i would be grateful to know if i can get a replacement top so i don't have to buy a new one. Thanks meryl hawkins
  • merylhawkins Aug 04, 2010
    I do not want to spend too much money on this enquiry as i could have brought a new one
    thanks meryl hawkins
  • 3,230 Answers
Well yes you can purchase a separate flask for your thermal vacuum, you may purchase them from the dealer or you can please post the brand of your thermos so we can help you to find the part.
Good Luck!!
Thanks
Posted on Aug 04, 2010
Vacuum stopped working. I think it overheated and I cleaned it out really well. Still won’t start
These days many electrical appliances are protected by a thermal fuse or breaker so overheating will cause the circuit to be broken. The thermal breaker should in theory reset itself when the motor cools but that isn't always the case in practice. The thermal fuse needs replacing when it "blows".
It might be by complete coincidence something completely different but the only way to discover the fault is to dismantle the cleaner and check the circuit with a multimeter.
Mar 03, 2018 | Vacuums
Can I safely bypass the thermo switch on my Panasonic vacuum cleaner? It has a chronic issue of shutting down after vacuuming about 200 square feet of carpet.
I would make sure the filters are clean for this vacuum. Dirty filters will cause a motor to overheat and trip the thermal switch. If this machine has bags make sure the bag is not full. On some machines there is a filter under the bag where it meets the motor housing. I would not recommend bypassing the thermal switch. It is there for your protection. The motor could possibly burn up without it.
Oct 12, 2014 | Vacuums
How do I repair an Olympia 2ltr Vaccum Flask that only keeps liquid hot for 2 hours
It may not need fixed.
Always preheat (or precool) a flask prior to use.
Fill it right up to eliminate any airspace above the hot liquid. That will help to keep things hotter for longer.
If this still does not work, the outer skin of the vacuum flask may be damaged and there is no longer a vacuum to insulate the contents.
Aug 12, 2014 | Vacuums
Riccar vacuum Moon 1 just won't turn on, any ideas?
Check cord, esp at entry point. Otherwise it may be switch, motor windings burnt out, broken wire, carbon brushes worn. Some appliances also have a thermal fuse, which is a silver tube shape.
Apr 13, 2013 | Riccar Moon, Pazza Vacuum Cleaner...
Is there a trigger handle to turn off and on
no betty, stupid bit of kit imo, no operating switch, just on/off at the switch, which heats the water up. i measured 500ml of water heated using my kettle, put the top on, switched on, and waited. first time the steam didn't come out of the nozzle, so i removed the end and cleaned the nozzle with water, blew down the end from the big end, and replaced it, steam came out. big grumble though, the steam coming out is not that warm, don't advise you to, but i directed against my fingers, it's only hot at the exit of the pointing bit, used it to try and clean floor tiles and grout, complete waste of time. i wouldn't advise anyone to buy one.
Dec 11, 2011 | Tristar SB Steam Buggy Vacuum
Where can I buy a stopper for my Aladdin flask no. SB950H stopper has a piece broken off the side and will not seal regards Maureen Perry (Australia)
Hello, well over here in the US we have several places. You can rubber or cork stoppers stoppers at Lowes or at an Ace Hardware store. Not sure what you will be putting in the flask but if you are looking to purchase on line, then check out Fisher Scientific. Enter the search term flask stopper and a whole gaggle of selections come up for you to click on drill down and read the type you want. They have glass, rubber, silicone and all kinds of stoppers.
Feb 13, 2011 | Vacuums
Why does my vacuum cleaner quite working about two minutes into vacuuming? It just shuts off. I have the pet fur picker upper version
Sounds like overheating of motor operating a thermal cut out ..Clean all filters you can run machine with no filters fitted to try if okay first.....
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
DC07 cutting out
I sounds that your thermal fuse is cutting out. By no means try to bypass this thermal fuse. It protects your product from catching on fire. Replace the thermal fuse at a service center. How old is this product?
Okay,
Spurs21
Feb 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover windtunnel will NOT turn on
You have to remove the motor cover, There I believe 5 screw, take off the light lens and remove the screw holding the light. It should then pull off. You say you have power to the Vac, but do you have power to the motor. There also is a thermo by the motor, sometimes they open up, then the motor won't run.
Dec 27, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
337 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
