When put on my washer, the water gets in and also starts pouring out without stopping and hence it does not start agitating to wash the clothes
  • 119 Answers
YOUR DRAIN HOSE IS CONNECTED WRONG. THE HOSE HAS TO BE HIGHER, ABOUT THE HEIGHT OF THE WASHER. IF YOU ARE JUST LAYING THE HOSE ON THE FLOOR, THE WATER GOING IN IS GRAVITATING AND RUNNING OUT, THUS THE LEVEL IS NEVER REACHED AND THE LEVEL SWITCH NEVER SEE THAT THE WATER LEVEL IS REACHED AND WILL NOT GO INTO WASH CYCLE
TIMOTHY DO 714-334-1998
Posted on Aug 04, 2010
Started a quick was cycle to test washer without cloths. It agitates for about 10 seconds, stops for 5 seconds and agitates for 10 seconds again. The light array is suggesting it is going from wash.
new washers usualy start a brief agitate then locks the door and then starts watering again. depending on washer model it can do this a couple times to evenly soak the clothes at the start of a wash cycle. it is advised to not run full cycle in the washing machine with no clothes for it can damage the unit.
Jul 07, 2016 | Whirlpool Compact Stackable Front-Load...
How do I fix a ge top load washer that's making a loud banging noise while agitating?
There is either a balance issue or a damaged spring. Usually all you need to do is open the washer (make sure it is OFF) wait for it to stop spinning... then look for clothes bunching up on one side. Take some out ad move them around.
Sometimes putting in to many or too few items will make it harder to resolve. Items like large towels or several towels, sheets and such will hold more water and be heavy until the water starts to pull out.
Oct 09, 2014 | Washing Machines
How to clean wash machine tub
with acetic or formic acid its clean the calk residu
Jun 28, 2014 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Could SOAP DISPENSER be caked with soap???
POWDERED DETERGENTS GET CLOGGED ALOT IN THOSE DISPENSERS. I ADVISE CUSTOMERS TO FILL THERE WASHER AND ADD SOAP WHEN IT STARTS TO AGITATE WHEN USING MORE THAN A 1/2 CUP OF POWDER ... THEN ADD YOUR CLOTHES ... THE WASHER HAS A SAFTEY SWITCH WILL STOP MOST WASHERS WHEN AGITATING OR IN SPIN CYCLE,SO YOU CAN LOAD CLOTHES ... OTHER THAN THAT ... ALL YOU CAN DO IS KEEP THAT DISPENSER FLUSHED OUT WITH HOT WATER AFTER EVERY WASH. JUST POUR HOT WAYER TROUGH IT ... IF THE WATER BACKS UP (EVEN WITH A SLOW POURING) THE DISPENSER IS PLUGGED AND NEEDS TO BE FLUSHED OUT WITH A HOSE. GOOD LUCK AND STAY DRY !!!
Apr 29, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
