Colors seperated on our projections TV. The magic focus will not correct. Convergence went out and it's a common problem. Am trying to find out the part and want to fix if I can. Hitachi 53SBX10B
  • 8,617 Answers
Remove the back panel on your tv and look at the large heat sink on the far right side and you will see the big black ICs let me know the STK numbers off them and I will post a link where you can get replacements and they will give free step by step instructions with pics so you can do the repair yourself which takes about an hour.
Posted on Apr 26, 2008
Colors on tv are seperating. looks like double images.
Hi, Try the auto convergence or auto focus to eliminate the problem, if this does not work, you may have to get the TV repaired, the common problem are the power amplifiers that correct the color convergence, that is why you get color shades or ghosts in the images.
Nov 29, 2010 | Hitachi 50UX57B 50" Rear Projection...
Convergence
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 06, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Lookslike the picture is in 3d and when i try ti use magic focus
  • Screen looks 3D
Jun 02, 2010 | Hitachi 57F500 57" Rear Projection...
The screen looks as if it is 3D. The colors are all offset.
  • Screen looks 3D
May 31, 2010 | Sony KP-57WS500 57" Rear Projection...
It appears to be convergence issues. Red, green,
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
The tv will not automatically come into focus
U have pictures out of focus?Like pictures colors seperates in lines?Ur tv convergence are dead.U know how solders?Must replaced 2 STK convergnece ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Hitachi 43UWX10B 43" Rear Projection...
All three colors have seperated and appear kind of like a 3d movie. Is this something we can fix on our own? We have experience with soldering and minor electrical repair. Any help, guidance, repair...
  • Screen looks 3D
Feb 26, 2010 | Samsung HCL552W 55" Rear Projection...
Color seperation
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Feb 25, 2010 | Hitachi 43FWX20B 43" Rear Projection...
My tv went multi colored take it as it looks like a 3d television
  • Screen looks 3D
Feb 20, 2010 | RCA HD61W66 61" Projection HDTV
Sony KP-WS500 bowed picture and colors seperated and out of focus
  • Screen looks 3D
Nov 22, 2008 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
