Hello, I have a Goldair Dehumidifier model no GD300. It has limited instructions as to the control panel. The settings are as follows; wet,cosy,dry, cont. What do these settings mean and does each setting use more power, thank you, Irvine New Zealand
    President:
  • 1,734 Answers
I tried to locate the manual with google+, but unfortunately had no success. You could ask some specialized manual search engines, like here or manualsparadise.com. The search services are not for free, but most times worthy - saved my live more than once.
Posted on Mar 20, 2013
  • 52 Answers
SOURCE: the control panel got wet when the air conditioner
Replace control board.
Posted on Mar 07, 2010
SOURCE: require instruction manuals
http://www.haieramerica.com/en/support/modelsearch go to this link hope this helps
Posted on Jan 09, 2009
  • 141 Answers
SOURCE: Given a new control panel but I can't follow the instructions
can you send me copys of the units wire diagram
Posted on Apr 18, 2010
hvac1960
  • 2133 Answers
SOURCE: Hello I need instructions on setting
There are 2 systems in timer set up. You follow as per your remote supports.
1. Set clock first. and then by pressing timer on make the time you need on. and same for off by timer off.
2. Press timer on which starts with 00.00. By pressing you can select how many hours after you want to switch on from current time and same for timer off. Is it useful? Write.
Posted on Dec 11, 2010
  • 4736 Answers
SOURCE: I have a model 129-25804
Since it's a Sears house brand, you can find and download the Owner's Manual at Sears Parts Central.
Thanks for choosing FixYa.
Posted on Sep 14, 2011
Does anyone have a manual for a Goldair FP570 Food Processor, please?
Try Googling (goldair)(FP570)(manual) without parens.
May 12, 2018 | Food Processors
Goldair dehumidifier GD-2020 has stopped working? 'CONT' light on front panel flashing and now cannot get to operate?
cont button just means continuous run mode . the power light is lit , the full light is out . try reseating the water catch bucket a few times , most machines have a safety that wont allow the thing to operate if bucket isn't just perfect in its slot (you don't want water on your floor )
May 23, 2015 | Dehumidifiers
How to adjust the humidity level
Hello Friend, that's a great question!
In order to better assist you I would need your model number please. The serial tag, which lists your model number, is typically located behind the bucket on your dehumidifier. Also, what is the size of your room/basement? Where is the dehumidifier located? What setting is your dehumidifier set on? With this material I can provide you the correct information. Thank you! - Z
Sep 03, 2014 | Dehumidifiers
What should the setting be set on this dehumidifier when used in a small space?
May I have your model number please? The serial tag, which lists your model number, is normally located behind your dehumidifier near the bucket. Also, what is the size of the room where your dehumidifier is located? With this data I can provide you the correct setting information. Thank you! - Z
Aug 31, 2014 | Frigidaire Dehumidifiers
I lost my manual and dont no how to operate my goldair gac 700w cooler
HOW DO I CLEAN THE TANK FROM THE GOLDAIR AIR COOLER (MODEL GAC-700W)
Dec 01, 2013 | Heating & Cooling
Goldair electronic timer manual
1) Copy following links to help identify timer and download possible manual for goldair timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
http://waterheatertimer.org/UPM-timers-and-manuals.html
http://waterheatertimer.org/How-to-set-timers.html
2) Add a comment and clearly describe timer and timer buttons and what you have discovered using possible manual from link above.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 26, 2012 | Leviton 6124H 24 Hour LCD Programmable...
HOW TO USE
follow the instructions below on how to use your dehumidifier:
Prepare the room for the dehumidifier by vacuuming, dusting and cleaning the room. Be especially careful to have all mold removed prior to using the dehumidifier.
Plug in the dehumidifier into a grounded outlet.
Set the dehumidifier to high in order to remove excess moisture from the room.
Wait for the dehumidifier to run several cycles, removing all undesired moisture from the air. This may take days or even weeks in especially damp rooms.
Adjust the setting of the dehumidifier when the air has reached your desired comfort level. Make the setting one that will maintain the current conditions.
Good luck.
Aug 16, 2010 | Woods WD25G Dehumidifier
Heating & Cooling Logo
424 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
