Question about AMD ASUS A7N8X-VM/400 Motherboard
When i start the computer not bootup befor few days its working fine but when i start the computer its need always press f1 to continue i replace the cmos battery but still problem same but now a days its not working finally so what will i do please help me.
    Guru:
  • 825 Answers
While computer starts before pressing f1 key press del key... you will go into the bios of *********** board... you can change these alert settings there... you will have an option that says wait for F1... select NO to that option and save the settings and exit from bios...
Posted on Aug 04, 2010
Keyboard failure message during bootup
There's a good chance that all you need to do is replace the battery which most likely is a cr2032
Jan 17, 2012 | Dell Dimension 8300 PC Desktop
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
MY DESK TOP TOWER RED LIGHT IS ALWAYS ON THESE DAYS. ALSO I NOTICE AFTER I START MY PC AFTER A FEW SECONDS ,THE SCREEN SHOWS STUFF WHICH INCLUDES PRESS F1 TO CONTINUE THEN AND ONLY THEN THE COMPUTER...
It seems a bad CMOS BIOS battery, normally this is a "coin" type alkaline battery located inside CPU, to replace it, you must have access to the motherboard.
Feb 15, 2011 | Computers & Internet
UnKnow Bios error Error Code =8302 Sr, Computer Opening No Display ....F1 Press Continue Display Ok
Hi, this can be caused by a BIOS update or a faulty motherboard battery. You can reset BIOS to default settings by pressing the F1 key during bootup, which will take you to the BIOS screen.
Aug 04, 2010 | MSI P4M900M-L Motherboard
Service centre at nagpur for brother printer and for buying the printer
when i start the computer not bootup befor few days its working fine but when i start the computer its need always press f1 to continue i replace the cmos battery but still problem same but now a days its not working finally so what will i do please help me.
Aug 04, 2010 | Computers & Internet
Virus in the hard disk
Tapping F8 key during bootup, to go in Safe Mode. Login as administrator.
After getting upto desktop, run the Checkdisk command and run a complete system scan with your Antivirus. Let me know the status after this, I will further investigate and fix the problem.
Oct 09, 2008 | Microsoft Windows 98 for PC
Computer keeps crashing!
Thanks for your posting in FixYa.
Please can you reboot your PC in "Safe mode with Networking".
Tapping F8 key as soon as PC bootup.
Let me know if you are able to work in it then.
Regards
ELLIN
Sep 23, 2008 | Dell Inspiron 6000 Notebook
Bootup
Have you tried changing the cmos battery on the motherboard?
Jan 07, 2008 | Computers & Internet
Want bootup says checksum bad
Usually, the message you are seeing is displayed when your CMOS loses power abnormally. Even when your computer is turned off, there should always be a low-level charge from the battery, keeping track of your PC's clock, and storing information about your BIOS settings.
If the CMOS battery is dying, it will produce a weaker charge, or continuously start and stop providing power, which will trigger that message. as a result, you are losing all your BIOS settings that you are configuring each and every time, and getting that message when it happens.
It's odd that you would be getting that message when you replaced the battery, but I'd try replacing it with another one just to be sure. If it doesn't fix the problem, the motherboard may need to be replaced. In this case, the problem could lie with wireing between the casing and the chip, or even be in the chip on the circuit board itself.
You could also try flashing the motherboard, but only use that as a last resort- you could finish toasting it. Also, I can't guarantee it would fix it in the future, as all you're doing is adressing the symptoms, and forgetting about the cause.
Dec 30, 2007 | MSI K8MM-ILSR Motherboard
When booting system I get message: Hardware Monitor found an error. Enter power setup
this is a sign that your cmos battery needs replacing on the motherboard its a cr2032 flat disc shaped battery and normally resides near the memory slots. The battery being flat is losing all the hardware and bios settings, F1 just passes this check and allows a boot, you will probably find the time and date is incorrect which is a sure sign of battery problems
May 27, 2007 | Sony VAIO PCV-RX753 PC Desktop
AMD ASUS A7N8X-VM/400 Motherboard Logo
83 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
David
David
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
