Question about LG Dishwashers
Dishwasher has an HE error code? - LG Dishwashers
    President:
  • 1,382 Answers
"HE" is a "HEATER ERROR"
These are the possible causes for "HE" error:
1. The Circuit of Heater is troubled.
2. The Thermistor is troubled.
3. The Heater is shorted.
4. The Relay Circuit is troubled.
The Possible solutions are:
1. Repair the Circuit of Heater.
2.Replace the Thermistor.
3. Replace the Heater.
4. Repair the Relay Circuit..
Thank you !!
Posted on Aug 04, 2010
F21 fault code on Electrolux dishwasher. What does it mean and how can i clear it??
Electrolux Dishwasher Error Code 01
Fault Condition: Water Leak Is Detected (Sensor under the dishwasher detected a leak)
Repair or Check: Remove power to the dishwasher. Check hoses, pumps, and tub to find the leak. Replace any parts leaking.
Parts Required: Drain Hose - Drain Pump - Recirculation Pump
Electrolux Dishwasher Error Code 02
Fault Condition: Thermistor Sensor Fail
Repair or Check: Remove power power to the dishwasher and check the thermistor sensor circuit wiring. If the wiring checks out then replace the thermistor sensor.
Parts Required: Thermistor Sensor
Electrolux Dishwasher Error Code 03
Fault Condition: Wash Motor Fail
Repair or Check: Remove power to the dishwasher. Inspect the wiring for the wash motor. If the wiring checks out then check for an blockage in the pump. Replace the wash motor if the pump is not blocked and the wiring checks out.
Parts Required: Wash Motor
Electrolux Dishwasher Error Code 04
Fault Condition: Upper Fan Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the upper fan. If the wiring checks out then replace the upper fan.
Parts Required: Upper Fan
Electrolux Dishwasher Error Code 05
Fault Condition: Upper Fan/Vent Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the upper fan vent. If the wiring checks out then replace the upper fan vent.
Parts Required: Upper Fan/Vent
Electrolux Dishwasher Error Code 06
Fault Condition: Lower Fan Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the lower fan. If the wiring checks out then replace the lower fan.
Parts Required: Lower Fan
Electrolux Dishwasher Error Code 07
Fault Condition: Drain Valve Fail
Repair or Check: Remove power to the dishwasher and check the wiring for the drain valve. If the wiring checks out then replace the drain valve.
Parts Required: Drain Valve
Electrolux Dishwasher Error Code 08
Fault Condition: User Interface Control Fail
Repair or Check: A switch on the user interface is possibly defective. Replace the complete user interface.
Parts Required: User Interface Control
Electrolux Dishwasher Error Code 09
Fault Condition: Communication Fail From User Interface Control TO Electronic Control Board
Repair or Check: Remove power to the dishwasher and check for any loose wiring connections between the user interface control and the electronic control board. If the wires and connections check out then replace the user interface control. If the problem persists then replace the electronic control board.
Parts Required: User Interface Control - Electronic Control Board
Electrolux Dishwasher Error Code 10
Fault Condition: Electronic Control Board (Relay) Fail
Repair or Check: A relay on the electronic control board possibly failed. Replace the complete electronic control board.
Parts Required: Electronic Control Board
Electrolux Dishwasher Error Code 11
Electrolux Dishwasher Error Code 12
Fault Condition: Drain Valve Position (Drain valve has activated when it should be turned off)
Repair or Check: Remove power to the dishwasher. Check the drain valve wiring for an issue. If the wiring checks out then replace the electronic control board. (This is because the drain valve relay on the control board is stuck) If the problem persists then replace the drain valve.
Parts Required: Electronic Control Board - Drain Valve
Electrolux Dishwasher Error Code 13
Fault Condition: Electronic Control Board Fail
Repair or Check: The control board has a component failure. Replace the complete electronic control board.
Electrolux Dishwasher Error Code 30
Inconsistency between level on electronic pressure switch and level on anti boiling pressure switch.
Electrolux Dishwasher Error Code 50
Fault on the wash motor circuit. On some Electrolux dishwashers the motor has a control board located at the back at the bottom just behind the wash motor.
Jun 18, 2018 | Electrolux Dishwashers
Frigidaire Dishwasher has error code i30 and drain pump still runs even with door open. Tried power cycle and comes right back on running and error code i30.
Error Problem / Condition = Clogged filters or a restricted drain line has been detected. ... If the drain line is attached to a disposer, check that the knockout plug has been removed. Frigidaire Dishwasher Error Code = i30. Error Problem / Condition = A leak or over flow of water has been detected in the bottom pan.Feb 18, 2016
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-how-t...
Text info here
Frigidaire Dishwasher has error code i30 Google Search
Jun 09, 2018 | Frigidaire Dishwashers
What does code Uo mean on the dishwaher
It is a Vent problem. The vent aids drying at the end of the cycle.
Frigidaire Diswasher ER UO Error code [FIXED] - Appliance Repair ...
forum.partsdr.com > Forum > Appliance Repair Help > Dishwasher Repair
May 25, 2012 - 20 posts - ‎3 authors
The ER UO error code means "Vent Open". On the top back right corner of the dishwasher tub, there is a vent and fan that opens to help dry the ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-ho... Feb 18, 2016 - The error code will display where the usual numbers are on the display screen. .... Do you have an error code on your Frigidaire dishwasher and need ..... Can you tell me what do you mean by "knockout plug has been removed"? ... Frigidaire dishwasher manual says UO error code is vent assembly error.
Diagnose UO Error Code - Dishwasher - YouTube
? 3:15
https://www.youtube.com/watch?v=pvJTiTd35vI
Dec 22, 2016 - Uploaded by Byrd Appliance Specialists
Byrd Appliance Specialists 3825 Gilbert Dr., Ste. 342 Shreveport, LA 71104 www.byrdas.com 318-459-8745 ...
My Samsung washing machine is showing a UE code during a spin ...
www.samsung.com/uk/support/skp/faq/1025292 Jul 5, 2016 - Your appliance will display a UE code when it has detected an unbalanced load and has stopped the ... If the door remains locked and the machine is displaying UE error, please run a drain program. ... What does this mean?
LG Help Library: Error Codes - Dishwasher ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library May 10, 2017 - An error code on the display of the dishwasher can usually be resolved by performing a few simple troubleshooting steps.
LG Help Library: UE Error Code - Top Load Washer ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library Sep 1, 2017 - After 3 attempts to balance, the uE will change to UE, meaning the unit was unable to rebalance the load and requires assistance. To determine ... What does code UE mean on the dishwasher Google Search
Oct 31, 2017 | Dishwashers
Error codes
Check out this website: http://www.searspartsdirect.com/dishwasher-repair/error-codes/samsung-dishwasher-error-codes.html
Feb 12, 2017 | Washing Machines
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Bosch Dishwasher fault E 15 explain
Bosch Dishwasher Error Code E15
Fault Condition:No water in dishwasher or not sensing water.
Repair or Check: Tilt dishwasher back and the error code should disappear. While you tilt it press off button to clear. Stand it back to normal turn back on and dishwasher should run normally.
Parts Required:Tilting machine
Hi i found this answer on this link, scroll down the page and it's the 3rd error code (in red) Hope it helps...
https://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Mar 16, 2016 | Bosch Dishwashers
Error code E3 on Samsung DMS500TRW dishwasher
3E error in Samsung dishwashers normally relates to high temperature error. This means the dishwasher is detecting over 80deg C water temperature. However if it is 5E that means drain error. If your dishwasher is draining correctly then please check the error again.
Apr 14, 2014 | Dishwashers
Dishwasher error code P0
Hello Alan Gibson - Are you certain the error code is P0? This manufacturer does not have an error code P0 for any dishwasher or other units. Could you please try reprogramming the unit by flipping the household circuit breaker off or unplugging it? Wait approximately ten minutes and restart dishwasher. If the unit is experiencing a generic communication error, it should be follow by another fault code. What is the error code? If it continues to display P0 then consult a professional to move forward accurately.
Feb 05, 2013 | Electrolux EWDW6505GS Fully Integrated...
I have 5E showing on my dishwasher. What is does this error mean?
ost common error codes that are caused by installation errors are:
  • 5E. If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose. A good indication that the drain hose is kinked is excessive water in the bottom of your dishwasher after a cycle has been completed. If your dishwasher is displaying error code 5E, your dishwasher will have to be removed to inspect the drain hose for kinks. If your dishwasher was professionally installed, contact the installer to remove the dishwasher and inspect the drain hose. If you installed the dishwasher your self, the dishwasher will have to be removed for drain hose inspection.
  • Info provided by Articlead.com
Dec 09, 2010 | Samsung DMR57LF Builtin Dishwasher
Dishwashers Logo
403 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
