Question about Magic Chef Cooktops
Hi I have a gas stove top - all it says on the top is CHEF. Can't find a model number - where should I look as I need to try and work out how old it is. Thanx
  • Magic Chef Master
  • 43,501 Answers
The model and serial will be on a sticker on the under side of the cooktop somewhere...
heatman101
Posted on Aug 05, 2010
I own a Maytag Glass top electric range stove. Model # PER5710BAC. The glass stove top cracked straight down the middle, and one of the bigger burners doesn't heat up anymore. Is there any way to repair...
You could try purchasing replacement parts from a local appliance parts supplier and you might be able to get advice on making the repair. The supplier can advise you of the cost, allowing you to decide whether it is economically worthwhile to repair the range. You also have to consider your degree of confidence in your ability to do the necessary work
Sep 29, 2013 | Magic Chef 30 in. 8241RT Gas Cooktop
Magic Chef Gas Stove Model CGC2536. 1. On just one of the 5 burners the"Lite" function doesn't work. On all the others you hear clicking, and the gas lights. But on one, no clicking at all....
Try Google your manufacture name model # and the word parts. This will not correct your lighting problem. It sounds like you have a igniter switch problem.
always unplug electricity before attempting to repair on any electrical appliance
Sep 04, 2017 | Magic Chef CGC2536 Gas Cooktop
Igniter will not turn off. Makes a clicking sound
Hi, normally what causes the igniter to keep clicking is spilling water or something down into the knob area. The water is causing a short circuit in the switch which is mounted on each burner valve shaft. If unplugging the range for several days to allow drying doesn't fix the problem, then one of the switches will need to be replaced.
Jan 27, 2010 | Magic Chef Cooktops
Magic Chef propane in 90 Terry 5th Wheel
unfortunately the model plate for these
was usually mounted on the the drop wall
or were paper on the inside right corner
Oct 05, 2009 | Cooktops
Replacement Knobs for 60's Universal Chef- Waste King Universal
I have an old Universal Chef stove - we are replacing - it is probably a mid to late 60's - the oven pan is warped - otherwise it works fine - burners, knobs, grates etc. are good - willing to let go cheap - contact Chester Koch 573-898-5508 (Elsberry, MO)
Apr 24, 2009 | Cooktops
Magic chef rv oven burners work fine oven pilot hard to get lit and when it does lite the oven burner will not lite can you help me
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
Apr 08, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Kenmore gas stove top switch harness replacement instructions
for the 4 burner if u not use coz of no igniter,use matches or lighter every time to use,if not turn the burner remove the knob & try to use hammer slowly at the top of the gas valve mostly the problem is stockcup,use oil b4 u try to turn.for the harness wire call the contact service center to buy a harness wire to replace the parts,but it so easily to replace the wire try to open the unit to see the wire size,color then gi to hardware to buy a wire same as in ur unit.tnx gerbee
Jan 27, 2009 | Dacor Preference SGM466 Gas Cooktop
My Magig Chef Glass Rangetop
This part can cost over $400. It is usually not worth fixing. NEVER operate the stove with a cracked top. This is tempered glass and it can just explode! It is also a dangerous electrical issue. Liquid can drip down through the crack and contact the live open element.
Jul 13, 2008 | Magic Chef 30 in. 8241RT Gas Cooktop
Cooktops Logo
95 people viewed this question
Top Magic Chef Cooktops Experts
ray gallant
Tom Chichester
marlin siecinski
Are you a Magic Chef Cooktop Expert? Answer questions, earn points and help others
