Question about Brother MFC 210C All-In-One InkJet Printer
My brother mfc210c prints ok, except for red. I have replaced all of the print cartridges, but still will not print red. Can I replace the print head for the Magenta cartridge? Bill Lannin
    Brigadier General:
  • 3,513 Answers
Hi
It is highly probable your red [Magneta] Printhead is clogged.
Magneta [red] is one of the three primary printing colors;
You need to clean the red printhead.
Check the bellow links…
http://www.youtube.com/watch?v=fGKFg0r7CXc&feature=related
http://www.retrevo.com/pdf/23576ag723/191/Cleaning+the+print+head/
http://www.youtube.com/watch?v=3DSZNhEj3o4
Also check this bellow link to follow the discussions…
http://www.fixyourownprinter.com/forums/inkjet/58899
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 04, 2010
Print test page mfc210c
good day...If you done for cleaning the printer head, the the nozzle check have some missing squares in between, either black or all color, will theirs a problem on the print head...the solution is need to replace the printer head
Nov 28, 2017 | Brother MFC 210C All-In-One InkJet Printer
Mfc 5860 red printing green - already checked print levels. all are fine.
1. Confirm that the colors are incorrect by printing a Print Quality Check Sheet
a. Press INK.
b. Press the UP OR DOWN ARROW key to select Test Print.
c. Press OK.
d. Use the UP OR DOWN ARROW key to select Print Quality.
e. Press OK.
f. Press COLOR START
The machine will generate the Print Quality Check Sheet.
2. The LCD will ask "IS QUALITY OK? 1. YES 2. NO"
a. Press STOP/EXIT to return to the "Date and Time" display.
3. Evaluate the Print Quality Check Sheet.
On the Print Quality Check Sheet each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
NOTE: Cyan is the light blue color and magenta is the pinkish color.
a. If the colors on the Print Quality Check Sheet do not match the sequence listed above then the ink cartridges are most likely installed in the wrong order. Continue to STEP 4 to resolve this.
4. Open the Ink Refill cover.
5. Open the cartridge covers of the colors that do not appear in the correct order.
6. Remove the cartridges and reinstall them in the correct slots. On Brother Genuine Cartridges the color of the label will match the color of the cartridge cover.
7. Run a "Setup Purge". A Setup Purge is necessary to replace the ink in the ink supply tubes with the correct color. One or more of the ink cartridges may run empty during this process. If they do, replace the empty cartridge with a Brother Genuine Ink Cartridge before continuing the process.
a. Press MENU - BLACK START - MENU. The LCD will display Maintenance.
b. Press 7-6, The LCD will display CLEANING ALL
c. Press 6, the LCD will display eINIT__P ALL
d. Press the RIGHT ARROW key until one of the colors that was installed incorrectly is displayed. i.e. eINIT__P CYAN.
e. Press the BLACK START Key.
  • After the machine completes the Setup Purge it will return to the Standby Display.
8. Print another Print Quality Check Sheet
a. Press INK.
c. Press OK.
e. Press OK.
9. The machine will generate another Print Quality Check Sheet.
a. If all four colors printed correctly the issue is resolved.
b. If one or more of the colors are still not printing in the correct order repeat STEPS 4 - 8.
Feb 17, 2011 | Brother MFC-5860CN InkJet Printer
MFC210C wont print yell or blue only blk &mag. HELP!
Pull the cartridges out and them turn it off and then turn it back on then try placing them back in...Because the cartridges work on suckion.
May 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC210C printer not working
ok, please follow the following site ------
http://www.windowsdevcenter.com/pub/a/windows/2004/09/28/printer_problems.html
Thanks
Dec 02, 2008 | Brother MFC 210C All-In-One InkJet Printer
Borther mfc210c black ink not printing even after cleaning
if your brother machine is within warranty, give the tech support a call. if not,replace the black cartridge with a new one. it may be a defective cartridge that you have or if you are using refilled cartridges, it will also give the same problem
Nov 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
MFC210C can't print in blck
I had a similar problem. The printer had indicated that it was out of black ink. I didn't have one on hand, so, for more than a week I couldn't print anything, because if you are out of any one of the four ink cartridges, it won't print at all. That delay in replacing the black ink cartridge apparently was enough time for the printhead to dry out. Big Mistake! I contacted Brother's Tech Support and they suggested I run the cleaning cycle and try to print a test page. Still nothing printed. They had me run another cleaning cycle, and another, and another. Finally, after the fourth cleaning cycle, something started to show up on the paper. They had me clean it two more times, six in all, and it was back to normal. From now on, if it says one of the ink cartridges is empty, I change it yesterday. The major disadvantage of all of this, other than not being able to print for awhile, is that this procedure used up about 1/2 of a brand new black ink cartridge.
Oct 04, 2008 | Brother MFC 210C All-In-One InkJet Printer
I have mfc210c that come with three color of ink,two of them ran out which is fine because i just want to use the black ink only but it with not let me use it what can i do to use just the black ink, i...
See if there is a printer software setup option that will allow you to set B/W printing only. If not you may be out of luck. Could be this particular print device requires all colors available.
Sep 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
Ink jets clog after periods of non-use
You need to run inkjet printers regularly. I expect your brother is right - for once?
If you can't get them clean, replace the cartridges, and print a test sheet at least, every week or so.
You may get away by standing the bottom of the cartridges in windex, or other mild solvent, for a couple of hours. It may save a few teaspoonfuls of ink, but the initial prints will be rubbish ;-)
Dec 21, 2007 | Lexmark X75 All-In-One InkJet Printer
UNABLE TO CLEAN
http://www.fixya.com/support/t233921-not_printing
you need to get error code there are many posts on this your is simular to 210,215,110,115, 3240, 425, 445 etc etc
probally waste tank full, look under brother inkjets here on fixya
Nov 13, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
47 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
