Washing machine works whenever it feels like... sometimes I just can't get it to work. all lights are on but doesn't fill up but if I leave it for a few hours it decides to work.. even pausing it to lift lid to add something I can't get it working again.. it's a fisher and parkel over ten years old not sure on model and recently water coming out the bottom occasionally ..
    Top Expert:
  • Washing Mach... Master
  • 51,269 Answers
Problem in the program board
get in a technician to diagnose all of the faults then decide if a new unit is a viable option
Posted on Sep 06, 2017
SOURCE: GLW10US won't do anything but beep
We love our new Bosch but... THE BEEPING IS TERRIBLE!!! I put a load in to wash when we go to bed. The beeping wakes us up. It is BAD!!
Posted on Jun 17, 2008
  • 22 Answers
SOURCE: Maytag Atlantis Washing Machine does not ever drain or spin unless lift lid
your machine needs a new lid switch assembly!
Posted on Aug 22, 2008
stephanos18
  • 144 Answers
SOURCE: water filling issue
It sounds like you have a faulty Out of Balance Micro switch(the machine now thinks it's always out of balance) you'll find this under the motor controller module (main computer module) in the top of the machine on the righthand side. Anymore questions feel free to ask. cheers
Posted on May 15, 2009
  • 56 Answers
SOURCE: Washing machine wont work at all
Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Posted on Mar 19, 2010
  • 159 Answers
SOURCE: No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
Posted on May 30, 2010
Testimonial: "Very helpful, as I was completely ignorant about the workings of a washing machine. Replied promptly and had a good sense of humour - important in a crisis!"
My front load washing machine agitate but won't spin
If your machine is rather old or used quite frequently, you should check out the motor brushes. Go to youtube for details on washing machines brushes.
Mar 06, 2015 | Washing Machines
My idesit IWB5113 just keeps filling after starting the wash cycle, normal it inject some water then starts washing, my machine just keeps filling and doesn't seem to start the wash cycle, please help
It is possible that the water level sensor has failed and so does not detect to stop the inlet valve from filling.You can remove and check this level sensor normally it can be a damaged diaphragm and replace the same so that the program proceeds to the next stage to start the machinetips to see working of the machine;http://www.espares.co.uk/advice/washing-machines/a/7/1392/how-a-washing-machine-works.html
Mar 14, 2012 | Washing Machines
Kenmore elite quietpak2 the when washing machine is not in use the drum fills with water. It flooded part of the garage
You have a bad water valve. The water valve is located where the hot and cold water hoses hook to the washer.Sometimes if your lucky you can take apart the valve and clean it and get it to work. It's worth a try if it doesn't work then you will have to buy a new valve.Hope this helped and thank you for using FIX ya.
Jun 20, 2011 | Washing Machines
I have a ge washing machine that will fill up wtih water but will not do anything including drain out. please help
after it fills up can you hear the motor running ,if so then your motro coupling has broken,whenever a machine gets out of balance it sometimes breaks the coupling,it's only rubber and plastic,cost about $20,have to remove the motor to replace it!
Jan 15, 2010 | Washing Machines
No water pressure on fill.
Hi, If you have checked the screens in the mixer valve and there is nothing plugging it, then it is most likely the mixer valve.
I hope this helps. Please let me know and feel free to rate my response to you.
Thanks
Vic
May 20, 2009 | Kenmore 22422 Top Load Washer
Maytag neptune starts to fill with water then stops
Water inlet valve sounds faulty.
Fill s to slow so it automatically shuts off.
Not a do it your self problem.
Apr 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
