Question about Hitachi Travelstar 7K320 HTS723232L9A360 320 GB SATA Hard Drive
I NEED sata driver for HTS723232L9A360. - Hitachi Travelstar 7K320 HTS723232L9A360 320 GB SATA Hard Drive
Please, give me a Sata driver for this HDD
The driver you need is for the onboard IDE/SATA controller. Locate the make and model of your motherboard, visit the support site that they have online, download the driver for the IDE/SATA/RAID (if applicable) controller.
Mar 24, 2014 | Fujitsu 40GB MHW2040BS SATA Mobile 40 GB...
Sata driver for Samsung harddisk
You need driver SATA controller that is used on your motherboard. You need to find CD or download from internet, drivers for your SATA controller that is used by your motherboard. Put this *.inf files on bootable Floppy diskette. In Windows XP setup press F6, when it askes you. If you found correct driver you will see your HDD in setup.
Apr 16, 2010 | Computers & Internet
My hitachi 320GB external hard drive is not mounting on my macbook (mac os x 10.5) and is not even found in disk utility.
When this happens, usually the drive is a total loss. You can check this by connecting to a USB to hard drive dongle, and connect to a windows PC, IF it works here you may simply need to reformat back on the Apple. If it doesn't then the drive is bad.
Mar 16, 2010 | Hitachi Travelstar 7K320 HTS723232L9A360...
MY Compaq Presario CQ40-330TU doesnot installing XP software
Hi
You need to have xp cd with sata disk driver support.
You can make xp with sata driver verymuch easily by downloading sata driver from intel site or other site and merging with xp cd.
Inorder to merge xp with sata driver you need to use the nlite software whcih can be downloaded from .http://www.nliteos.com/
For guide for creating xp with sata use this link http://www.nliteos.com/guide/
For sata driver u can use this link http://www.zyxware.com/articles/2008/10/07/compaq-presario-cq40-108tu-laptop-drivers-for-windows-xp evenethogh it is different model sata driver will be same and it will support for this model also
Mar 01, 2010 | Computers & Internet
I have a Toshiba Tecra S3 laptop with a standard Toshiba SATA hard drive (MK6032GSX rv. AS311G). It was a corporate hand me down. It is in dire need of a re-format due to age and virus but when I try it...
Windows XP does not have the SATA driver on the install CD.
You need to download the SATA driver for your model laptop from the Toshiba WEB support/download page.
If the laptop has floppy drive, then copy the SATA driver to the floppy and when you boot up with the Windows XP install CD and then press F6 to install the SATA drivers which is on the floppy as instructed..
Oct 30, 2009 | Computers & Internet
Run a sata drive as main boot up drive. Xp on ide cant see new sata drive to format or install Windows 7?
XP installation does not have SATA drivers.
You need to have the SATA driver on a floppy disk and during the XP installation press F6 to install the SATA driver.
The other alternative is to change the BIOS configuration and set the disk controller to IDE or SATA native driver, then install XP.
After Windows installation then install the SATA driver.
Download the driver from the motherboard WEB site.
Oct 10, 2009 | ASUS K8S-MX Motherboard
SATA driver to install in old XP SP1 system cloned on new SATA dr
Vista handles SATA driver support pretty well, but if you need XP you can follow this guide http://www.digitgeek.com/how-to-slipstream-sata-drivers-into-xp-cd/
Aug 07, 2009 | Albatron MB ALBATRN NF3 250GP|K8X250GB PRO...
Change geteway laptop from vista to xp
Yes you can but disable the SATA in the BIOS first and after Xp is installed you can install the SATA driver.
XP does not have a SATA driver or a SCSI driver on the CD and you need to interrupt the install process to insert this driver.
Leave the BIOS set to SATA, download the SATA driver and create a floppy with the SATA driver. Boot up the Windows XP install disk and when it asks for a a hard disk driver press F6 (I think it is this key, you have to be quick) insert the floppy with the SATA driver.
May 03, 2009 | Gateway M-6834 Notebook
Need SATA hardisk driver for DOS
GO ON LINE AND TYPE THE FOLLOWING INFORMATION:
SATA HARD DISK DRIVERS FOR DOS
OR
DOS HDD DRIVERS FOR SATA
OR
DOS DRIVERS
OR
DIRECT OPERATIONAL SOFTWARE
ROD
Mar 05, 2009 | Toshiba Laptop Keyboard for Satellite L10,...
Hitachi Travelstar 7K320 HTS723232L9A360 320 GB SATA Hard Drive Logo
198 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
